CME FXO Configuration
alkabeer80
hi, I have CME with 4 fxo port which i want to connect 4 analog lines in it.
how can i configure these FXO ports, so that it can have 3 lines for all employee and one line direct for manager ?
thanks
2 Accepted Solutions
Anas Abueideh
Level 9
Level 9
you need to use cor list to differentiate  between the manager and employees, cor list like partitions in call manager.
kindly find the below configuration
dial-peer cor custom
name Manager
name Employee
dial-peer cor list Manager
member Manager
dial-peer cor list Employee
member Employee
dial-peer cor list callingManager
member Manager
dial-peer cor list callingEmployee
member Employee
dial-peer voice 10 pots
corlist outgoing Employee
description ------Employee Calls-----
destination-pattern .T
port 0/0/0
forward-digits all
dial-peer voice 11 pots
corlist outgoing Manager
description ------Manager Calls-----
port 0/0/1
forward-digits all
ephone-dn  1 octo-line
number 200 no-reg primary
description Manager
corlist incoming callingManager
ephone-dn  2  octo-line
number 201 no-reg primary
description Employee
corlist incoming callingEmployee
Anas
please help if it is helpful
Hi alkabeer,
kindly rate if it is helpful. you rate help the community
thanks in advance
Anas
6 Replies 6
paolo bevilacqua
This is often discussed, if you could search the forum beoref asking.
Anas Abueideh
Level 9
Level 9
name Manager
name Employee
member Manager
member Employee
member Manager
member Employee
port 0/0/0
forward-digits all
port 0/0/1
forward-digits all
description Manager
Anas
thanks aabueideh for your help.
thanks Paolo Bevilacqua, you could simply answer it or at least leave it without comments if it bother you.
Hi alkabeer,
thanks in advance
Anas
Try to understand this:
No need to discuss again and again things that have been answered already, and you could have found with a simple search.
This forum is for helping people, you could send the link of discussed answer.
try to understand this !!!!!!!!!!!!!!!!!!
whos u to tell this, SIMPLY DO NOT ANSWER OR ASK ADMINISTRATOR TO REMOVE IT
