CME/CUE IP Change
mdaswani
I have a CME/CUE and had to change the IP address for both.  I also had to change the extension range I was using.
However, now I get strange behavior.  Whenever I click on the users the web page never shows the users - it just stays in loading mode.  I can fix this by re-entering the admin login/password but that only works for a day and the issue happens again.  Also, I noticed the old extensions keep coming back even after saves and reloads.
Any suggestions?
paolo bevilacqua
Update SW and you will be on the safe side with a fresh start.
