01-09-2013 08:15 AM - edited 03-16-2019 03:04 PM
CME with a request not to have to dial 9 for an outside line. The issue we are facing is that the Telco is sending 1212 down the PRI for a DID that we translate into a 3 digit DN. Since users do not have to dial 9 to get an outside line whenever they try to dial NYC at 1(212)xxx.xxxx the router sees 1212 and tries to send it back down to the DN.
Can anyone tell me a way to work aroud this? I tried to add a specific dial-peer for 1212 (perhaps I did it wrong) but that did not seem to help.
Thanks in advance. Replies rated.
01-09-2013 08:20 AM
Hi there,
Could you share the running config please? Also, please replicate the issue and capture "debug voip ccapi inout".
Harmit.
01-09-2013 08:33 AM
If you are doing the translation via translation rules which are applied to proper voice port or dial-peer you should not have any overlaps here. If you are using num-exp or dialplan pattern you will run into the issue you are describing. Please post full config as asked by Harmit.
HTH,
Chris
01-09-2013 10:37 AM
Thanks for ther responses,
The DN was actually for a MeetMe. As it turns out I still had a few of the 1212 existing as a secondary DN on the MeetMe ephones. Once I got rid of them call flow returned to normal.
Thanks for the replies!!
