CME 8.6 Call forwarding but no audio
Michael Durham
Level 4
Level 4
I have a working CME 8.6 system except that when I set call forward all on a phone we get no audio on the number calls are forwarded to in either direction.  The forwarded call does go through just neither party can hear the other party.  All calls are going through our SIP provider and we can have four or more simultaneous calls with no problem.
Has anyone heard of any problems with CME 8.6 and call forwarding with this issue?  Does anyone have call forwarding to a third party (cell phone etc) working on CME 8.6?
Any suggestions for debugging the issue via the router or via a PC would be greatly welcomed!
We cannot make conference calls either but I thought we did having it working once. And when I remember conferencing working (if I remember correctly), we still did not have audio on forwarded calls.
Internal transfers do work and audio is fine.
Our SIP provider is Anveo, www.anveo.com and we have 2 + 1 trunks.
Thank You,
Michael
Current configuration : 24030 bytes
! No configuration change since last restart
version 15.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime year
service password-encryption
service sequence-numbers
hostname TDC_CME_Router
boot-start-marker
boot-end-marker
logging buffered 10000000
enable secret 5 Cisco
no aaa new-model
clock timezone Eastern -5 0
clock summer-time DST recurring
dot11 syslog
ip source-route
ip cef
ip dhcp smart-relay
ip dhcp relay information option
ip dhcp excluded-address 192.168.69.1 192.168.69.240
ip dhcp excluded-address 10.110.0.1 10.110.0.20
ip dhcp excluded-address 192.168.125.1 192.168.125.9
ip dhcp excluded-address 192.168.200.1 192.168.200.99
ip dhcp excluded-address 192.168.200.102 192.168.200.109
ip dhcp excluded-address 192.168.200.112 192.168.200.219
ip dhcp excluded-address 192.168.26.1 192.168.26.99
ip dhcp pool Wiireless
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
domain-name thedurhamcorporation.com
dns-server 8.8.8.8
option 150 ip 10.110.0.1
lease 0 12
ip dhcp pool Users
network 192.168.69.0 255.255.255.0
default-router 192.168.69.1
dns-server 8.8.8.8
lease 0 12
ip dhcp pool Voice
network 10.110.0.0 255.255.255.0
default-router 10.110.0.1
dns-server 8.8.8.8
lease 0 12
ip dhcp pool Reserved69
host 192.168.69.101 255.255.255.0
hardware-address 0800.091a.8987
dns-server 8.8.8.8
ip dhcp pool Hopper_Durham
host 192.168.200.100 255.255.255.0
client-identifier 2857.67f3.df77
dns-server 8.8.8.8
ip dhcp pool Joey_Durham
host 192.168.200.101 255.255.255.0
client-identifier 000d.c5e1.62fb
dns-server 8.8.8.8
ip dhcp pool Hopper_Sommers
host 192.168.200.110 255.255.255.0
dns-server 8.8.8.8
ip dhcp pool Joey_Sommers
host 192.168.200.111 255.255.255.0
dns-server 8.8.8.8
ip dhcp pool TempVMware
network 192.168.70.0 255.255.255.0
default-router 192.168.70.1
dns-server 8.8.8.8
ip dhcp pool CUCM_Voice
network 192.168.27.0 255.255.255.0
default-router 192.168.27.1
dns-server 8.8.8.8
option 150 ip 192.168.26.10
ip domain name thedurhamcorporation.com
ip name-server 4.2.2.2
ip name-server 8.8.8.8
no ipv6 cef
password encryption aes
voice service voip
no ip address trusted authenticate
allow-connections sip to sip
no supplementary-service sip moved-temporarily
redirect ip2ip
sip
registrar server
voice class codec 1
codec preference 1 g711ulaw
voice register global
voice translation-rule 1
rule 1 /15552439001/ /1000/
rule 2 /15552875487/ /1000/
rule 3 /15554564538/ /1538/
voice translation-rule 2
rule 1 /\([2-9].........\)/ /1\1/
voice translation-rule 3
rule 1 /411/ /18003733411/
voice translation-rule 4
rule 1 reject /0/
voice translation-profile BLOCK-INBOUND
translate calling 4
voice translation-profile Free_411
translate called 3
voice translation-profile Incoming_calls
translate called 1
voice translation-profile Ten_Digit_Dialing
translate called 2
voice-card 0
dsp services dspfarm
crypto pki trustpoint TP-self-signed-2516279958
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2516279958
revocation-check none
rsakeypair TP-self-signed-2516279958
crypto pki certificate chain TP-self-signed-2516279958
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32353136 32373939 3538301E 170D3133 30373233 30373030
31355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35313632
37393935 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A322 EE57B83E 4C7B7947 8EE8EF6D 931234DB 41A4D133 19D8D297 32FF0E5F
10B94981 E7A1EA06 76CD851B FA24BDA8 561F4CC6 22C3B73B B0742465 571E07C9
04EE1661 7FC5B487 B6686CBB 22B49313 238DF90C 3795649E FA8CAD50 C0CE6A9D
E11FE11E 66870AC2 1492AE74 BBA1E419 1A7FE7F0 C88A8543 5CC6316C 2600101B
A32B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 1402DCB2 F8C6A62B 687347AB DEA0875E ECB7063E 8C301D06
03551D0E 04160414 02DCB2F8 C6A62B68 7347ABDE A0875EEC B7063E8C 300D0609
2A864886 F70D0101 05050003 8181002E 9E5AC99B CCCF28EB 9D517ECD EA130719
EB97B0CA 09CA4AA9 5D88C9C0 FFAE75FE 09B78CD5 3023BC39 B98E4B1F D3B72C82
FDCB8BA1 620A9433 3ED237D6 CFCB8D1E 67BD4232 FECF61EB 37499502 BB3F2899
E77260E9 985F9938 C47E7A09 37A07302 3C851D7A DAEF35A5 495E0220 C3F17AFB
B68AE9D3 F0CFE894 7E8DBC39 ED077B
quit
license udi pid CISCO2811 sn FTX1219A186
dial-control-mib retain-timer 10080
dial-control-mib max-size 500
username mdurham privilege 15 password 7 Cisco
username ldisbrow privilege 15 password 7 Cisco
username ssommer privilege 15 password 7 Cisco
redundancy
gw-accounting syslog
interface FastEthernet0/0
description "VMWare Server"
no ip address
ip nat inside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
interface FastEthernet0/0.26
encapsulation dot1Q 26
ip address 192.168.26.1 255.255.255.0
ip nat inside
no ip route-cache
interface FastEthernet0/0.50
encapsulation dot1Q 50
ip address 192.168.50.1 255.255.255.0
ip nat inside
no ip route-cache
interface FastEthernet0/1
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0/1.2
ip address 192.168.0.253 255.255.255.0
ip nat inside
no ip route-cache
interface FastEthernet0/1.27
encapsulation dot1Q 27
ip address 192.168.27.1 255.255.255.0
ip nat inside
no ip route-cache
interface FastEthernet0/1.69
description "Data Network"
encapsulation dot1Q 69 native
ip address 192.168.69.1 255.255.255.0
ip nat inside
no ip route-cache
interface FastEthernet0/1.110
description "Voice Network"
encapsulation dot1Q 110
ip address 10.110.0.1 255.255.255.0
ip nat inside
no ip route-cache
interface FastEthernet0/1.125
description "TV & Media Network"
encapsulation dot1Q 125
ip address 192.168.125.1 255.255.255.0
ip nat inside
no ip route-cache
interface FastEthernet0/1.200
description "Wireless - Guest User Network"
encapsulation dot1Q 200
ip address 192.168.200.1 255.255.255.0
ip access-group 100 in
ip nat inside
no ip route-cache
interface FastEthernet0/1/0
description Connects to MoFi 4G modem and Verizon
ip address dhcp
ip nat outside
ip nat enable
no ip route-cache
duplex auto
speed auto
router eigrp 1577
network 10.110.0.0 0.0.0.255
network 192.168.0.0
network 192.168.26.0
network 192.168.50.0
network 192.168.125.0
network 192.168.254.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:/CME_GUI
ip nat inside source list 20 interface FastEthernet0/1/0 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1/0
logging esm config
logging history size 500
access-list 20 remark Networks Allowed onto the Internet
access-list 20 permit 10.110.0.0 0.0.0.255
access-list 20 permit 192.168.0.0 0.0.0.255
access-list 20 permit 192.168.26.0 0.0.0.255
access-list 20 permit 192.168.27.0 0.0.0.255
access-list 20 permit 192.168.50.0 0.0.0.255
access-list 20 permit 192.168.69.0 0.0.0.255
access-list 20 permit 192.168.125.0 0.0.0.255
access-list 20 permit 192.168.200.0 0.0.0.255
access-list 100 remark "Block access from the Guest network to everything except the printer & the Interent
access-list 100 permit ip any host 192.168.69.99
access-list 100 permit ip any 192.168.200.0 0.0.0.7
access-list 100 deny ip any 192.168.0.0 0.0.255.255
access-list 100 permit ip any any
tftp-server flash:TFTP/7962/apps42.9-2-1TH1-13.sbn
tftp-server flash:TFTP/7962/cnu42.9-2-1TH1-13.sbn
tftp-server flash:TFTP/7962/cvm42sccp.9-2-1TH1-13.sbn
tftp-server flash:TFTP/7962/dsp42.9-2-1TH1-13.sbn
tftp-server flash:TFTP/7962/jar42sccp.9-2-1TH1-13.sbn
tftp-server flash:TFTP/7962/SCCP42.9-2-1S.loads
tftp-server flash:TFTP/7962/term42.default.loads
tftp-server flash:TFTP/7962/term62.default.loads
tftp-server flash:TFTP/7960/P0030801SR02.bin
tftp-server flash:TFTP/7960/P0030801SR02.loads
tftp-server flash:TFTP/7960/P0030801SR02.sb2
tftp-server flash:TFTP/7960/P0030801SR02.sbn
tftp-server flash:TFTP/7921/APPS-1.4.1SR1.SBN
tftp-server flash:TFTP/7921/CP7921G-1.4.1SR1.LOADS
tftp-server flash:TFTP/7921/GUI-1.4.1SR1.SBN
tftp-server flash:TFTP/7921/SYS-1.4.1SR1.SBN
tftp-server flash:TFTP/7921/TNUX-1.4.1SR1.SBN
tftp-server flash:TFTP/7921/TNUXR-1.4.1SR1.SBN
tftp-server flash:TFTP/7921/WLAN-1.4.1SR1.SBN
tftp-server flash:TFTP/7935/P00503021900.bin
tftp-server flash:TFTP/7985/cmterm_7985.4-1-7-0.bin
tftp-server flash:TFTP/9971/kern9971.9-2-2SR1-9.sebn
tftp-server flash:TFTP/9971/rootfs9971.9-2-2SR1-9.sebn
tftp-server flash:TFTP/9971/sboot9971.031610R1-9-2-2SR1-9.sebn
tftp-server flash:TFTP/9971/sip9971.9-2-2SR1-9.loads
tftp-server flash:TFTP/9971/skern9971.022809R2-9-2-2SR1-9.sebn
tftp-server flash:TFTP/9971/dkern9971.100609R2-9-2-2SR1-9.sebn
tftp-server flash:Desktops/320x212x12/CTS_Phn_TN.png
tftp-server flash:Desktops/320x212x12/CTS_Phn.png
tftp-server flash:Desktops/320x212x12/List.xml
control-plane
no ccm-manager fax protocol cisco
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp profile default
sccp ccm 10.110.0.1 identifier 1 priority 1 version 7.0
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register tdxcode
associate profile 1 register TDCCONF
dspfarm profile 2 transcode universal
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g722-64
codec g729r8
codec ilbc
maximum sessions 3
associate application SCCP
shutdown
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 4
shutdown
dial-peer cor custom
name LoK_Local
name LoK_National
name LoK_International
name LoK_EMS
dial-peer cor list Keyring-Local
member LoK_Local
member LoK_EMS
dial-peer cor list Keyring-National
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer cor list Keyring-International
member LoK_Local
member LoK_National
member LoK_International
member LoK_EMS
dial-peer cor list Keyring-EMS-Only
member LoK_EMS
dial-peer cor list Door-Local
member LoK_Local
member LoK_EMS
dial-peer cor list Door-National
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer cor list Door-International
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer cor list Door-EMS-Only
member LoK_EMS
dial-peer voice 911 voip
corlist outgoing Door-EMS-Only
destination-pattern 911
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
dial-peer voice 100 voip
description *** Incoming Calls VoIP ***
translation-profile incoming Incoming_calls
call-block translation-profile incoming BLOCK-INCOMING
call-block disconnect-cause incoming call-reject
preference 1
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 210 voip
corlist outgoing Door-National
description *** Outbound 10 Digit Dialing Calls ***
translation-profile outgoing Ten_Digit_Dialing
preference 1
destination-pattern [2-9].........$
translate-outgoing called 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 200 voip
description *** Outbound 11 Digit Dialing Calls ***
preference 1
destination-pattern 1[2-9]..[2-9]......$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 5000 voip
description Dial-peer to the Voicemail System"
destination-pattern 5000
b2bua
session target ipv4:10.110.0.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 5050 voip
description Dial-peer to the Auto Attendant"
destination-pattern 5050
b2bua
codec g711ulaw
no vad
dial-peer voice 5051 voip
description Dial-peer to the CUE Management System"
destination-pattern 5051
b2bua
codec g711ulaw
no vad
gateway
timer receive-rtp 1200
sip-ua
credentials username 5559487364 password 7 Cisco realm anveo.com
authentication username 5559487364 password 7 Cisco realm anveo.com
mwi-server ipv4:10.110.0.2 expires 3600 port 5060 transport udp unsolicited
registrar dns:sip.anveo.com:5010 expires 180
sip-server dns:sip.anveo.com:5010
gatekeeper
shutdown
telephony-service
sdspfarm units 2
sdspfarm tag 1 TDCCONF
sdspfarm tag 2 tdxcode
conference hardware
max-ephones 42
max-dn 100
ip source-address 10.110.0.1 port 2000
service phone daysDisplayNotActive 1,7
service phone displayOnTime 08:00
service phone displayOnDuration 12
service phone displayIdleTimeout 00:10
service phone settingsAccess 1
service phone modeOfOperation 1
service phone displaywhebincomingcall 1
system message The Durham Corporation
url services http://w1.weather.gov/xml/current_obs/KLCQ.xml
load 7921 CP7921G-1.4.1SR1
load 7935 P00503021900
load 7960-7940 P00308000800
load 7962 SCCP42.9-2-1S
load 7985 cmterm_7985.4-1-7-0
time-zone 12
voicemail 5000
mwi relay
max-conferences 2 gain -6
call-park system redirect
call-park system application
moh music-on-hold.au
multicast moh 239.2.2.2 port 2000
web admin system name Admin password Cisco
dn-webedit
time-webedit
transfer-system full-consult
after-hours block pattern 1 1010 7-24
after-hours block pattern 2 1900 7-24
directory entry 11 8002758777 name US Post Office
directory entry 12 8004633339 name FedEx
directory entry 16 8772234714 name QuickBooks Support
directory entry 17 8665403229 name eBay
directory entry 18 9135424700 name FreightQuote
fac standard
ephone-template 1
softkeys connected Hold Endcall Park Trnsfer Confrn Join LiveRcd Mobility
max-calls-per-button 4
type 7921
ephone-dn 1 dual-line
number 1000
label Certification Solutions
description Main Line - CTS
name Main Line - CTS
call-forward busy 5000
call-forward noan 5000 timeout 25
ephone-dn 2 dual-line
number 1010
label CTS Sales
description Sales Line
name CTS Sales
call-forward noan 5000 timeout 17
corlist incoming Keyring-National
ephone-dn 3 dual-line
number 1020
label CTS Service
description Customer Service Line
name CTS Service
ephone-dn 4 dual-line
number 1030
label CTS Support
description Technical Support Line
name CTS Support
ephone-dn 8
number 1106
label Garage
description Garage Phone, no outbound calls
trunk 1000
ephone-dn 10 dual-line
number 1100
label Michael T. Durham
description Michael T. Durham
name Michael T. Durham
ephone-dn 11 dual-line
number 1101
label Lacey
description Lacey Desk phone
name Lacey Disbrow
ephone-dn 12 dual-line
number 1102
label Living Room
description Living Room
name Living Room
ephone-dn 13 dual-line
number 1103
label Shop
description Shop
name Shop Video Phone
ephone-dn 14 dual-line
number 1104
label Hanger
description Hanger
name Hanger Phone
call-forward noan 5000 timeout 30
ephone-dn 15 dual-line
number 1105
label Bedroom
description Michaels Bedroom
name intercom Living Room
ephone-dn 18 dual-line
number 1108
label Valerie
description Valerie
ephone-dn 19
number B1100
name Intercom Shop
intercom A1103 no-mute label "Shop"
ephone-dn 20
number A1100
name Intercom Lacey
intercom A1101 no-mute label "Lacey"
ephone-dn 21
number A1100
name Intercom Living Room
intercom A1102 no-mute label "Living Room"
ephone-dn 22
number A1100
name Intercom Shop
ephone-dn 23
number A1100
name Intercom Hanger
intercom A1104 no-mute label "Hanger"
ephone-dn 25
number A1101
name Intercom Michael
intercom A1100 no-mute label "Michael T. Durham"
ephone-dn 26
number A1101
ephone-dn 27
number A1101
description Intercom from Lacey to Shop
name Iintercom Shop
ephone-dn 28
number A1101
ephone-dn 30
number A1102
ephone-dn 31
number A1102
name Intercom Lacey
ephone-dn 32
number A1102
name Intercom Shop
ephone-dn 33
number A1102
ephone-dn 35
number A1103
description From Shop to Michael's video phone
intercom B1100 no-mute label "Michael T. Durham"
ephone-dn 36
number A1103
description Intercom form Shop to Lacey
name Intercom Lacey
ephone-dn 37
number A1103
description Intercom from Shop to Living Room
ephone-dn 38
number A1103
description Intercom from Shop to Hanger
ephone-dn 39
number A1103
ephone-dn 40
number A1111
description Intercom from Lacey to Living Room
ephone-dn 41
number A1111
description From Lacey to Michael's phone
ephone-dn 42
number A1100
description From Michael to Lacey's phone
intercom A1111 no-mute label "Lacey"
ephone-dn 43
number A1100
description From Living Room to Lacey's phone
intercom A1111 no-mute label "Living Room"
ephone-dn 50
number 3000
park-slot timeout 300 limit 3 notify 1000 transfer 5000
ephone-dn 51 dual-line
number 3001
park-slot timeout 300 limit 3 recall alternate 1000
ephone-dn 60 dual-line
number 1538
label "KD Technologies"
description Shop
name KD Technologies
ephone-dn 98 octo-line
number AA01
conference ad-hoc
ephone-dn 99
number 5998....
mwi off
ephone-dn 100
number 5999....
mwi on
ephone 9
device-security-mode none
description "Office Video Phone"
video
mac-address 0050.6003.2BE8
ephone-template 1
type 7985
button 1:3 2:1 3f2 5:19
button 6:12
ephone 10
description "Michael T. Durham"
mac-address 0014.A998.C12D
ephone-template 1
type 7971
mwi-line 2
button 1:10 2:1 3:20 4:21
button 5:22 6f60
ephone 11
description Lacey
mac-address 0013.C461.BB6F
ephone-template 1
type 7970
button 1:11 2:1 3:41 4:40
ephone 12
description "Living Room Phone"
mac-address 0026.0B5C.795D
ephone-template 1
type 7945
button 1:1 2:32
ephone 13
description "Shop Video Phone"
video
mac-address 0050.6003.6B74
ephone-template 1
type 7985
button 1:13 2:1 3:35 4f60
button 5:37 6:39
ephone 14
description Hanger Phone
ephone 15
description living room 7971 phone
mac-address 0011.2121.3A94
type 7971
button 1:12 2:1 3:32 4:30
ephone 16
description "Garage Phone"
mac-address 0011.93C2.AE67
type 7905
ephone 17
description "Michael's Bedroom Phone"
mac-address 0008.2128.7A30
ephone-template 1
type 7940
button 1:15 2:1
ephone 18
description Valerie Winters' 7971 phone
mac-address 0015.C696.E15A
type 7971
button 1:18 2:1 3:32 4:30
ephone 20
description Color WiFi Phoen
mac-address 0022.90FD.8AA4
ephone-template 1
type 7921
button 1:1 2:25
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
password 7 Cisco
logging synchronous
login local
terminal-type monitor
monitor
transport input telnet ssh
transport output telnet
line vty 5 15
privilege level 15
password 7 Cisco
logging synchronous
login local
scheduler allocate 20000 1000
ntp master 2
ntp server 216.228.192.69
end
0 Replies 0
