CME 8.6 with voip.ms
Hi, I am trying to get inbound and outbound calling working. I am trying to get inbound first, and setup my config....however, it rings busy. My provider is VOIP.MS, and it shows registered on their main page and all incoming connections work fine. Even to my VM and AA system. I did a ccsip debug error and attached this with the config as well.
I need help to get our phone system up and communicating.
Thanks!
Ping to chicago.voip.ms works fine too:
USRMIHQ#ping chicago.voip.ms
Sending 5, 100-byte ICMP Echos to 173.208.83.50, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/30/60 ms
USRMIHQ#
26 Replies 26
I tried entering config but it gets me a fast busy.
changing it to session transport UDP however works but with a "unknown" called ID, and one way audio to my cell phone, but not back to my 7940.
Your debugs don't include the full call trace however I can see the following from what is provided.
It looks like a call arrives from the SIP provider (chicago.voip.ms) with:
Calling number = 5173914946
Called Number = 7347947685
You have a dial peer that translates the called number from 7347947685 to 1000, which should route to address 10.0.0.5. I don't see any outgoing INVITE messages to this address.
I notice that you are binding all SIP media and signalling to interface GI0/0 however the SIP server 10.0.0.5 would be routed through interface GI0/1.1. I would remove the binding command and try the traces again. This time increase the scroll back or use logging on your terminal application to catch the full call trace.
I tried removing bindings and now my internal phones will not reach AA and Exchange VM. The internal phones work just fine....obviously with the bindings in place.
Out, coming in, still rang busy with bindings removed as well.
I'm guessing the exchange server is expecting the source ip of the sip messages to be coming from the ip of your gi0/0 interface, which might be why the internal phones can't reach the exchange vm when the binding command is removed.
For the external aa issue can you capture a full debug of the call. The last one didn't show any messages being sent to the exchange server at all.
For the external one way voice issue, can you establish a call and enter the command "show voip rtp connections"?
User Access Verification
Password:
Password:
USRMIHQ>en
Password:
USRMIHQ#Debug ccsip messages
SIP Call messages tracing is enabled
USRMIHQ#Debug ccsip call
SIP Call statistics tracing is enabled
USRMIHQ#
Mar 26 00:26:03.739: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:chicago.voip.ms:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK14441A74
To: <>1003@chicago.voip.ms>
Date: Tue, 26 Mar 2013 00:26:03 GMT
Call-ID: 5771CE18-936611E2-80049EE5-25EAD9CA
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1364257563
CSeq: 1801 REGISTER
Contact: <1003>
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 00:26:03.779: //3354/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK14441A74;received=10.0.16.1;rport=54109
To: <>1003@chicago.voip.ms>;tag=as3a718f3f
CSeq: 1801 REGISTER
Server: voip.ms
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
WWW-Authenticate: Digest algorithm=MD5, realm="chicago.voip.ms", nonce="4041de99"
Content-Length: 0
Mar 26 00:26:03.783: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK144512D5
Max-Forwards: 70
CSeq: 1802 REGISTER
Contact: <1003>
Expires: 3600
Authorization: Digest username="141349",realm="chicago.voip.ms",uri="sip:chicago.voip.ms:5060",response="06f369e1ffa0e17e0e59db9b7d9472d8",nonce="4041de99",algorithm=MD5
Content-Length: 0
Mar 26 00:26:03.843: //3354/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden (Bad auth)
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK144512D5;received=10.0.16.1;rport=54109
CSeq: 1802 REGISTER
Server: voip.ms
Content-Length: 0
Mar 26 00:26:04.163: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK14461930
To: <>1001@chicago.voip.ms>
Date: Tue, 26 Mar 2013 00:26:04 GMT
Call-ID: 57713157-936611E2-80039EE5-25EAD9CA
Max-Forwards: 70
Timestamp: 1364257564
CSeq: 1801 REGISTER
Contact: <1001>
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 00:26:04.211: //3355/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK14461930;received=10.0.16.1;rport=54109
To: <>1001@chicago.voip.ms>;tag=as72f6953e
CSeq: 1801 REGISTER
Server: voip.ms
WWW-Authenticate: Digest algorithm=MD5, realm="chicago.voip.ms", nonce="66d4c60d"
Content-Length: 0
Mar 26 00:26:04.211: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK1447231F
Max-Forwards: 70
CSeq: 1802 REGISTER
Contact: <1001>
Expires: 3600
Authorization: Digest username="141349",realm="chicago.voip.ms",uri="sip:chicago.voip.ms:5060",response="46505fd1656078b776fc698d1c002273",nonce="66d4c60d",algorithm=MD5
Content-Length: 0
Mar 26 00:26:04.251: //3355/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK1447231F;received=10.0.16.1;rport=54109
CSeq: 1802 REGISTER
Server: voip.ms
Content-Length: 0
Mar 26 00:26:16.867: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:7347947685@75.151.8.65:54109 SIP/2.0
Via: SIP/2.0/UDP 173.208.83.50:5060;branch=z9hG4bK0074536b;rport
Max-Forwards: 70
To: <7347947685>
Contact: <8103347343>
Call-ID:
3d44bacc6b09d76d5ef04cdd5319feab@173.208.83.50
:5060
CSeq: 102 INVITE
User-Agent: voip.ms
Date: Tue, 26 Mar 2013 00:26:16 GMT
Remote-Party-ID: "8103347343" <8103347343>;party=calling;privacy=off;screen=no
Content-Type: application/sdp
Content-Length: 272
v=0
o=root 1903160696 1903160696 IN IP4 173.208.83.50
s=voip.ms
c=IN IP4 173.208.83.50
t=0 0
m=audio 16290 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Mar 26 00:26:16.875: //3356/9B9AE1468699/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <7347947685>
Call-ID:
:5060
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Mar 26 00:26:16.879: //3357/9B9AE1468699/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1000@10.0.0.5:5065 SIP/2.0
Via: SIP/2.0/TCP 10.0.16.1:5060;branch=z9hG4bK144853F
Remote-Party-ID: "8103347343" <8103347343>;party=calling;screen=no;privacy=off
From: "8103347343" <>7347947685@chicago.voip.ms>;tag=9AD1A40-5F5
To: <1000>
Call-ID:
9B9CB5BE-94E211E2-869F9EE5-25EAD9CA@10.0.16.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2610618694-2497843682-2258214629-0636148170
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1364257576
Contact: <7347947685>
Expires: 180
Max-Forwards: 69
Cisco-Gcid: 9B9B7D6E-94E2-11E2-869C-9EE525EAD9CA
Content-Disposition: session;handling=required
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 6157 5110 IN IP4 10.0.16.1
s=SIP Call
c=IN IP4 10.0.16.1
t=0 0
m=audio 17136 RTP/AVP 0 101
c=IN IP4 10.0.16.1
a=fmtp:101 0-16
a=ptime:20
Mar 26 00:26:16.887: //3357/9B9AE1468699/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "8103347343"<>7347947685@chicago.voip.ms>;tag=9AD1A40-5F5
TO: <1000>
CSEQ: 101 INVITE
CALL-ID:
VIA: SIP/2.0/TCP 10.0.16.1:5060;branch=z9hG4bK144853F
CONTENT-LENGTH: 0
TIMESTAMP: 1364257576
Mar 26 00:26:16.979: //3357/9B9AE1468699/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
TO: <1000>;tag=90c43ee857;epid=52D6175B32
CSEQ: 101 INVITE
CALL-ID:
CONTACT: ;automata;text;audio;video;image
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
P-ASSERTED-IDENTITY: <1000>
SERVER: RTCC/5.0.0.0 MSExchangeUM/15.00.0516.029
Received:
SIP/2.0 200 OK
CSEQ: 101 INVITE
CALL-ID:
CONTENT-LENGTH: 266
PRIORITY: Normal
SUPPORTED: Replaces
SUPPORTED: timer
SUPPORTED: 100rel
CONTENT-TYPE: application/sdp
ALLOW: ACK
Content-ID: c22cb324-1b29-4d01-b35c-923220e91000
Allow: CANCEL,BYE,INVITE,MESSAGE,INFO,SERVICE,OPTIONS,BENOTIFY,NOTIFY,PRACK,UPDATE
Session-Expires: 1800;refresher=uas
Min-SE: 1800
v=0
o=- 22 0 IN IP4 10.0.0.5
s=session
c=IN IP4 10.0.0.5
b=CT:10000000
t=0 0
m=audio 31884 RTP/AVP 0 101
c=IN IP4 10.0.0.5
a=rtcp:31885
a=label:main-audio
a=sendrecv
a=fmtp:101 0-16,36
a=ptime:20
Mar 26 00:26:16.983: //3357/9B9AE1468699/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x71331A60
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : YES
Calling Number           : 7347947685
Called Number            : 1000
Source IP Address (Sig  ): 10.0.16.1
Destn SIP Req Addr:Port  : 10.0.0.5:5065
Destn SIP Resp Addr:Port : 10.0.0.5:5065
Destination Name         : 10.0.0.5
Mar 26 00:26:16.983: //3357/9B9AE1468699/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 10.0.16.1
Source IP Port    (Media): 17136
Destn  IP Address (Media): 10.0.0.5
Destn  IP Port    (Media): 31884
Orig Destn IP Address:Port (Media): [ - ]:0
Mar 26 00:26:16.983: //3357/9B9AE1468699/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:USREX01.usrangers.local:5065;maddr=10.0.0.5;transport=Tcp SIP/2.0
Via: SIP/2.0/TCP 10.0.16.1:5060;branch=z9hG4bK14491190
To: <1000>;tag=90c43ee857
Call-ID:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 26 00:26:16.987: //3356/9B9AE1468699/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <7347947685>;tag=9AD1AA8-11FD
Call-ID:
:5060
CSeq: 102 INVITE
Remote-Party-ID: <1000>;party=called;screen=no;privacy=off
Content-Length: 0
Mar 26 00:26:16.991: //3356/9B9AE1468699/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Call-ID:
:5060
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 3678 5378 IN IP4 10.0.16.1
s=SIP Call
c=IN IP4 10.0.16.1
t=0 0
m=audio 19566 RTP/AVP 0 101
c=IN IP4 10.0.16.1
a=fmtp:101 0-36
a=ptime:20
Mar 26 00:26:17.015: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:7347947685@10.0.16.1:5060 SIP/2.0
Via: SIP/2.0/UDP 173.208.83.50:5060;branch=z9hG4bK0634539d;rport
Max-Forwards: 70
Call-ID:
:5060
CSeq: 102 ACK
User-Agent: voip.ms
Content-Length: 0
Mar 26 00:26:17.015: //3356/9B9AE1468699/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x71337450
TCP Sockets Used         : NO
Calling Number           : 8103347343
Called Number            : 7347947685
Destn SIP Req Addr:Port  : 173.208.83.50:5060
Destn SIP Resp Addr:Port : 173.208.83.50:5060
Destination Name         : 173.208.83.50
Mar 26 00:26:17.015: //3356/9B9AE1468699/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 19566
Destn  IP Address (Media): 173.208.83.50
Destn  IP Port    (Media): 16290
Mar 26 00:26:48.012: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:7347947685@10.0.16.1:5060;transport=tcp SIP/2.0
TO: <>7347947685@chicago.voip.ms>;tag=9AD1A40-5F5
CSEQ: 1 BYE
CALL-ID:
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP 10.0.0.5:5065;branch=z9hG4bK6d83dfd
CONTENT-LENGTH: 0
PRIORITY: Normal
SUPPORTED: Replaces
USER-AGENT: RTCC/5.0.0.0 MSExchangeUM/15.00.0516.029
Mar 26 00:26:48.012: //3357/9B9AE1468699/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
Mar 26 00:26:48.016: //3357/9B9AE1468699/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Mar 26 00:26:48.016: //3357/9B9AE1468699/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
Mar 26 00:26:48.016: //3356/9B9AE1468699/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:8103347343@173.208.83.50:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK144AF0A
To: "8103347343" <8103347343>;tag=as62686696
Date: Tue, 26 Mar 2013 00:26:17 GMT
Call-ID:
:5060
Max-Forwards: 70
Timestamp: 1364257608
CSeq: 101 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=1509,OS=241312,PR=29,OR=4640,PL=0,JI=0,LA=0,DU=31
Content-Length: 0
Mar 26 00:26:48.016: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 10.0.0.5:5065;branch=z9hG4bK6d83dfd
To: "8103347343" <>7347947685@chicago.voip.ms>;tag=9AD1A40-5F5
Date: Tue, 26 Mar 2013 00:26:48 GMT
Call-ID:
CSeq: 1 BYE
P-RTP-Stat: PS=29,OS=4640,PR=1511,OR=241488,PL=0,JI=0,LA=0,DU=31
Content-Length: 0
Mar 26 00:26:48.036: //3356/9B9AE1468699/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK144AF0A;received=10.0.16.1;rport=54109
Call-ID:
:5060
CSeq: 101 BYE
Server: voip.ms
Content-Length: 0
Mar 26 00:26:48.040: //3356/9B9AE1468699/SIP/Call/sipSPICallInfo:
Mar 26 00:26:48.040: //3356/9B9AE1468699/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
USRMIHQ#
USRMIHQ#
Mar 26 00:27:01.452: //3358/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:chicago.voip.ms:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK144B1C72
To:
Date: Tue, 26 Mar 2013 00:27:01 GMT
Call-ID:
B62E018E-94E211E2-86A09EE5-25EAD9CA@10.0.16.1
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <10.0.16.1:5060>
Content-Length: 0
Mar 26 00:27:01.476: //3358/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK144B1C72;received=10.0.16.1;rport=54109
To: ;tag=as5e4abdcf
Call-ID:
CSeq: 101 OPTIONS
Server: voip.ms
Contact: <173.208.83.50:5060>
Accept: application/sdp
Content-Length: 0
USRMIHQ#
Mar 26 00:27:11.552: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 173.208.83.50:5060;branch=z9hG4bK6e748181;rport
Max-Forwards: 70
To: <7347947685>
Call-ID:
5a0d65ba403ced95068dd8620265ceaa@173.208.83.50
:5060
CSeq: 102 INVITE
User-Agent: voip.ms
Date: Tue, 26 Mar 2013 00:27:11 GMT
Content-Length: 270
v=0
o=root 550196023 550196023 IN IP4 173.208.83.50
s=voip.ms
t=0 0
m=audio 19950 RTP/AVP 0 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Mar 26 00:27:11.564: //3360/BC332C9786A1/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 10.0.16.1:5060;branch=z9hG4bK144C387
From: "8103347343" <>7347947685@chicago.voip.ms>;tag=9ADEFD8-24AE
To: <1000>
Call-ID:
BC34657F-94E211E2-86A79EE5-25EAD9CA@10.0.16.1
Min-SE:  1800
Cisco-Guid: 3157470359-2497843682-2258738917-0636148170
CSeq: 101 INVITE
Timestamp: 1364257631
Expires: 180
Max-Forwards: 69
Cisco-Gcid: BC332C97-94E2-11E2-86A4-9EE525EAD9CA
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 8226 4091 IN IP4 10.0.16.1
s=SIP Call
c=IN IP4 10.0.16.1
t=0 0
m=audio 19260 RTP/AVP 0 101
c=IN IP4 10.0.16.1
a=fmtp:101 0-16
a=ptime:20
Mar 26 00:27:11.564: //3359/BC332C9786A1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <7347947685>
Call-ID:
:5060
CSeq: 102 INVITE
Content-Length: 0
Mar 26 00:27:11.568: //3360/BC332C9786A1/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "8103347343"<>7347947685@chicago.voip.ms>;tag=9ADEFD8-24AE
TO: <1000>
CSEQ: 101 INVITE
CALL-ID:
VIA: SIP/2.0/TCP 10.0.16.1:5060;branch=z9hG4bK144C387
CONTENT-LENGTH: 0
TIMESTAMP: 1364257631
Mar 26 00:27:11.624: //3360/BC332C9786A1/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
TO: <1000>;tag=a2142d2b64;epid=52D6175B32
CSEQ: 101 INVITE
CALL-ID:
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Received:
SIP/2.0 200 OK
CSEQ: 101 INVITE
CALL-ID:
CONTENT-LENGTH: 264
PRIORITY: Normal
SUPPORTED: Replaces
SUPPORTED: timer
SUPPORTED: 100rel
ALLOW: ACK
Content-ID: 506349a4-0ba4-49e6-8f51-929604882f09
Min-SE: 1800
v=0
o=- 23 0 IN IP4 10.0.0.5
s=session
c=IN IP4 10.0.0.5
b=CT:10000000
t=0 0
m=audio 9186 RTP/AVP 0 101
c=IN IP4 10.0.0.5
a=rtcp:9187
a=label:main-audio
a=sendrecv
a=fmtp:101 0-16,36
a=ptime:20
Mar 26 00:27:11.628: //3360/BC332C9786A1/SIP/Call/sipSPICallInfo:
Mar 26 00:27:11.628: //3360/BC332C9786A1/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 19260
Destn  IP Port    (Media): 9186
Mar 26 00:27:11.628: //3360/BC332C9786A1/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 10.0.16.1:5060;branch=z9hG4bK144D1C3F
To: <1000>;tag=a2142d2b64
Call-ID:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 26 00:27:11.632: //3359/BC332C9786A1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <7347947685>;tag=9ADF01C-10F0
Call-ID:
:5060
CSeq: 102 INVITE
Content-Length: 0
Mar 26 00:27:11.636: //3359/BC332C9786A1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Call-ID:
:5060
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 9252 4256 IN IP4 10.0.16.1
s=SIP Call
c=IN IP4 10.0.16.1
t=0 0
m=audio 17084 RTP/AVP 0 101
c=IN IP4 10.0.16.1
a=fmtp:101 0-36
a=ptime:20
Mar 26 00:27:11.660: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 173.208.83.50:5060;branch=z9hG4bK4c8bba54;rport
Max-Forwards: 70
Call-ID:
:5060
CSeq: 102 ACK
User-Agent: voip.ms
Content-Length: 0
Mar 26 00:27:11.660: //3359/BC332C9786A1/SIP/Call/sipSPICallInfo:
Mar 26 00:27:11.660: //3359/BC332C9786A1/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 17084
Destn  IP Port    (Media): 19950
USRMIHQ#show voip rtp connections
VoIP RTP active connections :
No. CallId     dstCallId  LocalRTP RmtRTP     LocalIP                                RemoteIP
1     3359       3360       17084    19950    10.0.16.1                              173.208.83.50
2     3360       3359       19260    9186     10.0.16.1                              10.0.0.5
Found 2 active RTP connections
USRMIHQ#
Mar 26 00:27:42.669: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
TO: <>7347947685@chicago.voip.ms>;tag=9ADEFD8-24AE
CSEQ: 1 BYE
CALL-ID:
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP 10.0.0.5:5065;branch=z9hG4bK94b3d1cf
CONTENT-LENGTH: 0
PRIORITY: Normal
SUPPORTED: Replaces
Mar 26 00:27:42.673: //3360/BC332C9786A1/SIP/Call/sipSPICallInfo:
Mar 26 00:27:42.673: //3360/BC332C9786A1/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Mar 26 00:27:42.673: //3359/BC332C9786A1/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK144E1EBD
To: "8103347343" <8103347343>;tag=as060ca0b0
Call-ID:
:5060
Max-Forwards: 70
Timestamp: 1364257662
CSeq: 101 BYE
P-RTP-Stat: PS=1510,OS=241472,PR=29,OR=4640,PL=0,JI=0,LA=0,DU=31
Content-Length: 0
Mar 26 00:27:42.673: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 10.0.0.5:5065;branch=z9hG4bK94b3d1cf
To: "8103347343" <>7347947685@chicago.voip.ms>;tag=9ADEFD8-24AE
Date: Tue, 26 Mar 2013 00:27:42 GMT
Call-ID:
CSeq: 1 BYE
P-RTP-Stat: PS=29,OS=4640,PR=1512,OR=241648,PL=0,JI=0,LA=0,DU=31
Content-Length: 0
Mar 26 00:27:42.701: //3359/BC332C9786A1/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.0.16.1:5060;branch=z9hG4bK144E1EBD;received=10.0.16.1;rport=54109
Call-ID:
:5060
CSeq: 101 BYE
Server: voip.ms
Content-Length: 0
Mar 26 00:27:42.705: //3359/BC332C9786A1/SIP/Call/sipSPICallInfo:
Mar 26 00:27:42.705: //3359/BC332C9786A1/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
What I can see from these debugs is that when the router responds to the SIP provider to accept the call, it is telling the sip provider to route the media to the IP address of 10.0.16.1. I am assuming that the sip provider can't route to this address. See the below 200ok message where this address is sent.
Sent:
SIP/2.0 200 OK
Call-ID:
:5060
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 238
v=0
s=SIP Call
c=IN IP4 10.0.16.1
t=0 0
c=IN IP4 10.0.16.1
a=fmtp:101 0-36
a=ptime:20
My guess is that this behaviour is related to your bind commands, is the previous config accurate with regards to what bind commands are in place when this call was placed?
I had another quick look at your config and this issue is definitely related to your bind command. You are binding both you signalling and media to source interface gi0/1.16. You will need to remove the bind commands and work out why your ip phones stop working after these commands are removed.
Can you remove these commands and try your external call again and post the debugs?
Once this is confirmed as working we can look at the call flow for your internal ip phones trying to get to the exchange um. Post a separate debug for this call flow and we can investigate why it doesn't work without the bind commands.
Removed. Here is the debug:
just dead air, and then busy signal.... calling in,
USRMIHQ#
Mar 27 00:23:29.857: //58/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 75.151.8.65:5060;branch=z9hG4bK3F961
To:
Date: Wed, 27 Mar 2013 00:23:29 GMT
Call-ID: 6278DCB2-95AB11E2-80789170-7B952484@75.151.8.65
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <75.151.8.65:5060>
Content-Length: 0
Mar 27 00:23:29.881: //58/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 75.151.8.65:5060;branch=z9hG4bK3F961;received=75.151.8.65;rport=58124
To: ;tag=as5ae05659
CSeq: 101 OPTIONS
Server: voip.ms
Content-Length: 0
This traces doesn't actually show any call information. It is as if the call never reached the router. The trace shows an OPTIONS ping sent to the provider and that is all.
Can you check that your SIP trunk is still registered to the provider? You can use "show sip-ua register status" to find this out.
Thanks Daniel so much for your help. I will try, but can I ask that I would be glad to pay you to look at this router, as the waiting between messages and any resolution is down right crazy.
I have teamviewer and serial from that system to router. Also, I tried seeking out help on odesk and elance, but you seem to have more knoledge about sip-sip, as many are familiar with PRI or T1.
Let me know, or private message me. I know folks are busy, but we really could appreciate the help for our non-profit.
I can give access to our voip.ms account, and our router, and exchange
After lots and lots of trial and error the adjustments I had made:
realm was changed to chicago.voip.ms instead of voip.ms
removed session transport tcp from sip
removed call start slow under h323
removed ONE bind statement, I assume that since I have Exchange AA on our native VLAN, it was able to pass media through any gateway.
the bind statement I removed was:  bind media source-interface GigabitEthernet0/1.16
voice translation-rule 2 was corrected:
rule 1 /.*/ //
authentication username 141349 password 7 12350C03060xxxx was corrected:
authentication username 141349 password 7 12350C03060xxxx realm chicago.voip.ms
host registrar was added to end of sip-ua
Also on ephone 1 I included no-reg statement.
I also adjusted times to 200 instead of 3600, as I noticed drops of registration.
Also seems to work now. I get incoming and outgoing.
good evening Frederick
I hope you are well,
I thing I have a similarly case, I have I small IP Phone network with (Router 2900, Switch Catalyst 3750, 5 Cisco IP Phones 7945G), I had configure my CCME it’s working and able do calls but just inside the network, now I checking out for a code allow me an outside call, I find out your code and I want to use It but there are some commands that I didn’t understand:
rule 1 /9602+/ /602/
rule 2 /9480+/ /480/
rule 3 /9623+/ /623/
voice translation-rule 4
rule 1 /91+/ /1/
voice translation-rule 5
rule 1 /9011+/ /011/
voice translation-rule 7
rule 1 /1005/ /16025551313/
rule 2 /1006/ /16025551212/
voice translation-rule 5551212
rule 1 /16025551212/ /1006/
rule 2 /16025551313/ /1005/
voice translation-profile Caller-ID
translate calling 7
voice translation-profile INCOMING
translate called 5551212
voice translation-profile International
translate calling 7
translate called 5
voice translation-profile Local10
translate calling 7
translate called 2
voice translation-profile LongDistance
translate calling 7
translate called 4
What are the roles of all those Translation;
dial-peer cor custom
name Business2_10Digit
name Business2_11Digit
name Business1_10Digit
name Business1_11Digit
dial-peer cor list Business2-Line
member Business2_10Digit
member Business2_11Digit
dial-peer cor list Business2-11Digit
dial-peer cor list Business1-11Digit
member Business1_11Digit
dial-peer cor list Business1-Line
member Business1_10Digit
dial-peer cor list Business2-10Digit
dial-peer voice 2000 voip
destination-pattern 2…
session protocol sipv2
session target ipv4:172.30.100.12
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 10 voip
corlist outgoing Business1-11Digit
description Business1 11-Digit Outgoing
translation-profile outgoing LongDistance
destination-pattern 91……….
session target ipv4:losangeles.voip.ms
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 11 voip
corlist outgoing Business1-10Digit
translation-profile outgoing Local10
destination-pattern 9[^1]..[2-9]……
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 12 voip
translation-profile outgoing International
destination-pattern 9011T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 13 voip
destination-pattern *97
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 30 voip
corlist outgoing Business2-11Digit
session target dns:chicago-1a.vtnoc.net
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 31 voip
corlist outgoing Business2-10Digit
translation-profile incoming INCOMING
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
What are the roles of all those dial-peer
Cordiality
