CME cnf-files for 6921 - How do I obtain these?
Joshua Engels
Hey guys,
I am setting up my first lab.  Im starting with CME and the issue I am running into is that I seem to be missing the configuration files for my test phones which are 6921's.  I can see in the TFTP log that the phone is looking for the following files but not sure what my next step is.
XMLDefault.cnf.xml
SEP44D3A253572.cnf.xml
CTLSEP44D3A253572.tlv
Thanks for your help!
-Josh
Joshua Engels
also, here is my config:
site-A#sho run
Building configuration...
Current configuration : 1839 bytes
! Last configuration change at 08:06:11 UTC Mon Nov 12 2012
version 15.1
hostname site-A
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp pool LAN
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   option 150 ip 10.10.10.1
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FTX1242A1WV
interface Loopback0
no ip address
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
interface Async0/1/0
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
control-plane
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp profile default
telephony-service
no auto-reg-ephone
max-ephones 20
max-dn 20
system message ENGELS ENTERPRISES
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Nov 11 2012 17:00:11
ephone-dn  1  dual-line
number 2222
description Mr. Engels
ephone-dn  2  dual-line
number 2223
description Nelda Rodriguez
ephone  1
mac-address 44D3.CA25.3572
max-calls-per-button 2
type 6921
button  1:1
ephone  2
mac-address 0007.7DDF.F0A0
button  1:2
line con 0
line aux 0
line 0/1/0
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
Joshua Engels
I figured it out!
I was missing once command:
"ip source-address 10.10.10.1"  under telephony-service.
Feel free to mark this answer as correct so this shows up as answered.
thanks everyone.
