CME and Voip Access list to prevent tool fraud question
etmarcof
Level 3
Level 3
I have CME and internet access on same 2821 IOS 12.4.24T1. So i have configured following ACL in dialer 0 interface.
access-list 102 remark +++ Block IN Internet VOIP Traffic +++
access-list 102 deny tcp any host X.X.X.X eq 5060
access-list 102 deny udp any host X.X.X.X eq 5060
access-list 102 deny tcp any host X.X.X.X eq 5061
access-list 102 deny udp any host X.X.X.X eq 5061
access-list 102 deny tcp any host X.X.X.X eq 1720
access-list 102 deny tcp any host X.X.X.X eq 1719
access-list 102 deny tcp any host X.X.X.X eq 1718
access-list 102 deny tcp any host X.X.X.X eq 2000
access-list 102 deny udp any host X.X.X.X eq 2000
access-list 102 deny udp any any eq snmp
access-list 102 deny udp any any eq snmptrap
access-list 102 permit ip any any
Where X.X.X.X is the public ip address of my internet connection.
When i telnet to this ip address in port 5060 (or 5061,or 2000,or 1718,or 1719) for exemple connection is refused but when i do a telnet for 1720 i receive a black screen so connection is accepted.
Any ideas why this is happenning or what i have to configure more?
Best Regards
MC
For what it's worth, this is my template which matches pretty close:
access-list 101 remark **** SIP CUSTOMERS ****
access-list 101 permit udp host x.x.x.x any eq 5060
access-list 101 permit tcp host x.x.x.x any eq 5060
access-list 101 remark **** H323 CUSTOMERS ****
access-list 101 permit udp host x.x.x.x any eq 1720
access-list 101 permit udp host x.x.x.x any eq 1719
access-list 101 permit udp host x.x.x.x any eq 1718
access-list 101 permit tcp host x.x.x.x any eq 1720
access-list 101 permit tcp host x.x.x.x any eq 1719
access-list 101 permit tcp host x.x.x.x any eq 1718
access-list 101 remote **** DENY ALL ELSE ****
access-list 101 deny udp any any eq 1720
access-list 101 deny udp any any eq 1719
access-list 101 deny udp any any eq 1718
access-list 101 deny tcp any any eq 1720
access-list 101 deny tcp any any eq 1719
access-list 101 deny tcp any any eq 1718
access-list 101 deny udp any any eq 5060
access-list 101 deny tcp any any eq 5060
access-list 101 remark **** NOW PERMIT ALL ****
access-list 101 permit ip any any
I don't see any reason why you should be able to telnet to 1720. Are you sure it's not just a black screen that isn't connecting?
-nick
Hi Nick,
For the other ports i get refused connection when i try to telnet using that ports but for port 1720 like i said appears a black screen, how could i check in router if session is established?
Best Regards
MC
You can try 'show tcp brief' to see if there is a session open. 'show tcp detail' may also be helpful.
-nick
