I have a question about mixed shared lines on CME.
When you create a shared line for SIP and SCCP phones, under which section are you supposed to put the common settings such as forward to voicemail and what not? What happens if you have conflicting settings under each section?
I only use SIP phones but if I wanted to add a hold-alert 30 originator command to a sip phone, would I be able to do this with a mixed shared line since that command is only available on SCCP dn's and not SIP dn's?
