CME forward all issue
Tibor Marchyn
first of all I want to thank to all people which will have a look on my problem.
And now problem. I have CIsco 2801 router with CME 7.1 in. This router is in my branch in USA and our HQ is in CZ. USA employees ordered ISDN trunk to their location and connected ISDN cable to Cisco router. I've got ISDN specs from ISP and configured. Outbound and Inbound calls working fine. But issue is when anybody in USA set forward-all on their desk phones to their mobile phones.
Problem is that before they had analog lines and let ISP port their analog numbers to ISDN trunk, so I need to match all extensions to different external number and cannot use dial plan like 615112233XX. each external number is different.
I configured it that outbound calls are dialed as "9xxxxxxxxxx" ("9" + 10 digits) for national calls, or "0.T" ("0" + undefined count of digits) for international calls. numbers "21XX" are routed to trunk to Prague.
So I would like to ask you for check my config and say what is bad, what could be improved and how to fix my forward issue?
Thanks to all
version 12.4
boot-start-marker
boot system flash:c2801-adventerprisek9_ivs-mz.124-24.T8.bin
boot-end-marker
card type t1 0 1
logging message-counter syslog
no logging buffered
aaa new-model
aaa session-id common
clock timezone CST -5
network-clock-participate wic 1
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.12.1 192.168.12.10
ip dhcp excluded-address 192.168.12.250 192.168.12.254
ip dhcp pool PC
   network 192.168.12.0 255.255.255.0
   default-router 192.168.12.1
   dns-server 192.168.100.10 192.168.159.10
   domain-name local.domain.com
   option 150 ip 192.168.12.1
ip cef
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 nntp
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 ntp
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 vdolive
ip reflexive-list timeout 120
no ipv6 cef
isdn switch-type primary-ni
trunk group PSTN
voice service voip
redirect ip2ip
fax protocol cisco
h323
  h225 id-passthru
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
codec preference 4 g729r8
voice translation-rule 1001
rule 1 /^6151111111$/ /2301/
rule 2 /^6152222222$/ /2302/
rule 3 /^6153333333$/ /2303/
rule 4 /^6154444444$/ /2304/
voice translation-rule 2001
rule 1 /2301/ /6151111111/
rule 2 /2302/ /6152222222/
rule 3 /2303/ /6153333333/
rule 4 /2304/ /6154444444/
voice translation-rule 2101
rule 1 /^9/ //
voice translation-rule 2102
rule 1 /^0/ //
voice translation-profile inc_pri
translate called 1001
voice translation-profile out_pri
translate called 2101
voice translation-profile out_pri_dn
translate calling 2001
voice translation-profile out_pri_intl
translate called 2102
voice-card 0
dsp services dspfarm
crypto pki trustpoint TP-self-signed-196247180
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-196247180
revocation-check none
rsakeypair TP-self-signed-196247180
crypto pki certificate chain TP-self-signed-196247180
certificate self-signed 01
  30820252 308201BB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  2673672E 86CB37DF 2430EABF A84E7863 A8F6A4AC 7A47
   quit
archive
log config
  hidekeys
crypto isakmp policy 2
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxxxxxxxxxxxxxx address 1.2.3.210
crypto isakmp key cccccccccccccccc address 2.3.4.154
crypto isakmp key dddddddddddddddd address 3.4.5.218
crypto ipsec transform-set IPSEC-US-IOS-CZ-ASA esp-3des esp-sha-hmac
crypto map CMAP-TO-CZ 1 ipsec-isakmp
description to CZ ZOOM 1.2.23.210
set peer 1.2.3.210
set ip access-group acl_vpn_usa_to_prague2 in
set transform-set IPSEC-US-IOS-CZ-ASA
match address exempt-to-cz-zoom
crypto map CMAP-TO-CZ 2 ipsec-isakmp
description to CZ ShwoRACK 3.4.5.218
set peer 3.4.5.218
set ip access-group acl_vpn_usa_to_showrack in
match address exempt-to-cz-showrack
controller T1 0/1/0
clock source line primary
cablelength long 0db
pri-group timeslots 1-6,24
trunk-group PSTN timeslots 1-6
controller T1 0/1/1
ip ssh version 1
no ip rcmd domain-lookup
interface FastEthernet0/0
ip address 9.9.9.165 255.255.255.252
ip access-group FIREWALL in
ip nat outside
ip inspect DEFAULT100 in
ip inspect DEFAULT100 out
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/3/0
switchport access vlan 12
speed 100
spanning-tree portfast
interface FastEthernet0/3/1
speed 100
interface FastEthernet0/3/2
speed 100
interface FastEthernet0/3/3
speed 100
interface FastEthernet0/3/4
speed 100
interface FastEthernet0/3/5
speed 100
interface FastEthernet0/3/6
speed 100
interface FastEthernet0/3/7
speed 100
interface FastEthernet0/3/8
speed 100
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Vlan1
no ip address
interface Vlan12
description $ES_LAN$
ip address 192.168.12.1 255.255.255.0
ip access-group acl_LAN_IN in
ip nat inside
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.12.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 9.9.9.166
ip http server
ip http authentication local
ip http secure-server
ip http path flash:gui
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/0 overload
ip access-list extended FIREWALL
permit udp any eq domain any
permit tcp any host 9.9.9.165 established
deny   tcp any host 9.9.9.165 eq 1720
deny   tcp any host 9.9.9.165 eq 2000
deny   tcp any host 9.9.9.165 eq 5060
permit icmp any host 9.9.9.165 log
permit ip host 1.2.3.210 host 9.9.9.165 log
permit ip host 3.4.5.218 host 9.9.9.165 log
permit tcp any host 9.9.9.165 eq 22 log
permit tcp any host 9.9.9.165 eq www log
permit tcp any host 9.9.9.165 eq 443 log
deny   ip any host 9.9.9.165 log
route-map SDM_RMAP_1 permit 1
match ip address 101
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:AreYouTheref.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:RingList.xml
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Chime.raw
tftp-server flash:Vibe.raw
tftp-server flash:SCCP75.8-4-2S.loads
tftp-server flash:term75.default.loads
tftp-server flash:apps75.8-4-1-23.sbn
tftp-server flash:cnu75.8-4-1-23.sbn
tftp-server flash:cvm75sccp.8-4-1-23.sbn
tftp-server flash:dsp75.8-4-1-23.sbn
tftp-server flash:jar75sccp.8-4-1-23.sbn
control-plane
disable-eadi
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0:23
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
associate application SCCP
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions software 6
dial-peer voice 2001 voip
description to cz
huntstop
destination-pattern 21..
voice-class codec 1
session target ipv4:192.168.100.12
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 101 pots
description INCOMING PRI
translation-profile incoming inc_pri
incoming called-number .
direct-inward-dial
port 0/1/0:23
dial-peer voice 201 pots
description OUTGOING PRI
translation-profile outgoing out_pri
destination-pattern 9..........
port 0/1/0:23
forward-digits all
dial-peer voice 202 pots
description OUTGOING INTL PRI
translation-profile outgoing out_pri_intl
destination-pattern 0.T
port 0/1/0:23
forward-digits all
gatekeeper
shutdown
telephony-service
max-ephones 25
max-dn 25
ip source-address 192.168.12.1 port 2000
load 7975 SCCP75.8-4-2S.loads
time-zone 8
date-format yy-mm-dd
max-conferences 4 gain -6
call-forward pattern .T
moh cme/music-on-hold.au
web admin system name webadmin secret 5 xxxxxxxxxxxxxxxxxxxxxx
web admin customer name webcust secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx
dn-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Sep 01 2010 07:18:12
ephone-template  1
ephone-dn  4  dual-line
number 2301
name Brian
translation-profile incoming out_pri_dn
ephone-dn  5  dual-line
number 2302
name Teresa
ephone-dn  6  dual-line
number 2303
name Andy
ephone-dn  7  dual-line
number 2304
name Sales
ephone  1
device-security-mode none
mac-address A40C.C395.68B3
speed-dial 1 2302 label "Teresa"
speed-dial 2 2303 label "Andy"
speed-dial 3 2304 label "Dylan"
speed-dial 4 96156667778 label "Andys Cell"
type 7975
button  1:4
ephone  3
description andy
mac-address A40C.C395.6CC0
fastdial 1 96156667778 name My
speed-dial 1 2304 label "Dylan"
speed-dial 2 2301 label "Brian"
speed-dial 3 2302 label "Teresa"
type 7975
button  1:6
ephone  4
description sales
mac-address 0021.A084.F1BA
speed-dial 1 96156667778 label "Andy Cell"
speed-dial 2 2302 label "Teresa"
speed-dial 3 2301 label "Brian"
type 7975
button  1:7
ephone  12
mac-address A40C.C395.6991
speed-dial 1 96156667778 label "Andys Cell"
speed-dial 2 2304 label "Dylan"
speed-dial 4 2303 label "Andy"
type 7975
button  1:5
ephone  999
mac-address D4BE.D996.F327
type CIPC
button  1:7 2w4 4:4 5:5
button  6:6
ephone  1000
mac-address 90E6.BA57.A60E
type CIPC
button  1:4 2:5 3:6 4:7
scheduler allocate 20000 1000
ntp source FastEthernet0/0
ntp server 192.168.100.10 source Vlan12
end
5 Replies 5
Ayodeji Okanlawon
Hi Tibor,
So call forward to mobile phones do not work. what is the pattern for the mobile phones? is it 0.T or 9.T
Can you do a test call and send the ff
debug voip ccapi inout
debug isdn q931
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
mobile pattern is same as national calls - 9..........
Pattern 0.T is only for international calls with more then 10 digits number...
thanks
debug output:
Sep 23 11:52:25.131: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0051
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18386
                Preferred, Channel 6
        Facility i = 0x9F8B0100A113020101020100800B4F7574206F662041726561
                Protocol Profile =  Networking Extensions
                0xA113020101020100800B4F7574206F662041726561
                Component = Invoke component
                        Invoke Id = 1
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = Out of Area
        Calling Party Number i = 0x0080, '20222554187'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '6154721878'
Sep 23 11:52:25.135: ISDN Se0/1/0:23 Q931: Received SETUP  callref = 0x8051 callID = 0x001F switch = primary-ni interface = User
Sep 23 11:52:25.139: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=20222554187, Called Number=6154721878, Voice-Interface=0x6A5791F8,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=101
   Calling Number=20222554187, Called Number=6154721878, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
Sep 23 11:52:25.139: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2303, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2303
   Result=Success(0) after DP_MATCH_DEST
Sep 23 11:52:25.139: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20003
Sep 23 11:52:25.143: //-1/F9CC1E048053/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=20222554187
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=6154721878
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Sep 23 11:52:25.147: //-1/F9CC1E048053/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x6A5791F8, Call Info(
   Calling Number=20222554187,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=6154721878(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=101, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=PSTN, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Sep 23 11:52:25.147: //-1/F9CC1E048053/CCAPI/ccCheckClipClir:
   In: Calling Number=20222554187(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=20222554187(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Sep 23 11:52:25.147: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 23 11:52:25.147: :cc_get_feature_vsa malloc success
Sep 23 11:52:25.147:  cc_get_feature_vsa count is 1
Sep 23 11:52:25.147: :FEATURE_VSA attributes are: feature_name:0,feature_time:1785011664,feature_id:478
Sep 23 11:52:25.147: //400/F9CC1E048053/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=20222554187(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=6154721878(TON=Unknown, NPI=Unknown))
Sep 23 11:52:25.151: //400/F9CC1E048053/CCAPI/cc_process_call_setup_ind:
   Event=0x68771520
Sep 23 11:52:25.151: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 6154721878
Sep 23 11:52:25.151: //400/F9CC1E048053/CCAPI/ccCallSetContext:
   Context=0x6A6AB444
   >>>>CCAPI handed cid 400 with tag 101 to app "_ManagedAppProcess_Default"
Sep 23 11:52:25.155: //400/F9CC1E048053/CCAPI/ccCallProceeding:
Sep 23 11:52:25.155: //-1/F9CC1E048053/DPM/dpMatchPeersCore:
Sep 23 11:52:25.155: //-1/F9CC1E048053/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Sep 23 11:52:25.155: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=2303, Called Number=2303, Peer Info Type=DIALPEER_INFO_SPEECH
Sep 23 11:52:25.155: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Calling Number=, Called Number=96156532162, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=96156532162
   Result=SUCCESS(0)
     1: Dial-peer Tag=201
Sep 23 11:52:25.155: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2303, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Sep 23 11:52:25.159: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sep 23 11:52:25.159: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Sep 23 11:52:25.159: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Sep 23 11:52:25.159: //-1/F9CC1E048053/DPM/dpMatchPeersCore:
Sep 23 11:52:25.159: //-1/F9CC1E048053/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Sep 23 11:52:25.159: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=2303
Sep 23 11:52:25.163: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Sep 23 11:52:25.163: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Sep 23 11:52:25.163: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=2303, Called Number=2303, Calling Number=20222554187, Calling DN=-1 Calling Id=400,
   Redirect Number=96156532162, Redirect Reason=15
   Calling Number=, Called Number=20222554187, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=20222554187
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
   Result=SUCCESS(0)
Sep 23 11:52:25.163: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
Sep 23 11:52:25.163: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 23 11:52:25.163: :cc_get_feature_vsa malloc success
Sep 23 11:52:25.163:  cc_get_feature_vsa count is 2
Sep 23 11:52:25.163: :FEATURE_VSA attributes are: feature_name:0,feature_time:1785011440,feature_id:479
Sep 23 11:52:25.163: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Sep 23 11:52:25.163:  feature_vsa is 6A651DC8,featname is 0
Sep 23 11:52:25.163:  cc_get_feature_vsa count is 3
Sep 23 11:52:25.163: :FEATURE_VSA attributes are: feature_name:0,feature_time:1785011216,feature_id:480
Sep 23 11:52:25.163: : Generating new featurevsa,inserting it
Sep 23 11:52:25.163:  feature call forward featname is 1
Sep 23 11:52:25.163: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 23 11:52:25.163: :cc_free_feature_vsa freeing 6A651CE8
Sep 23 11:52:25.163:  vsacount in free is 2
Sep 23 11:52:25.167: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8051
        Channel ID i = 0xA98386
                Exclusive, Channel 6
Sep 23 11:52:25.167: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 23 11:52:25.167: :cc_get_feature_vsa malloc success
Sep 23 11:52:25.167:  cc_get_feature_vsa count is 3
Sep 23 11:52:25.171: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 23 11:52:25.171: :FEATURE_VSA attributes are: feature_name:0,feature_time:1785011440,feature_id:481
Sep 23 11:52:25.171: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Sep 23 11:52:25.171:  feature call forward featname is 1
Sep 23 11:52:25.171: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 23 11:52:25.171: :cc_free_feature_vsa freeing 6A651CE8
Sep 23 11:52:25.171:  vsacount in free is 2
Sep 23 11:52:25.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Sep 23 11:52:25.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
Sep 23 11:52:25.171: //400/F9CC1E048053/CCAPI/ccGetTBCTCap:
   TGRM TBCT Enabled; TBCT Capability=0
Sep 23 11:52:25.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Sep 23 11:52:25.171: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=96156532162, Called Number=, Voice-Interface=0x0,
Sep 23 11:52:25.175: //-1/F9D238C584D6/DPM/dpMatchPeersCore:
Sep 23 11:52:25.175: //-1/F9D238C584D6/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Sep 23 11:52:25.175: //400/F9CC1E048053/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=201, Params=0x6A6B85EC, Progress Indication=NULL(0)
Sep 23 11:52:25.175: //400/F9CC1E048053/CCAPI/ccCheckClipClir:
Sep 23 11:52:25.179: //400/F9CC1E048053/CCAPI/ccCallSetupRequest:
   Destination Pattern=9.........., Called Number=6156532162, Digit Strip=TRUE
   Called Number=6156532162(TON=Unknown, NPI=Unknown),
   Redirect Number=2303, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=F9D238C5-04AB-11E2-84D6-9041A5EA61EB, Outgoing Dial-peer=201
Sep 23 11:52:25.179: //400/F9CC1E048053/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=6156532162
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=2303
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=15   fwd_final_type =0
Sep 23 11:52:25.179: //400/F9CC1E048053/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x6A5791F8, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=20222554187,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=6156532162(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=201, Call Count On=FALSE,
   Source Trkgrp Route Label=PSTN, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
Sep 23 11:52:25.179: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 23 11:52:25.179: :cc_get_feature_vsa malloc success
Sep 23 11:52:25.179:  cc_get_feature_vsa count is 3
Sep 23 11:52:25.179: :FEATURE_VSA attributes are: feature_name:0,feature_time:1785011440,feature_id:482
Sep 23 11:52:25.179: //401/F9CC1E048053/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Sep 23 11:52:25.179: //401/F9CC1E048053/CCAPI/ccCallSetContext:
   Context=0x6A6B859C
Sep 23 11:52:25.179: //400/F9CC1E048053/CCAPI/ccSaveDialpeerTag:
Sep 23 11:52:25.179: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Sep 23 11:52:25.179:  feature call forward featname is 1
Sep 23 11:52:25.179:  feature_vsa is 6A651CE8,featname is 0
Sep 23 11:52:25.179:  cc_get_feature_vsa count is 4
Sep 23 11:52:25.179: :FEATURE_VSA attributes are: feature_name:0,feature_time:1785010992,feature_id:483
Sep 23 11:52:25.179: : Generating new featurevsa,inserting it
Sep 23 11:52:25.187: ISDN Se0/1/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Sep 23 11:52:25.187: ISDN Se0/1/0:23 Q931: Sending SETUP  callref = 0x00DE callID = 0x8042 switch = primary-ni interface = User
Sep 23 11:52:25.187: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8  callref = 0x00DE
                Standard = CCITT
        Channel ID i = 0xA98385
                Exclusive, Channel 5
                        Invoke Id = 1
                                Name = Out of Area
        Called Party Number i = 0xA1, '6156532162'
                Plan:ISDN, Type:National
        Redirecting Number i = 0x00008F, '2303'
Sep 23 11:52:25.211: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x80DE
Sep 23 11:52:25.215: //401/F9CC1E048053/CCAPI/cc_api_call_proceeding:
   Interface=0x6A5791F8, Progress Indication=NULL(0)
Sep 23 11:52:25.231: ISDN Se0/1/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x80DE
        Cause i = 0x8281 - Unallocated/unassigned number
Sep 23 11:52:25.235: ISDN Se0/1/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x00DE
Sep 23 11:52:25.235: //401/F9CC1E048053/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x6A5791F8, Call Id=401
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Sep 23 11:52:25.239: //400/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Sep 23 11:52:25.239: //401/F9CC1E048053/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=401
Sep 23 11:52:25.239: //401/F9CC1E048053/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Sep 23 11:52:25.239: //401/F9CC1E048053/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Sep 23 11:52:25.251: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80DE
Sep 23 11:52:25.259: //401/F9CC1E048053/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6A5791F8, Tag=0x0, Call Id=401,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Sep 23 11:52:25.259: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 23 11:52:25.259: :cc_free_feature_vsa freeing 6A651B28
Sep 23 11:52:25.259:  vsacount in free is 3
Sep 23 11:52:25.259:  vsacount in free is 2
Sep 23 11:52:25.259: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=9.........., Called Number=, Voice-Interface=0x0,
Sep 23 11:52:25.263: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sep 23 11:52:25.263: //400/F9CC1E048053/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Sep 23 11:52:25.263: //400/F9CC1E048053/CCAPI/cc_api_get_transfer_info:
Sep 23 11:52:25.267: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8051
        Cause i = 0x8081 - Unallocated/unassigned number
Sep 23 11:52:25.291: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x0051
Sep 23 11:52:25.295: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8051
Sep 23 11:52:25.299: //400/F9CC1E048053/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6A5791F8, Tag=0x0, Call Id=400,
Sep 23 11:52:25.299: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 23 11:52:25.299: :cc_free_feature_vsa freeing 6A651C08
Sep 23 11:52:25.299:  vsacount in free is 1
Sep 23 11:52:25.303: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 23 11:52:25.303:  vsacount in free is 0
Sep 23 11:52:25.303: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Result=NO_MATCH(-1) After All Match Rules Attemptter no mon
Tibor,
Okay I have looked at the l ogs and here is what I see..
1. Incoming call from 20222554187 to 6154721878
2. The call was xlated to extension 2303
3. We then see the call diverted to 6156532162.
Now this call was routed to the PSTN and your telco provider rejected the call saying that it cant find the number 6156532162.
So question is is this a valid number? Your Telco doesnt think it is. Do you need to add additional digits to it?
I will contact Telco Op. but it's strange, because when I dial same number from phone, everything works fine...
Could be problem by presenting 2303 to telco as outgoing number? Is my masking to public number OK???
I've still not get answer from telco... but strange is when I call from internal deskphone call forward is working without any problems.
Problems starting when somebody from PSTN calls in. then redirect is not working...
i have little bit changed config but it doesn't help...
Now DN is same as external phone number... so when inbound call no translation-profile used..when outbound call only discard "9" as prefix in dial peer.
telephony-service
max-ephones 25
max-dn 25
time-zone 8
call-forward system redirecting-expanded
ephone-dn  2  dual-line
number 2302
ephone-dn  12  dual-line
number 6151234567
call-forward all 96154446667
ephone  12
description Teresa
type 7975
button  1:12
button  2:2
