06-16-2011 04:10 PM - edited 03-16-2019 05:30 AM
I m referring to this document (which doesnt seem to help me much)..so thought of posting at this forum....
Has any body successfully implemented FAC in CME..
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefac.html
i have setup two LPCor groups one for end users and one for PSTN trunks..to test this functionality i put one ephone under the end users group and another ephone in the PSTN trunk group..and when you call from ephone 1 to 2...it asks for the username and password as programmed but then it hangs up the call...
i can post configs if needed...its pretty similar to whats in the document..
TIA..
07-09-2012 11:52 AM
I am trying to acheive FAC on CME 9. But i have doubt to get below matrix
Local Call LD Call Intl Call
LOcal User --> NO FAC FAC FAC
LD Useer --> NO FAC No FAC FAC
Intl User ---> NO FAC NO FAC NO FAC
How can i acheive this in LPcor policy and single E1 with many dialpeer pot for outgoing.
07-19-2012 02:52 AM
hi saurabh_om,
We are facing the same delema, got a few tries doing this scenario and come up with the same result, if you are using a single E1 Pri/Bri that has all the outgoing function, lpcor is not the solution for now, unless cisco will fix it and rescript it in the new IOS version. Because that's the biggest problem of using lpcor, its like we need to block the whole E1 Pri dedicated for authentication calls and must have another E1 Pri using non-authentication calls. Sounds stupid and costly but we have to live with for now ^_^
If you want you can try using the "acctfixedpin.tcl" script, it runs on dial-peers and can be controlled by typical corlists. Though its unsupported tcl script by Cisco, but develop by a brilliant guy who seem to be knockout by LPCOR.. hahahah Goodluck ^_^
07-27-2012 07:03 AM
dennis,
I think you can achieve what you want by combining lpcor and cor.
Use cor to restrict which dial peers a line/phone can use.
for dial peers that require fac, point them to the trunk group with lpcor
for dial peers that don't require fac, point them to the voice-port itself instead of the trunk
I was able to achieve this using cor/lpcor for a customer that only required fac on ld/intl but also had fax machines that didn't need to use fac.
I don't have the config handy but it worked fine
07-29-2012 08:15 PM
Thank you for the quick reply, was able to try this configuration and I may be missing something out. ^_^ if you could provide additional assistance, it would be much appreciated. I will retry this again and will give feedback. Thanks.
07-29-2012 11:38 PM
Hello Dennis,
LPCOR and multiple auth code policy with single PRI line or POTS dial-peers. with Voice Dial-pper, yes you can play with policies.
I found an alternative is to create translation patterns and match PSTN numbers with voice dial-pper first and then looping number back to CME itself. Apply LPCOR policy on voice Dial-peer and take decision allow/restrict there itself.
Later make POTS dial-peer to reroute translated number to PSTN trunk.
Here is configuration :
Defines the name and number of LPCOR resource groups
voice lpcor custom
group 10 local LPCOR group for Local Calls
group 11 ld LPCOR group for Long Distance Calls
group 12 isd LPCOR group for International Calls
Creates a LPCOR policy for a resource group
voice lpcor policy local Service policy for local resource group
service fac Enable FAC Service for a routing endpoint
accept ld Accept calls from group without any FAC
accept isd
voice lpcor policy ld Service policy for long distance resource group
service fac
accept local fac Accept calls from group with a valid FAC
accept isd
voice lpcor policy isd Service policy for international resource group
service fac
accept local fac
accept ld fac
LPCOR for international numbers patterns:
voice translation-rule 2 Voice translation rule translating international number
rule 1 /^000/ /654000/
voice translation-profile add654
translate called 2
dial-peer voice 311 voip
description international
translation-profile outgoing add654
destination-pattern 000T
lpcor outgoing isd
session target ipv4:10.220.2.2
dtmf-relay h245-alphanumeric h245-signal
codec g711ulaw
dial-peer voice 312 voip
incoming called-number 654000T
codec g711ulaw
dial-peer voice 310 pots
description # Dial-Peer to Dial ISD Numbers #
destination-pattern 654000T
port 0/0/0:15
prefix 00
LPCOR for Long Distance numbers patterns:
trunk group PRI-ACCESS Define a trunk-group and associate an LPCOR policy
trunk group lpcor outgoing ld
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-5ess
isdn incoming-voice voice
isdn bchan-number-order ascending
trunk-group PRI-ACCESS Associate trunk-group to E1 PRI
no cdp enable
dial-peer voice 302 pots
trunkgroup PRI-ACCESS Associate trunk-group to longdistance dialpeer
description # Dial-Peer to Dial LD Mobile Numbers #
destination-pattern 00[7-9].........
forward-digits 11
*********** PLEASE RATE THE ANSWER IF YOU FIND IT HELPFUL *****************
07-30-2012 10:29 PM
The idea is very helpful and solved the configuration issue we encounter. We limit the configuration of the dial-peers and translation though by controlling it by cor-list (Pots - Outgoing to PSTN) per IP Phone access, much simplier to control and maintain ^_^
voice-port 0/0/0:15
description ***** ISDN PRI *****
no vad
timeouts interdigit 3
timeouts call-disconnect 3
timeouts wait-release 1
bearer-cap Speech
trunk group Cust01-E1
hunt-scheme least-idle
lpcor incoming Cust01ISDNTrunks
lpcor outgoing Cust01ISDNTrunks
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
trunk-group Cust01-E1 timeslots 1-31 preference 1
dial-peer voice 103 pots
corlist outgoing Cust01localcalls --> Cor List access to Local Calls
description ***** Outgoing POTS Call Leg from CME
destination-pattern 9[1-9]T
port 0/0/0:15 --> Local PSTN Access pointing to ISDN port.
dial-peer voice 100 pots
trunkgroup Cust01-E1 --> Local PSTN Access pointing to ISDN Trunkgroup
corlist outgoing Cust01IDDcalls --> Cor List access to IDD Calls
destination-pattern 9[0][0]T
forward-digits 11
prefix 00
Thank you,
Dennis
09-19-2012 03:16 PM
Hi everybody,
All of you guys have a realy helpful information here but I have not gotten it. I am still trying to configure the FAC feature. The issue is that system is not validating neither the username nor password, because I dial number I want to reach then I receive recordings user&passwd prompt, I put them right or even wrong and the call is stablished. I have been looking out a lot of information of how to configure FAC, searching information about this issue but I can find nothing.
Im deplying over a 3945E ios 15.1(4)M4. CME 8.6
I will be thankful if anyone has any advice
Sincerely,
Omar Cruz
09-19-2012 03:35 PM
Hello Omar,
Can you share running configuration of CME.
Saurabh
09-21-2012 11:17 AM
Saurabh,
thanks alot for your fast answer, but finally I could get it!!!! the issue was that I had 2 Dail Peers (DP) A and B. I was only requesting FAC for A. I had not seen that I kept B, so all the trafic was traveling through B. I took it out and right away it worked. : D
thanks for your attention though and have a great weekend!!!
11-09-2012 07:38 AM
Hey guys I know this might sound dumb but I need to confirm this issue
Can the forced authorization code support many usernames and passwords (username xxx password 0 1234)? Let's say I have 2 usernames : 1234 and 4321. Can I use both of them to authenticate the calls?
11-09-2012 08:44 AM
yes you can
11-12-2012 03:00 AM
Thanks hanky. Btw does anybody know how to include the FAC username/pin in the CDR?
@Omar, I'm using ios 15.2(4)M1 and CME version 9.1. I haven't tried restarting the router (as it is in production mode), but once I do, I will tell you the results
11-09-2012 11:45 AM
hi everybody,
I was implementing FAC on CME 8.6 with IOS 15.4M.3 all the functions are working good besides a little detail. I am facing with a command deleted called "trunk group lpcor outgoing
thanks in advance
01-23-2013 03:05 AM
I would like to know working IOS as well..
I have some odd behaviour with IOS 15.1(3)T3 (CME Version 8.5)
#sh voice lpcor policy
voice lpcor policy LP_2 (group 2)
service fac is enabled
( accept ) LP_2 (group 2)
( accept fac ) LP_3 (group 3)
voice lpcor policy LP_3 (group 3)
( accept fac ) LP_2 (group 2)
( accept ) LP_3 (group 3)
ephone 2
lpcor type local
lpcor incoming LP_2
lpcor outgoing LP_2
ephone 3
lpcor type local
lpcor incoming LP_3
lpcor outgoing LP_3
I'm trying to enable FAC between 2002 (ephone 2) and 2003 (ephone 3).
Call 2003->2002 works fine, FAC is required in order to place a call (Debug shows: Source LPCOR is LP_3, Target LPCOR is LP_2)
Call 2002->2003 does not require FAC (Debug show that used LPCORs: Source LPCOR is LP_2, Target LPCOR is LP_2) until I add
conf t
accept LP_2 fac
I still cannot figure out why on earth the same LP_2 is used as both Source and Target??
Config and logs are attached
12-07-2013 04:19 PM
Hi All
I'm trying to configure CME FAC also for customer requirement,
But still doesn't work. Any idea please?
my configuration
aaa new-model
aaa authentication login default local
aaa authentication login h323 local
aaa authorization exec default local
aaa authorization exec h323 local
aaa authorization network h323 local
trunk group TELKOM-E1
trunk group lpcor outgoing trunk
voice-card 0
voice lpcor enable
voice lpcor custom
group 10 user
group 11 trunk
voice lpcor policy user
service fac
accept user fac
accept trunk fac
voice lpcor policy trunk
service fac
accept user fac
accept trunk fac
application
package auth
param passwd-prompt flash:en_bacd_welcome.au --> should we put this file en_bacd_welcome.au to flash?
param abort-digit *
param user-prompt flash:en_bacd_enter_dest.au --> should we put this file en_bacd_welcome.au to flash?
param passwd 5555
param term-digit #
param max-digits 32
username 649 password 0 1258
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-30
trunk-group TELKOM-E1 timeslots 1-30
gw-accounting aaa
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn outgoing display-ie
no cdp enable
voice-port 0/0/0:15
dial-peer cor custom
name ALL
name LIMITED
dial-peer cor list ALL
member ALL
dial-peer cor list LIMITED
member LIMITED
dial-peer voice 1 pots
translation-profile incoming incoming
incoming called-number .
direct-inward-dial
dial-peer voice 15 pots
corlist outgoing ALL
translation-profile outgoing outgoing
destination-pattern 9T
port 0/0/0:15
dial-peer voice 16 pots
trunkgroup TELKOM-E1
lpcor outgoing trunk --> not yet configured, need this?
telephony-service
no auto-reg-ephone
max-ephones 100
max-dn 200
ip source-address 10.224.248.1 port 2000
system message CME
cnf-file location flash:
time-zone 40
date-format dd-mm-yy
max-conferences 8 gain -6
moh music-on-hold.au
multicast moh 239.1.1.1 port 2000 route 10.224.252.254
web admin system name unhcr password unhcr123
dn-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Dec 03 2013 13:00:40
ephone-template 1
lpcor type local
lpcor incoming user
lpcor outgoing user --> not yet configured, need this?
ephone-dn 13 dual-line
number 649
pickup-group 1101
label Server Room - 649
description Server Room - 649
name Server Room - 649
ephone 13
device-security-mode none
mac-address 0C68.03C1.79B8
ephone-template 1
type 7945
button 1:13
RTR-01#sh flash0:
-#- --length-- -----date/time------ path
1 68482708 Aug 13 2013 11:24:54 +07:00 c3900e-universalk9-mz.SPA.151-4.M5.bin
239 2464 Aug 13 2013 11:37:14 +07:00 home.shtml
240 0 Nov 30 2013 16:38:02 +07:00 its
241 0 Nov 30 2013 16:38:02 +07:00 its/vrf1
242 60 Nov 30 2013 16:38:06 +07:00 its/SEPDEFAULT.cnf
243 3239 Nov 30 2013 16:38:06 +07:00 its/vrf1/XMLDefault.cnf.xml
244 517 Nov 30 2013 16:38:08 +07:00 its/vrf1/XMLDefault7902.cnf.xml
245 970 Nov 30 2013 16:38:08 +07:00 its/vrf1/XMLDefault7905.cnf.xml
246 1260 Nov 30 2013 17:52:16 +07:00 its/vrf1/XMLDefault7906.cnf.xml
247 603 Nov 30 2013 16:38:08 +07:00 its/vrf1/XMLDefault7910.cnf.xml
248 1260 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7911.cnf.xml
249 970 Nov 30 2013 16:38:10 +07:00 its/vrf1/XMLDefault7912.cnf.xml
250 970 Nov 30 2013 16:38:10 +07:00 its/vrf1/XMLDefault7920.cnf.xml
251 1186 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7921.cnf.xml
252 1222 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7925.cnf.xml
253 1260 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7931.cnf.xml
254 550 Nov 30 2013 16:38:12 +07:00 its/vrf1/XMLDefault7935.cnf.xml
255 550 Nov 30 2013 16:38:12 +07:00 its/vrf1/XMLDefault7936.cnf.xml
256 1260 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7937.cnf.xml
257 1065 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940.cnf.xml
258 1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7914-1.cnf.xml
259 1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7915-12-1.cnf.xml
260 1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7915-24-1.cnf.xml
261 1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7916-12-1.cnf.xml
262 1227 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7916-24-1.cnf.xml
263 1358 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7914-2.cnf.xml
264 1358 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7915-12-2.cnf.xml
265 1358 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7915-24-2.cnf.xml
266 1358 Nov 30 2013 16:38:18 +07:00 its/vrf1/XMLDefault7940-7916-12-2.cnf.xml
267 1358 Nov 30 2013 16:38:18 +07:00 its/vrf1/XMLDefault7940-7916-24-2.cnf.xml
268 1260 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7941.cnf.xml
269 1262 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7941GE.cnf.xml
270 1260 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7942.cnf.xml
271 1260 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7945.cnf.xml
272 1065 Nov 30 2013 16:38:20 +07:00 its/vrf1/XMLDefault7960.cnf.xml
273 1227 Nov 30 2013 16:38:20 +07:00 its/vrf1/XMLDefault7960-7914-1.cnf.xml
274 1227 Nov 30 2013 16:38:20 +07:00 its/vrf1/XMLDefault7960-7915-12-1.cnf.xml
275 1227 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7915-24-1.cnf.xml
276 1227 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7916-12-1.cnf.xml
277 1227 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7916-24-1.cnf.xml
278 1358 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7914-2.cnf.xml
279 1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7915-12-2.cnf.xml
280 1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7915-24-2.cnf.xml
281 1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7916-12-2.cnf.xml
282 1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7916-24-2.cnf.xml
283 1260 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961.cnf.xml
284 1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7914-1.cnf.xml
285 1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7915-12-1.cnf.xml
286 1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7915-24-1.cnf.xml
287 1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7916-12-1.cnf.xml
288 1422 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7916-24-1.cnf.xml
289 1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7914-2.cnf.xml
290 1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7915-12-2.cnf.xml
291 1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7915-24-2.cnf.xml
292 1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7916-12-2.cnf.xml
293 1553 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961-7916-24-2.cnf.xml
294 1262 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961GE.cnf.xml
295 1424 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961GE-7914-1.cnf.xml
296 1424 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961GE-7915-12-1.cnf.xml
297 1424 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7915-24-1.cnf.xml
298 1424 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7916-12-1.cnf.xml
299 1424 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7916-24-1.cnf.xml
300 1555 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7914-2.cnf.xml
301 1555 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7915-12-2.cnf.xml
302 1555 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7961GE-7915-24-2.cnf.xml
303 1555 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7961GE-7916-12-2.cnf.xml
304 1555 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7961GE-7916-24-2.cnf.xml
305 1260 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7962.cnf.xml
306 1422 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7962-7914-1.cnf.xml
307 1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7915-12-1.cnf.xml
308 1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7915-24-1.cnf.xml
309 1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7916-12-1.cnf.xml
310 1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7916-24-1.cnf.xml
311 1553 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7914-2.cnf.xml
312 1553 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7915-12-2.cnf.xml
313 1553 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7962-7915-24-2.cnf.xml
314 1553 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7962-7916-12-2.cnf.xml
315 1553 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7962-7916-24-2.cnf.xml
316 1260 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7965.cnf.xml
317 1422 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7965-7914-1.cnf.xml
318 1422 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7965-7915-12-1.cnf.xml
319 1422 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7915-24-1.cnf.xml
320 1422 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7916-12-1.cnf.xml
321 1422 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7916-24-1.cnf.xml
322 1553 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7914-2.cnf.xml
323 1553 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7915-12-2.cnf.xml
324 1553 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7915-24-2.cnf.xml
325 1553 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7965-7916-12-2.cnf.xml
326 1553 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7965-7916-24-2.cnf.xml
327 1260 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970.cnf.xml
328 1422 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970-7914-1.cnf.xml
329 1422 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970-7915-12-1.cnf.xml
330 1422 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970-7915-24-1.cnf.xml
331 1422 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7916-12-1.cnf.xml
332 1422 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7916-24-1.cnf.xml
333 1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7914-2.cnf.xml
334 1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7915-12-2.cnf.xml
335 1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7915-24-2.cnf.xml
336 1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7916-12-2.cnf.xml
337 1553 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7970-7916-24-2.cnf.xml
338 1260 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971.cnf.xml
339 1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7914-1.cnf.xml
340 1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7915-12-1.cnf.xml
341 1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7915-24-1.cnf.xml
342 1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7916-12-1.cnf.xml
343 1422 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7916-24-1.cnf.xml
344 1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7914-2.cnf.xml
345 1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7915-12-2.cnf.xml
346 1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7915-24-2.cnf.xml
347 1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7916-12-2.cnf.xml
348 1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7916-24-2.cnf.xml
349 1260 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975.cnf.xml
350 1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7914-1.cnf.xml
351 1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7915-12-1.cnf.xml
352 1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7915-24-1.cnf.xml
353 1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7916-12-1.cnf.xml
354 1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7916-24-1.cnf.xml
355 1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7914-2.cnf.xml
356 1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7915-12-2.cnf.xml
357 1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7915-24-2.cnf.xml
358 1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7916-12-2.cnf.xml
359 1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7916-24-2.cnf.xml
360 1260 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7985.cnf.xml
361 404 Nov 30 2013 16:39:02 +07:00 its/vrf1/ATADefault.cnf.xml
362 1224 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefaultCIPC.cnf.xml
363 1353 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6921.cnf.xml
364 1353 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6941.cnf.xml
365 1353 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6961.cnf.xml
366 1260 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6901.cnf.xml
367 1260 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6911.cnf.xml
368 1222 Nov 30 2013 17:52:52 +07:00 its/vrf1/XMLDefault7926.cnf.xml
369 903 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-tones.xml
370 8777 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-font.xml
371 1313 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-kate.xml
372 19750 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-dictionary.xml
373 2740 Nov 30 2013 16:39:08 +07:00 its/united_states_SCCP-dictionary.xml
374 496521 Dec 3 2013 12:38:48 +07:00 music-on-hold.au
375 55599 Dec 3 2013 17:23:12 +07:00 app-b-acd-aa-3.0.0.2.tcl
376 1030860 Dec 3 2013 17:44:44 +07:00 en_bacd_welcome.au
377 0 Dec 5 2013 14:10:12 +07:00 gui
378 828928 Dec 5 2013 14:20:14 +07:00 gui.tar
379 4118 Dec 5 2013 14:21:30 +07:00 gui/admin_user.html
380 677820 Dec 5 2013 14:21:32 +07:00 gui/admin_user.js
381 1029 Dec 5 2013 14:21:32 +07:00 gui/CiscoLogo.gif
382 639 Dec 5 2013 14:21:32 +07:00 gui/CME_GUI_README.TXT
383 953 Dec 5 2013 14:21:32 +07:00 gui/Delete.gif
384 16344 Dec 5 2013 14:21:32 +07:00 gui/dom.js
385 864 Dec 5 2013 14:21:34 +07:00 gui/downarrow.gif
386 6315 Dec 5 2013 14:21:34 +07:00 gui/ephone_admin.html
387 4558 Dec 5 2013 14:21:34 +07:00 gui/logohome.gif
388 3978 Dec 5 2013 14:21:34 +07:00 gui/normal_user.html
389 78428 Dec 5 2013 14:21:36 +07:00 gui/normal_user.js
390 1347 Dec 5 2013 14:21:36 +07:00 gui/Plus.gif
391 843 Dec 5 2013 14:21:36 +07:00 gui/sxiconad.gif
392 174 Dec 5 2013 14:21:36 +07:00 gui/Tab.gif
393 2496 Dec 5 2013 14:21:36 +07:00 gui/telephony_service.html
394 870 Dec 5 2013 14:21:38 +07:00 gui/uparrow.gif
395 10230 Dec 5 2013 14:21:38 +07:00 gui/xml-test.html
396 3412 Dec 5 2013 14:21:38 +07:00 gui/xml.template
397 2910 Dec 5 2013 15:33:52 +07:00 RingList.xml
398 2823 Dec 5 2013 14:41:20 +07:00 DistinctiveRingList.xml
399 326144 Dec 5 2013 14:46:50 +07:00 ringtones.tar
400 0 Dec 5 2013 14:47:18 +07:00 ringtones
401 8160 Dec 5 2013 14:47:18 +07:00 ringtones/Analog1.raw
402 8160 Dec 5 2013 14:47:18 +07:00 ringtones/Analog2.raw
403 5280 Dec 5 2013 14:47:18 +07:00 ringtones/AreYouThere.raw
404 5040 Dec 5 2013 14:47:20 +07:00 ringtones/AreYouThereF.raw
405 8160 Dec 5 2013 14:47:20 +07:00 ringtones/Bass.raw
406 12240 Dec 5 2013 14:47:20 +07:00 ringtones/CallBack.raw
407 16040 Dec 5 2013 14:47:20 +07:00 ringtones/Chime.raw
408 8160 Dec 5 2013 14:47:22 +07:00 ringtones/Classic1.raw
409 16080 Dec 5 2013 14:47:22 +07:00 ringtones/Classic2.raw
410 10800 Dec 5 2013 14:47:22 +07:00 ringtones/ClockShop.raw
411 2823 Dec 5 2013 14:47:22 +07:00 ringtones/DistinctiveRingList.xml
412 9600 Dec 5 2013 14:47:22 +07:00 ringtones/Drums1.raw
413 13440 Dec 5 2013 14:47:24 +07:00 ringtones/Drums2.raw
414 15840 Dec 5 2013 14:47:24 +07:00 ringtones/FilmScore.raw
415 16080 Dec 5 2013 14:47:24 +07:00 ringtones/HarpSynth.raw
416 8160 Dec 5 2013 14:47:24 +07:00 ringtones/Jamaica.raw
417 16080 Dec 5 2013 14:47:24 +07:00 ringtones/KotoEffect.raw
418 12720 Dec 5 2013 14:47:26 +07:00 ringtones/MusicBox.raw
419 8160 Dec 5 2013 14:47:26 +07:00 ringtones/Piano1.raw
420 15360 Dec 5 2013 14:47:26 +07:00 ringtones/Piano2.raw
421 9360 Dec 5 2013 14:47:26 +07:00 ringtones/Pop.raw
422 7200 Dec 5 2013 14:47:26 +07:00 ringtones/Pulse1.raw
423 4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring1.raw
424 4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring2.raw
425 4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring3.raw
426 4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring4.raw
427 4000 Dec 5 2013 14:47:30 +07:00 ringtones/Ring5.raw
428 4000 Dec 5 2013 14:47:30 +07:00 ringtones/Ring6.raw
429 4000 Dec 5 2013 14:47:30 +07:00 ringtones/Ring7.raw
430 495 Dec 5 2013 14:47:30 +07:00 ringtones/RingList.xml
431 10800 Dec 5 2013 14:47:30 +07:00 ringtones/Sax1.raw
432 14160 Dec 5 2013 14:47:32 +07:00 ringtones/Sax2.raw
433 16080 Dec 5 2013 14:47:32 +07:00 ringtones/Vibe.raw
434 1435 Dec 6 2013 17:33:04 +07:00 its/vrf1/SEP0C6803C179B8.cnf.xml
181395456 bytes available (75214848 bytes used)
RTR-01#
