05-27-2011 06:08 AM - edited 03-16-2019 05:11 AM
Hi there,
On a cisco 2821 router running IOS 15.1(4)M im trying to successfully configure 2 aa & acd scripts.
First service/script ( set as the default app-b-acd-aa service ) for my main number, which accepts the call and then callers get 8 options to route through to the hunt groups
Second one ( ictaa and ictoptions service), is for an internally dialled shortcode ( example *0) to accept the call and present the callers 2 options to route onto Helpdesk numbers.
Its all working as expected the numbers and options route through fine, but the two services/scripts don't seem to run side by side quite well.
it appears that the aa-hunt param values get mixed up with each other. So if I dial through to the default app-b-acd-aa service, select option 1 it routes me through to hunt group 2001.
If i then test dialing through to ictaa service, option 1 routes me through to 2001 also ( even though as my config below shows it should be a different destination)
But after a router reload, if I test the ictaa service first, ( press option 1) this routes through to the configured aa-hunt1 of 1899.
Then if i test the default app-b-acd-aa service, this also works fine, but any subsequent calling attempts into the ictaa service, the aa-hunt params are set with the values of the default app-b-acd service.
Can you only have 1 set of aa-hunt params configured?
application
service app-b-acd-aa
param voice-mail 5000
paramspace english index 1
param queue-exit-extension1 2010
param service-name app-b-acd
param number-of-hunt-grps 8
param menu-timeout 3
paramspace english language en
param handoff-string app-b-acd-aa
param dial-by-extension-option 0
paramspace english location flash:
param aa-pilot 100
param max-extension-length 4
param queue-overflow-extension 2011
param welcome-prompt _bacd_welcome.au
param queue-exit-option1 9
service app-b-acd
param aa-hunt7 2007
param aa-hunt3 2003
param queue-len 10
param aa-hunt8 2008
param aa-hunt4 2004
param aa-hunt5 2005
param aa-hunt1 2001
param aa-hunt6 2006
param aa-hunt2 2002
param queue-manager-debugs 1
service ictaa flash:/helpdesk/app-b-acd-aa-2.1.2.3.tcl
param aa-pilot 3501
param max-extension-length 12
param number-of-hunt-grps 2
paramspace english location flash:/helpdesk/
param handoff-string ictaa
param service-name ictoptions
service ictoptions flash:/helpdesk/app-b-acd-2.1.2.3.tcl
param aa-hunt1 1899
param aa-hunt2 1898
05-27-2011 06:34 AM
You are trying to have multiple queue services in the same router. That is not supported, and known to not work.
You can only have one queue service per router.
If you need to have different aa-hunt options for each AA service, mapping to the same keypad input, there is an undocumented parameter called optionIndex, that allows each AA to define an "offset" into the global queue aa-hunt entries.
You will need to look at the script code to understand how it works in detail.
05-27-2011 08:27 AM
Thank you for a quick response, I'll try take a look into it.
05-27-2011 08:48 AM
You're welcome, thanks for the nice rating and good luck!
