CME Auto Attendent
adnanhassan1
I have uploaded new greetings in CME and I have also deleted the old greetings from flash but surprisingly the system is still playing the old greetings which is really strange.
Has anyone come across this issue before and therefore in a position to guide me as to how I can resolve this issue?
Adnan
Correct Adnan,
a tar file is a compressed file not an audio one.
The new prompt should be .au and with 8000 khz 16 bit and mono and ulaw wave format.
Upload it in the correct format and old should work
Carlo
Please rate all helpful posts "The more you help the more you learn"
8 Replies 8
Hi Adnan,
Have you issued "audio-prompt load <audio filename> " to load the new prompt on gateway's memory?
Please let me know
Carlo
Hi Carlo,
Thanks for your reply.
Is there any command I can look and delete existing prompt load? Because I have tried "audio-prompt load" already but didn't work.
Adnan
Please rename the old prompt file ad rename the new one with the original old prompt name and issue again the audo-prompt command.
If you can, please post the application part of your gateway configuration.
Carlo
Hi Carlo, sorry for asking silly question, what is the command to rename file? Can you please message step by step procedure or some guide link?
Adnan
Hi Adnan,
let's assume that the file name of old prompt on your flash is welcome.au and the new file is newprompt.au.
On your gateway do what follows:
Router#rename flash:welcome.au flash:Old-welcome.au
Router#rename flash:newprompt.au flash:welcome.au
Router#audio-prompt load flash:welcome.au
Let me know
Carlo
Hi Carlo, that doesn't work may be I am uploading wrong file extension (.tar) in flash.
1: I have recorded new prompt with ulaw/8000bits/mono and saved
2: uploaded .tar
    Router# archive tar /xtract tftp://<TFTP IP>/newprompt-x.x.x.tar flash:
Please correct me if this newprompt should be in ".au" and not in ".tar"
Adnan
Correct Adnan,
Carlo
Thank you so much Carlo, you are star
it's works this time :-)
