CME paging integration with TOA – 900 Series II  A-912MK2
peterson.m
My client's implementing a CME solution and needs to integrate their legacy paging using an FXS port. They have a TOA A-912MK2 paging amplifier. Documentation says telephone paging would connect to a TOA B-41S balanced line input module on the 900 series amp. Is a TAMB module required and would it work for this integration? Anyone integrate Cisco voice with a TOA 900 series before?
Here are the specs for the B-41S module -
B-41S
Balanced Line with Input with Mute-Send
For balanced or unbalanced, line level equipment such as AM/FM tuners, tape decks and CD players. Transformer isolation minimizes ground loop problems when connecting remote equipment. Signal at input terminals activates mute bus.
  • Controls/Functions:
    • Mute Send Sensitivity
  • Performance Input: 10 kohms
  • Input Sensitivity: -16 ~ -34 dBu
  • Gain (Adjustable): -2 dB
  • Physical Connector:Removable Terminal Block
Rob Huffman
Hi there,
You are most correct
If you look on Page 15 of the doc you attached, the TOA-900
is looking for a Paging output from the telephone system and not
a FXS/FXO/E&M connection. So you will  "mid-point"  integration piece like the TAMB-2 (see link)
or older TAMB between the FXS/FXO and TOA-900. The TAMB will answer the call
and then bridge across the audio to the paging system.
http://www.bogen.com/products/telephonepaging/index.html
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
Rob Huffman
Hi there,
Cheers!
Rob
"Talk about a dream
- Springsteen
Thanks Rob!
