09-16-2016 03:08 PM - edited 03-17-2019 08:06 AM
Hi ,
I have C2901-CME-SRST/K9 and i need help to configure it to work with DX650, CP-8851, CP-8831, CP-7861 please.
09-16-2016 04:05 PM
You'll need to be more specific on what you need assistance with, have you already reviewed the CME configuration guide?? If not, that should be your first step.
09-16-2016 04:14 PM
I have done the cme configuration guide step but phone not register
09-16-2016 04:26 PM
What CME version? and what have you configured?
09-16-2016 04:31 PM
09-17-2016 08:32 AM
You are missing the following commands:
voice service voip
sip
bind all source g0/0.10
registrar server
Also, in your voice dhcp pool your default gateway is pointing to different IP which is 10.10.20.252. Not sure if this is intentional or typo mistake
09-28-2016 02:51 AM
09-28-2016 04:25 AM
I dont see any translation rules and profiles created on the CME to translate digits as the extensions are 3 digits. Can you lets us know the number of digits you are receiving from the provider on port 0/0/0?
Also, collect the following debugs for a test call:
debug ccsip messages
debug voice ccapi inout
debug voice vtsp all
Aseem
09-28-2016 04:57 PM
We receive 8 digit for local call without country indicator and 13 digit from all international call
09-28-2016 05:24 PM
Then you need to create translations to modify the 8 digit and 13 digits to match the extension length.
voice translation-rule 1
rule 1 /^.*\(...\)/ /\1/
Voice translation-profile PSTN
translate called 1
voice-port 0/0
Translation-profile incoming PSTN
Aseem
(Please rate if useful)
09-28-2016 11:18 PM
In my configuration, my extension is on 3 digit than 101, 102, etc ... and i would like that incoming call ring on extension 103 first and if no answer ring to another extension.
09-29-2016 12:57 AM
With all due respect, did you try to go through any of the documents to find out possible ways of doing it? I would request you to go through the guide below before coming with new queries.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmetrans.html
Aseem
