Hi All, i have to build a new cluster from scratch could someone please share the steps or documents and
I thought at one time there was a community here where you could post jobs where you needed engineers but I cant seem to locate it. Was I dreaming or has it been moved elsewhere?
Hi all, I have my two cucm 1 pub and 1 sub, each on different sites, because of bandwidth limitation, i want my phone that is in the same site as the pub register to the pub , and all the phones that are in the same site as the sub register to the su...
Hi Everybody I am new to this Cisco voice architecture and in need of basic config steps/guide to configure isr4331 as an voice gateway for connecting analog extensions in the FXS card.The Isr 4331 will be connected to CUCM 11.5.I am confused on the ...
HelloI have installed SEPMAC.cnf.xml using the TFTP server, also installed AppDialRules.xml, dialplan.xml, ITL, CTL.When I tried to register to my asterisk server, it says, 802.x1 authentication timeoutAlso, I can see the VPN option but it disabled ...
Hi,I have implemented many times an Expressway C&E solution where the Expressway-E has one interfaceNow we want to implement an Expressway-E with two interfaces.On the Expressway-C we have as the peer address the FQDN of the Expressway-E pointing to ...
I'm currently looking into some calls trying to figure which part hung up - the caller or the call recipient. I found 2 unusual examples and I'm not sure how to interpret them. I've read some threads here and they suggested that code 1 CctiLine indic...
Hello, I am confused by all of the licensing for CUCM, I would like to purchase CUCM 11x license for 5 users and would like to know what is the difference between the following: enhanced licensepermanent licensebasic license
We have a user with 2 lines on their Cisco 8841 phone, occasionally after a call has ended on the second line it is still showing the call as active on the line and next to the callers name it says Remote. This is not a huge problem just curious as ...
Hi, i'm setting up a Cisco 7861 but i have a problem with recall.When i call a number from history with redial or looking in the recent call and redial from there, the number is done with the first number removed.Do you have any idea of where the pro...
Hoping for some help. We are a new office with CP-8851 phones. These were installed by a 3rd party contractor and we have no information on how the system was set up or which options are available to us.Several stations share lines (e.g. operations, ...
Good day Gurus, Its amazing i ask so many questions here i wish i could get more response...I have a site that needs each end user to be entering a PIN when calling Jaime Valencia has a nice link where Cisco explains how it is done?I want to see a si...
Hi,Can I use Cisco IP Communicator 12.x with CUCM system version 11.5.1.14900-11.Anything else that I need to worry about?Thanks!
I have received complaints that certain phone numbers give you a fast busy when you dial them. Most calls have no issue. I have attached the call output from the SIP Cube of a calls that complete & a couple that doesn't. Any advice would be apprec...
So I have a 4321 router configured with CME version 10.5. I currently have eight DTD-8841-02 sip phones registered under voice register global. I’m having trouble figuring out how to setup Meetme conferencing for voice register global. Online I can o...
| Subject | Author | Posted |
| 03-04-2026 06:20 AM | ||
| 03-02-2026 07:40 AM | ||
| 03-02-2026 07:34 AM | ||
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM |
