CME 8.6 Call Transfer Issues
Scott Hanson
Level 3
Level 3
Hey folks,
The receptionists answers a call.  She puts it on hold to call an employee to see if they want to take the call.  Employee says they will take the call.  She goes back to the original call and says "I will put you through" and hits Transfer and the employees extension.  Instead of ringing, the call does an auto-answer with no announcement tone, etc.  They want the transferred call to ring first.  Is she doing something wrong or is the configuration wrong?If the config is incorrect what do I need to do to fix it?
All replies rated
Rob Huffman
Hi Scott,
If you set this up as a "Consult" transfer she does not have to put the
caller on hold as it is done automatically as the first step in the Consult
transfer process. If the user does not want to take the call she simply
goes back to the caller, if the user does want to take the call she simply
presses Transfer a second time. This is the standard transfer process
Cheers!
Rob
"Celebration it's around us, every nations, all around us.
Singin' forever young, singin' songs underneath that sun" - K'naan
