CME 8.6 conference call in CP7942
cm6043
Hi all,
When making ad hoc conference call with 6 persons, how can I press "confrn" to connect others in one CP7942.
1. CP7942 A dial to B
2. Press "confrn" in CP7942 to C
3. Press "confrn" in CP7942
4. A, B and C are in conference
5. Press "confrn" in CP7942
6. C will drop call     <-------  So, A cannot make conference call with 6 person in CP7942
Leung Che Man
13 Replies 13
acampbell
This is due to your conferencing config.
Can you post the show run
Rgards
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,
Thanks for your response. Please the attache sh runn.
Leung Che Man
You have no DSP resources configured to provide conferencing.
You asre using the default which only allows a 3 way call.
Please read this chapter in the CME Admin guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html
Alex
Hi Alex,
Thanks for your information. Could you state which part is the required subject ?
Leung Che Man
I will follow the steps and post the result
LEung Che Man
Hi ,
I tried to follow the steps to add. When making ad hoc conference, I get " Cannot Complete Conference" message in the phone CP7942.
Leung Che Man
HI
It seems your conference resources are not registered to CME....
Can you send us new configutaion which you have done after following above mentioned steps.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Please refer to my previous post.
Leung Che Man
I am sorry I missed that...
Please send me Show diag and out put of "Show SCCP"
Ronak Patel
nshk-cme#sh sccp
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/1
        IPv4 Address: 10.34.195.222
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.10.1, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 1
                Trustpoint: N/A
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.10.1, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 2
Reported Max Streams: 16, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
nshk-cme#sh diag
Slot 0:
        C2801 2FE 4SLOT Mainboard Port adapter, 7 ports
        Port adapter is analyzed
        Port adapter insertion time 00:04:19 ago
        EEPROM contents at hardware discovery:
        Chassis MAC Address      : 001b.548b.49de
        MAC Address block size   : 34
        PCB Serial Number        : FOC11150GY0
        Hardware Revision        : 6.0
        Part Number              : 73-8190-06
        Board Revision           : B0
        Top Assy. Part Number    : 800-23435-04
        Deviation Number         : 88989
        Fab Version              : 04
        CLEI Code                : IPM7S00CRA
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : CISCO2801
        Version Identifier       : V03
        Processor type           : 86
        Chassis Serial Number    : FHK1117F1MC
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C3 06 00 1B 54 8B 49 DE 43 00 22 C1 8B 46
          0x10: 4F 43 31 31 31 35 30 47 59 30 40 04 1C 41 06 00
          0x20: 82 49 1F FE 06 42 42 30 C0 46 03 20 00 5B 8B 04
          0x30: 88 00 01 5B 9D 02 04 C6 8A 49 50 4D 37 53 30 30
          0x40: 43 52 41 03 00 81 00 00 00 00 04 00 CB 89 43 49
          0x50: 53 43 4F 32 38 30 31 89 56 30 33 20 D9 02 C1 40
          0x60: 09 86 C2 8B 46 48 4B 31 31 31 37 46 31 4D 43 FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x100: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x110: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8538-05
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 04
        PCB Serial Number        : FOC10130M0G
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-16
        Version Identifier       : V01
          0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 41 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 31 33
          0x20: 30 4D 30 47 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 1:
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC13374RX3
        RMA History              : 00
        Processor type           : 00
          0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 43 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 33 33 37
          0x20: 34 52 58 33 03 00 81 00 00 00 00 04 00 09 00 CB
        WIC/VIC/HWIC Slot 1:
        4 Port FE Switch
        Base MAC Address         : 001a.6dee.17be
        MAC Address block size   : 4
        PCB Serial Number        : FOC10493T7B
        Part Number              : 73-8474-06
        Board Revision           : A0
        Top Assy. Part Number    : 800-24193-02
        Fab Version              : 05
        CLEI Code                : IPUIA00RAA
        RMA History              : 00
        Product (FRU) Number     : HWIC-4ESW
        Connector Type           : 01
          0x00: 04 FF CF 06 00 1A 6D EE 17 BE 43 00 04 C1 8B 46
          0x10: 4F 43 31 30 34 39 33 54 37 42 40 00 56 41 06 00
          0x20: 82 49 21 1A 06 42 41 30 C0 46 03 20 00 5E 81 02
          0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 30 30
          0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
          0x50: 49 43 2D 34 45 53 57 89 56 30 31 20 D9 02 C1 40
          0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        4-Port HWIC-ESW Power Daughter Card:
        Part Number              : 73-8476-04
        Board Revision           : A0
        Fab Version              : 03
        PCB Serial Number        : FOC10484B3P
        RMA History              : 00
        Product (FRU) Number     : ILPM-4
        CLEI Code                : IPUPACDAAA
          0x00: 04 FF 40 00 57 41 04 00 82 49 21 1C 04 42 41 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 30 34 38
          0x20: 34 42 33 50 03 00 81 00 00 00 00 04 00 CB 86 49
          0x30: 4C 50 4D 2D 34 89 56 30 31 20 C6 8A 49 50 55 50
          0x40: 41 43 44 41 41 41 FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF 42 C8
        WIC/VIC Slot 2:
        E1 (1 port) Multi-Flex Trunk WAN daughter card
        Hardware revision 1.0           Board revision A0
        Serial number     20561972      Part number    800-04475-02
        FRU Part Number     VWIC-1MFT-E1=
        Test history      0x0           RMA number     00-00-00
        Connector type    PCI
        EEPROM format version 1
          0x20: 01 21 01 00 01 39 C0 34 50 11 7B 02 00 00 00 00
          0x30: 50 00 00 00 00 06 21 00 FF FF FF FF FF FF FF FF
AIM Module in slot: 0
Service Engine AIM: 0
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-20063-06
        Board Revision           : B0
        Fab Version              : 05
        PCB Serial Number        : FOC11286LZK
        RMA History              : 00
        Product (FRU) Number     : AIM-CUE
          0x00: 04 FF 40 03 8E 41 01 00 C0 46 03 20 00 4E 5F 06
          0x10: 42 42 30 88 00 00 00 00 02 05 C1 8B 46 4F 43 31
          0x20: 31 32 38 36 4C 5A 4B 03 00 81 00 00 00 00 04 00
          0x30: CB 87 41 49 4D 2D 43 55 45 89 56 30 33 20 FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
nshk-cme#
Leung Che Man
I
believe you have less DSP resources
Let us have look in to
show dspfarm dsp all
show dspfarm profile
show dspfarm profile 2
show voice dsp
Please send it is attachment rather pasting it in post.
Ronak patel
Hi Ronak,
Leung che Man
