[CME 9.1] Ip phone 3905 fails to send DTMF tones to external network.
asergeyev
Hi all!
We have three kinds of SIP phones in our CME 9.1: 3905, 6941 and 8941. All phones except 3905 send DTMF tones successfully via our operator. Here is "debug voice ccapi detail" when extension "206" (ip phone 3905) calls to external phone 93274343 and tries to send digits. Config is in attach. Also some part of config here:
voice service voip
ip address trusted list
  ipv4 10.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  registrar server expires max 120 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice register global
mode cme
source-address 10.10.0.41 port 5060
timeouts interdigit 3
max-dn 100
max-pool 80
load 8961 sip8961.9-2-2SR1-9
authenticate register
authenticate realm defagroup.com
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0001013651736503
Hi all!
We have three kinds of SIP phones in our CME 9.1:  3905, 6941 and 8941. All phones except 3905 send DTMF tones successfully  via our operator. Here is "debug voice ccapi detail" when extension  "206" calls to external phone 93274343 and tries to send digits. Config  is in attach. Also some part of config here:
voice service voip
  ipv4 10.0.0.0
h323
sip
voice class codec 1
mode cme
max-dn 100
max-pool 80
time-format 24
date-format D/M/Y
tftp-path flash:
voice register dn  6
number 204
call-forward b2bua noan 201 timeout 20
voice register template  1
feature-button 1 Redial
feature-button 2 Cfwdall
feature-button 3 Hold
feature-button 5 Trnsfer
feature-button 6 DnD
voice register dialplan 1
type 7940-7960-others
pattern 1 ...
pattern 2 9810*
pattern 3 9.......
pattern 4 98..........
voice register pool  8
id mac 64D8.14A5.01B4
type 3905
number 1 dn 8
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
username 206 password 206
no vad
dial-peer voice 1 pots
translation-profile outgoing to-city
destination-pattern 9T
port 0/0/0:15
The "debug voice ccapi detail" is here:
telephony#
*Dec 27 16:45:22.095: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   Call Entry Is Not Found
*Dec 27 16:45:22.095: //817/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Dec 27 16:45:22.095: //-1/xxxxxxxxxxxx/CCAPI/cc_api_update_interface_cac_resource:
   Hwidb=GigabitEthernet0/0, Bandwidth=80, Call Id=817
   Total Call Count=0, Voip Call Count=0, MMoip Call Count=0x0, Bandwidth=80
*Dec 27 16:45:22.095: //-1/A3B9036582FD/CCAPI/cc_api_call_setup_ind_common:
   Interface Type=0, Protocol=3
*Dec 27 16:45:22.095: //-1/A3B9036582FD/CCAPI/ccCheckClipClir:
   Calling Party Number Is User Provided
   After Number Translation Checking:
   Calling Number=206(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3(TON=Unknown, NPI=Unknown)
*Dec 27 16:45:22.095: //817/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=1
*Dec 27 16:45:22.095: //817/A3B9036582FD/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=817
*Dec 27 16:45:22.095: //817/A3B9036582FD/CCAPI/cc_incr_if_call_volume:
   Remote IP Address=10.10.0.126, Hwidb=GigabitEthernet0/0
telephony#
   Total Call Count=1, Voip Call Count=1, MMoip Call Count=0
*Dec 27 16:45:22.099: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   Matching Parameters; Called Number=3, Call Transfer Consult Id=
   No Matching Node
*Dec 27 16:45:22.099: //817/A3B9036582FD/CCAPI/cc_api_set_transfer_info:
   Call Transfer Reset
*Dec 27 16:45:22.443: //817/A3B9036582FD/CCAPI/ccCallDisconnect:
   Start Calling Accounting;
   Call Entry(Incoming=TRUE)
   Cause Value=28, Call Entry(Disconnect Cause=0)
*Dec 27 16:45:22.443: //817/A3B9036582FD/CCAPI/cc_api_update_interface_cac_resource:
   Hwidb=GigabitEthernet0/0, Bandwidth=-80, Call Id=817
   Total Call Count=1, Voip Call Count=1, MMoip Call Count=0x0, Bandwidth=0
*Dec 27 16:45:22.559: //817/A3B9036582FD/CCAPI/cc_decr_if_call_volume:
*Dec 27 16:45:22.559: //817/A3B9036582FD/CCAPI/cc_delete_guid_pod_entry:
   Incoming=TRUE
*Dec 27 16:45:22.559: //817/A3B9036582FD/CCAPI/cc_delete_call_entry:
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=0
   Deleting profileTable[0x336F00D4]
*Dec 27 16:45:22.559: //817/A3B9036582FD/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x2, Call Id=817
   Flag=FALSE
*Dec 27 16:45:22.559: //817/A3B9036582FD/CCAPI/ccCallSetVoipFlag:
telephony#Flag=FALSE, Data Bitmask=0x2, Call Id=817
   Call Entry(Voip AAA Flags=0x0)
*Dec 27 16:45:22.559: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
telephony#
*Dec 27 16:45:28.995: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Dec 27 16:45:28.995: //818/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Dec 27 16:45:28.995: //-1/xxxxxxxxxxxx/CCAPI/cc_api_update_interface_cac_resource:
   Hwidb=GigabitEthernet0/0, Bandwidth=80, Call Id=818
*Dec 27 16:45:28.995: //-1/A7D5DC978303/CCAPI/cc_api_call_setup_ind_common:
*Dec 27 16:45:28.995: //-1/A7D5DC978303/CCAPI/ccCheckClipClir:
   Called Number=9(TON=Unknown, NPI=Unknown)
*Dec 27 16:45:28.995: //818/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=1
*Dec 27 16:45:28.995: //818/A7D5DC978303/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=818
*Dec 27 16:45:28.999: //818/A7D5DC978303/CCAPI/cc_incr_if_call_volume:
telephony#
*Dec 27 16:45:28.999: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   Matching Parameters; Called Number=9, Call Transfer Consult Id=
   No Matching Node
*Dec 27 16:45:28.999: //818/A7D5DC978303/CCAPI/cc_api_set_transfer_info:
   Call Transfer Reset
telephony#
*Dec 27 16:45:34.827: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
   VALIDATING MLPP INFO:- ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]
*Dec 27 16:45:34.827: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
   Precedence not above Routine
*Dec 27 16:45:34.827: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
   BEFORE COPY - SRC MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]
   DEST  MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]
     AFTER COPY - SRC MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]   DEST MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)]
   VALIDATING MLPP INFO:- ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)]
*Dec 27 16:45:34.827: //818/A7D5DC978303/CCAPI/ccCheckClipClir:
*Dec 27 16:45:34.827: //819/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
*Dec 27 16:45:34.827: //818/A7D5DC978303/CCAPI/cc_peer_bind:
   Bind=TRUE, Binder Call Id=818, Bindee Call Id=819
*Dec 27 16:45:34.827: //819/A7D5DC978303/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=819
telephony#
*Dec 27 16:45:34.827: //819/A7D5DC978303/CCAPI/cc_set_voice_port_value:
   CC_IF_TELEPHONY: Echo=0, Playout=0
*Dec 27 16:45:34.831: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Dec 27 16:45:34.831: //818/A7D5DC978303/CCAPI/ccCallGetContext:
   Context=0x33C6F520, Call Id=818
*Dec 27 16:45:34.831: //-1/xxxxxxxxxxxx/CCAPI/cc_set_outpulsed_digits:
   outpulsed_dialstring=3274343 set
*Dec 27 16:45:35.399: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Dec 27 16:45:35.403: //818/A7D5DC978303/CCAPI/cc_peer_bind:
telephony#Bind=TRUE, Binder Call Id=818, Bindee Call Id=819
*Dec 27 16:45:35.559: //818/A7D5DC978303/CCAPI/cc_peer_bind:
telephony#
*Dec 27 16:45:45.199: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0:14, changed state to up
telephony#
*Dec 27 16:46:02.215: //818/A7D5DC978303/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Disconnect Cause=16)
*Dec 27 16:46:02.215: //819/A7D5DC978303/CCAPI/ccCallDisconnect:
   Call Entry(Incoming=FALSE)
   Cause Value=16, Call Entry(Disconnect Cause=0)
*Dec 27 16:46:02.215: //818/A7D5DC978303/CCAPI/cc_api_update_interface_cac_resource:
   Hwidb=GigabitEthernet0/0, Bandwidth=-80, Call Id=818
*Dec 27 16:46:02.227: //-1/A7D5DC978303/CCAPI/g113_calculate_impairment:
   (delay=79(ms), loss=0%), Io=0 Iq=0 Idte=0 Idd=2 Ie=-1 Itot=1
*Dec 27 16:46:02.227: //818/A7D5DC978303/CCAPI/cc_decr_if_call_volume:
*Dec 27 16:46:02.227: //818/A7D5DC978303/CCAPI/cc_delete_guid_pod_entry:
   Incoming=TRUE
*Dec 27 16:46:02.227: //818/A7D5DC978303/CCAPI/cc_delete_call_entry:
   Total Call Count=0
   Deleting profileTable[0x336EFA6C]
*Dec 27 16:46:02.227: //818/A7D5DC978303/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x2, Call Id=818
   Flag=FALSE
*Dec 27 16:46:02.227: //818/A7D5DC978303/CCAPI/ccCallSetVoipFlag:
telephony#Flag=FALSE, Data Bitmask=0x2, Call Id=818
*Dec 27 16:46:02.227: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Dec 27 16:46:02.275: //819/A7D5DC978303/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
*Dec 27 16:46:02.275: //819/A7D5DC978303/CCAPI/cc_delete_call_entry:
   Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
   Deleting profileTable[0x336E75C4]
*Dec 27 16:46:02.275: //819/A7D5DC978303/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x2, Call Id=819
   Flag=FALSE
*Dec 27 16:46:02.275: //819/A7D5DC978303/CCAPI/ccCallSetVoipFlag:
   Flag=FALSE, Data Bitmask=0x2, Call Id=819
*Dec 27 16:46:02.275: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
telephony#unde all
Version of CME is 9.1
Version of IOS is 15.3(1)T (also tested in 15.2 - the same issue)
All ip phones have the latest firware (9-2-2-0), also I have already downgraded some of them (9-2-1-0)  - the issue persists.
Jorge Armijo
Level 4
Level 4
I think that the best is to capture a sniffer trace on the phone directly, we will be able to see if the phone itself is sending the digits.
You can also enable some debugs:
deb voice ccapi inout
deb ccsip messages
deb ccsip media
That should be enough to isolate the problem
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Jorge Armijo
Level 4
Level 4
deb ccsip messages
deb ccsip media
Jorge Armijo
Hi!
Thanks for pointing me to ther right debugs. There I noteced, that on Cisco IP phone 3905 kpml need to be implemented, not rtp-nte.
Here is a debug that revealed this issue
Hey,
Great to hear that you were able to fix the problem, I'll be checking the logs!
And thanks for the rating!
Jorge Armijo
We had the same issue with our 3905 and the dtmf-relay sip-kpml worked fine after a reset.
Thank you for the info.
Gabriel D.
