CME gets busy signal when I dial out
mercdecember
For some rason my current config works, but if I were to just add the statement
conf t
voice translation-rule 3
end
The rule is applied to nothing and has nothing applied to it I get busy signal, if I do:
conf t
no voice translation-rule 3
end
I still get a busy signal.
If I do not save my config and reboot, I can make a cal when my router comes back online.
attached is my config please let me know what if there is something wrong with it or if there is something I need to apply.
My router is a 2800 series router
5 Replies 5
Niranjan Durairaj
Please send "debug ccsip messages" & "debug voip ccapi inout" outputs.
Niran
Attached is the output
I can see that you are getting  404 from your sip provider.
Received:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 50.0.0.21:5060;branch=z9hG4bK281446;received=50.0.0.21;rport=10        38
From: <sip:9142281462@newyork.voip.ms>;tag=CEECC-1D72
To: <sip:18042221111@newyork.voip.ms>;tag=as295cc05e
Call-ID: A424B755-2DEC11E4-802FF15A-3687DBF8@50.0.0.21
CSeq: 101 INVITE
Server: voip.ms
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLIS        H
Supported: replaces, timer
Content-Length: 0
can you try changing your destination pattern
for
91[2-9].........
to
9[2-9].........
and check if its working, just give a try and see if it works.
regards
Chintan
I can try this tonight, but what does not make sense to me is it works until I create a voice translation rule.  Then after that I need to reboot my router for calls to work and I do not save the config.
Both 10 and 11 digit dialing are working, it appears everything works after I reboot the router after I make really any changes to CME.  Is there anything I can do to not have to reboot this router everytime I run into this issue?
