CME-param operator- what is it
leonpr22
I saw some config on my CME under application that is param operator <number>
Can anyone explain me what is it because i didn't find it in any doc?
Chris Deren
You can define an auto attendant call flow in CME that uses a TCL script, and the script has some pre-defined parameters, one of which is the operator. You can map an input key and extension to operator if you chose it.  Here is a guide for configuration of it:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/bacd/configuration/guide/cme40tcl/40bacd.pdf
