CME and CUE
travis-dennis_2
Level 7
Level 7
I have a 3825 running CME 8.6 and an AIM-CUE module.     Can I get confirmation that the AIM-CUE module can only go up to 7.4(1) and not into the CUE 8.x releases?  The compatibility matrix seems to indicate this.  Just want to make sure that it is up to date.
Thanks in advance.  Replies rated.
Harmit Singh
Hi Travis,
Yes, that is correct. Compatibility matrix is up to date for the same. AIM2-CUE would support version 8.x.
Harmit.
Harmit Singh
Hi Travis,
Harmit.
Harmit Singh
Additionally, kindly refer to the release notes for CUE 8.0:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_0/rel_notes/rel_notes.html
If your system is using an AIM-CUE module, you  must upgrade to the AIM2-CUE module before upgrading the software to  Cisco Unity Express 8.0.x.
HTH.
Harmit.
Check out this great doc with compatibility info:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
HTH,
Chris
