04-30-2014 07:59 AM - edited 03-16-2019 10:38 PM
Hi everyone,
I am currently working on a Cisco 2911 running 15.2(4)M5, which is version 9.1 of CME. I am having a problem making outbound calls from the 9971 phone that I have registered. When I dial, the phone just sits there and eventually times out with a fast busy after a few minutes. I currently have the "video" and "camera" commands configured under "voice register global" and "voice register pool" to enable video on the phone.
I have found that when those two commands are removed, I am able to make outbound calls from the phone. I am wondering if this is a bug in the version of CME I am running or if it is simply a configuration error on my part somewhere.
For your reference, here is a configuration snippet:
mode cme
source-address 10.8.88.253 port 5060
max-dn 20
max-pool 10
authenticate register
timezone 8
url authentication http://10.8.88.253/CCMCIP/authenticate.asp
tftp-path flash:
create profile sync 0014032233425515
ntp-server 67.217.112.181 mode directedbroadcast
camera
video
voice register dn 5
number 7005
name Office_5
label Line 1 - 7005
voice register pool 5
id mac 1C1D.86C5.42E3
type 9971
number 1 dn 5
dtmf-relay sip-notify
username cisco password cisco
codec g711ulaw
camera
video
Solved! Go to Solution.
04-30-2014 11:53 AM
Hi Brian,
Any other thoughts on this? I'd really like to figure out what's going on. Do you think it's a bug? Mind doing an internal search for me?
Thanks for your help!
05-01-2014 07:44 AM
It definitely sounds like a bug to me. I no longer have access to internal tools but did an external search for you.
It looks like you're hitting CSCty61190
That is just a duplicate of CSCtt38880 (https://tools.cisco.com/bugsearch/bug/CSCty61190)- IOS gateway not handling fragmented SIP UDP message properly
So it looks like the problem is due to the extra video SDP information causing the packet to be big enough to get fragmented and IOS not handling the fragmented message appropriately.
05-01-2014 09:04 AM
The keyword being FRAGMENTED message. Right now I am actually running these phones through a dot1q tunnel and neglected to set the MTU correctly on one of the switches that is processing the frames. Once I set the MTU to a number at or above 1504, I can now make calls.
Thank you for your help with this Brian! I appreciate your efforts.
04-30-2014 09:56 AM
I think CME may not be accepting the call due to no video bandwidth configured.
Try this:
mode cme
bandwidth video tias-modifier 512000 negotiate end-to-end
04-30-2014 10:09 AM
Hi Brian,
That sounded promising, but it didn't seem to like that either. I went into "voice register global", entered the "bandwidth video" command as stated above, did a "create profile", reset the voice register pool, and still got the same result.
04-30-2014 08:30 AM
By the way, I can make a successful call if it originates from the SCCP phone. So we know that the SIP phone can successfully receive calls, it just cannot place them at this point.
