Cme international digits
smartnet
Hi all,
I'm having an issue with a customer of ours when trying to dial an international number with 14 digits.
The cisco 79XX phone is cutting the number on 14 digits including the extra 0 for an outside line.
so when i press 0 00351214543989 and i do a debug voice dialpeer i only see 0 0035121454398
when is for example use a 9 for an outside line it works...  like 9 00351214543989
why is the 0 an issue?
i tried different dialpeers like 0T as destination-pattern or just 0..............
thanks
yahsiel2004
Level 7
Level 7
You're matching another dial-peer. Can you post your config and or perform a "show dialplan number "number_that_you're_dialing"
Yosh
HTH Regards, Yosh
yahsiel2004
Level 7
Level 7
Yosh
HTH Regards, Yosh
Indeed... you're right... there where 2 dialpeers and it was matching a dialpeer with a shorter destination pattern...arggghh stupid.. thanks for you're reply.. :D
You're welcome! Glad you fixed the issue.
Yosh
HTH Regards, Yosh
