05-14-2014 04:21 AM - edited 03-16-2019 10:47 PM
When i try initiate conference with 3 or 4 paricipants, third and fourth participants listen silent if sccp phone or listen music if sip phone
#show dspfarm all
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 1 35.1.2 UP N/A FREE conf 1 - - -
I think if i increase maximum participants in conference profile this solve my problem
When i try change profile i have message profile oper state is up in progress already
#dspfarm profile 1 conference
(config-dspfarm-profile)#maximum conference-participants 8
(config-dspfarm-profile)#no shutdown
How can i change participants in profile?
Thanks for help
Solved! Go to Solution.
05-14-2014 11:40 PM
You need to do "no sdspfarm tag 1 confdsp1"
and
"sdspfarm tag 1 confprof1"
Then do "no sccp" followed by "sccp"
Manish
05-14-2014 09:06 AM
I do not see you shutting down the dspfarm profile , shutdown the dspfarm profile first, make changes and do a no shut.
Manish
05-14-2014 10:15 PM
Thanks for your answer
I perform
(config-dspfarm-profile)#shutdown
Disabling profile will disconnect active CONFERENCING calls,
do you want to continue ? [yes/no]yes
(config-dspfarm-profile)#end
#show dspfarm all
Dspfarm Profile Configuration
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : RESOURCE ALLOCATED
Application : SCCP Status : ASSOCIATION IN PROGRESS
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 2
Number of Resources Out of Service : 0
Maximum conference participants : 8
Codec Configuration: num_of_codecs:6
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Total number of DSPFARM DSP channel(s) 2
I want use conference with three and four participants simultaneously
But problem still exist (
05-14-2014 10:24 PM
Can you share the 'show run' and 'show sccp' from the CME. Also 'show sccp conn' for an active conference call.
Manish
05-14-2014 10:56 PM
Current config in attach
05-14-2014 10:56 PM
i try initiate call between to Cisco 6921 IP phones
but command #show sccp connections shows me
Total number of active session(s) 0, and connection(s) 0
05-14-2014 11:09 PM
When conference active between three Cisco 6921 IP phones
#show sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
IPv4 Address: IP
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: IP, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 100
Trustpoint: N/A
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: IP, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 16, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
05-14-2014 11:16 PM
In your config, you have
associate profile 1 register confprof1
and
Change the "sdspfarm tag 1 confdsp1" to "sdspfarm tag 1 confprof1" and do a no sccp / sccp
Let us know if that fixes the issue.
Manish
05-14-2014 11:28 PM
sorry i newbie in cisco
me need perform:
#telephony-service
#no sccp
#sdspfarm tag 1 confprof1
#sccp
#end
I understand you correctly?
05-14-2014 11:40 PM
and
Manish
05-15-2014 12:17 AM
Thank you very much!
You helped me a lot!!!!!
Conference are now working!
I think this is solved in most settings conference station
05-15-2014 12:17 AM
That's good to know. Please remember to rate all helpful posts and mark the discussion as solved if your query / issue has been answered / fixed.
Manish
