CME config missing
uday kiran
Hi all,
I am trying to build a home lab with 2800 Series router and switch  3560. I have configured the router and switch but the the phone is not getting registered. I am not sure if I am missing any configuration.
I am using 7941 phone and I see the message (term41.default OK) and it stucks there.
Here is the router config
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.05.26 16:19:20 =~=~=~=~=~=~=~=~=~=~=~=
sjo      h run
Building configuration...
Current configuration : 2545 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone central -8
clock summer-time zone recurring
no network-clock-participate wic 3
dot11 syslog
ip source-route
--More--                           !
ip cef
ip dhcp excluded-address 192.168.10.1 192.168.10.9
ip dhcp excluded-address 192.168.20.1 192.168.20.9
ip dhcp pool VOICE_SCOPE
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   option 150 ip 192.168.100.3
ip dhcp pool DATA_SCOPE
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
no ipv6 cef
--More--                           !
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server expires max 3600 min 3600
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
--More--                           !
voice-card 0
archive
log config
  hidekeys
--More--                           controller T1 0/3/0
controller T1 0/3/1
interface GigabitEthernet0/0
no ip address
duplex full
speed auto
interface GigabitEthernet0/0.10
description router interface for voice vlan
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/0.20
description router interface for data vlan
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
--More--                           interface GigabitEthernet0/0.100
description administration
encapsulation dot1Q 100 native
ip address 192.168.100.2 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface Service-Engine1/0
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
--More--                           !
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
ccm-manager fax protocol cisco
mgcp fax t38 ecm
--More--                           !
telephony-service
em logout 0:0 0:0 0:0
max-ephones 5
max-dn 10
ip source-address 192.168.10.1 port 2000
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
number 1000
ephone  1
device-security-mode none
mac-address FCFB.FBCA.4B34
type 7941
button  1:1
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login
--More--                           scheduler allocate 20000 1000
end
Here are the 7941 files in flash
2494499 May 25 2013 19:25:32 apps41.8-3-2-27.sbn
42      547146 May 25 2013 19:26:18 cnu41.8-3-2-27.sbn
43     2452629 May 25 2013 19:26:50 cvm41sccp.8-3-2-27.sbn
44      530601 May 25 2013 19:28:22 dsp41.8-3-2-27.sbn
45      315827 May 25 2013 19:28:40 jar41sccp.8-3-2-27.sbn
46         638 May 25 2013 19:28:58 SCCP41.8-3-3S.loads
47         642 May 25 2013 19:29:12 term41.default.loads
48         642 May 25 2013 19:30:16 term61.default.loads
Here is the switch config
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.05.26 16:18:29 =~=~=~=~=~=~=~=~=~=~=~=
show run
Current configuration : 2170 bytes
! Last configuration change at 02:29:19 UTC Mon Mar 1 1993
version 15.0
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip routing
--More--                           !
spanning-tree mode pvst
vlan internal allocation policy ascending
--More--                           interface FastEthernet0/1
switchport trunk native vlan 20
switchport mode trunk
switchport voice vlan 10
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
--More--                            switchport mode trunk
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
--More--                           !
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
speed 100
duplex full
interface Vlan1
ip address 192.168.100.1 255.255.255.0
ip default-gateway 192.168.100.1
--More--                           ip http server
line con 0
line vty 5 15
end
Switch#
*Mar  1 02:38:10.929: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, changed state to down
*Mar  1 02:38:11.944: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to down
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
*Mar  1 02:38:14.796: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to up
Switch#
*Mar  1 02:38:16.826: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, changed state to up
Any help is much appreciated.. please
Jaime Valencia
The TFTP option from DHCP needs to be the same IP as CME
java
if this helps, please rate
Jaime Valencia
java
Thanks for the reply Jamie. I tried that but it is still not registering . Here is the configuration
Router#sh run
Current configuration : 2670 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
--More--                           !
ip cef
   option 150 ip 192.168.100.2
no ipv6 cef
--More--                           !
voice service voip
sip
  no update-callerid
voice class codec 1
--More--                           !
voice-card 0
archive
log config
  hidekeys
controller T1 0/3/1
no ip address
duplex full
speed auto
no ip address
duplex auto
speed auto
no ip address
shutdown
no ip http server
--More--                           !
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
mgcp fax t38 ecm
--More--                           !
telephony-service
max-ephones 5
max-dn 10
ephone-dn  1
number 1000
ephone  1
type 7941
button  1:1
--More--                           !
line con 0
line aux 0
line 66
no exec
transport input all
line vty 0 4
login
end
Router#        $
Router#
Router#
Router#
Router#
Switch>
Switch>
Switch>
Switch>
Switch>
Switch>
Switch>
Switch>
Switch>exi         rn
Translating "rn"...domain server (255.255.255.255)
% Unknown command or computer name, or unable to find computer address
Switch>e
% Ambiguous command:  "e"
Switch>
Switch>qq       en
Switch#show run
Current configuration : 2664 bytes
! Last configuration change at 00:18:10 UTC Mon Mar 1 1993
version 15.0
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
--More--                           !
--More--                           !
--More--                            switchport trunk native vlan 20
speed 100
duplex full
interface Vlan1
ip address 192.168.100.10 255.255.255.0
ip http server
line con 0
Hi Jamie,
Looks like I had issue with my phone and when I tried with another phone it worked..
Thanks a lot for your help.. You rock
