10-06-2014 03:36 PM - edited 03-17-2019 12:26 AM
Dears,
I am trying to upload a firmware for 3905 phones in CME 9.1 but i couldn't, also GUI is not working for me I don't know where things are going wrong with me.
Attached are the configs
Solved! Go to Solution.
10-07-2014 04:29 AM
are you using any locale package?
Oct 7 14:24:31: TFTP: Looking for SIP_English_United_States/cin-sip.jar Oct 7 14:24:31: TFTP: Sending error 1 No such file Oct 7 14:24:31: TFTP: Server request for port 3072, socket_id 0x3C372FCC for process 181 Oct 7 14:24:31: TFTP: read request from host 192.168.4.35(3072) via GigabitEthernet0/0 Oct 7 14:24:31: TFTP: Looking for United_States/g3-tones.xml
10-06-2014 10:29 PM
tftp-server flash:/CP3905.9-4-1-0/APP3905.9-4-1-0.zz alias APP3905.9-4-1-0.zz
10-06-2014 11:50 PM
Dears,
Attached is the configuration for the router, i have enabled debug for tftp events but no logs seen on the terminal monitor,
For GUI i am opening by firefox 32.0.3 after username and password the blank page is opening , i also have configuration professional it is opening properly. which username and pwd we shld enter the telephony service web admin username and pwd ????? or (ip http authentication local ) local username and password?????
10-06-2014 11:57 PM
use
web admin system name admin password cisco
add , file priv 0 and remove ip http secure-server
10-07-2014 12:06 AM
Dear
what do mean by add , file priv 0 ???
I removed ip http secure-server and the GUI came up on the screen successfully.
why i cant see the tftp events on the router is it the configuration part is ok from the sh run??
thanks
10-07-2014 12:09 AM
good , send me ,
sh run | sec log
and please unplug and plug the phone back or reset the phone and see if there is any logs printed
10-07-2014 12:36 AM
Dear
here are the logs
debug tftp
Oct 7 11:25:52: TFTP: Looking for SEPBC671CDCD91A.cnf.xml
Oct 7 11:25:52: TFTP: Opened flash:/its/SEPBC671CDCD91A.cnf.xml, fd 14, size 37 37 for process 181
Oct 7 11:25:52: TFTP: Finished flash:/its/SEPBC671CDCD91A.cnf.xml, time 00:00:0 0 for process 181
Oct 7 11:25:54: TFTP: Looking for CP3905.9-4-1-0.loads
Oct 7 11:25:55: TFTP: Looking for SIP_English_United_States/cin-sip.jar
Oct 7 11:25:55: TFTP: Looking for United_States/g3-tones.xml
service timestamps log datetime localtime
no logging console
already used the username "cisco" to login to the router and your IOS image
You will not be able to login to the router with this username after you exit
banner login ^C
login local
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
login local
login local
ntp logging
10-07-2014 12:40 AM
please keep the debugs running for a while and send the logs once the phone is registered
also try below
telephony-service
load 3905 CP3905.9-4-1-0.loads
no create cnf
creae cnf
10-07-2014 01:00 AM
Dears,
Oct 7 11:25:52: TFTP: Opened flash:/its/SEPBC671CDCD91A.cnf.xml, fd 14, size 3737 for process 181
Oct 7 11:25:52: TFTP: Finished flash:/its/SEPBC671CDCD91A.cnf.xml, time 00:00:00 for process 181
Oct 7 11:30:50: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (192.168.3.100)
Oct 7 11:32:28: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (192.168.3.100)
Oct 7 11:53:44: TFTP: Server request for port 3072, socket_id 0x22BB0104 for process 181
Oct 7 11:53:44: TFTP: read request from host 192.168.4.35(3072) via GigabitEthernet0/0
Oct 7 11:53:44: TFTP: Looking for SEPBC671CDCD91A.cnf.xml
Oct 7 11:53:44: TFTP: Opened flash:/its/SEPBC671CDCD91A.cnf.xml, fd 15, size 3737 for process 181
Oct 7 11:53:44: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Received ACK for block 1, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Received ACK for block 2, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Received ACK for block 3, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Received ACK for block 4, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Received ACK for block 5, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Received ACK for block 6, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Received ACK for block 7, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Sending block 8 (retry 0), len 153, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Received ACK for block 8, socket_id 0x22BB0104
Oct 7 11:53:44: TFTP: Finished flash:/its/SEPBC671CDCD91A.cnf.xml, time 00:00:00 for process 181
Oct 7 11:53:46: TFTP: Server request for port 3072, socket_id 0x22BB0104 for process 181
Oct 7 11:53:46: TFTP: read request from host 192.168.4.35(3072) via GigabitEthernet0/0
Oct 7 11:53:46: TFTP: Looking for CP3905.9-4-1-0.loads
Oct 7 11:53:46: TFTP: Sending error 1 No such file
Oct 7 11:53:46: TFTP: Server request for port 3072, socket_id 0x3C28B3F8 for process 181
Oct 7 11:53:46: TFTP: Looking for SIP_English_United_States/cin-sip.jar
Oct 7 11:53:47: TFTP: Server request for port 3072, socket_id 0x22BB0104 for process 181
Oct 7 11:53:47: TFTP: read request from host 192.168.4.35(3072) via GigabitEthernet0/0
Oct 7 11:53:47: TFTP: Looking for United_States/g3-tones.xml
Oct 7 11:53:47: TFTP: Sending error 1 No such file
Oct 7 11:54:12: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (192.168.3.100)
10-07-2014 02:37 AM
looks like phone is not able to find the load
do you have the tftp commands pointing to the location of the load.
10-07-2014 02:41 AM
Dear
I get the error when specify the tftp command
tftp-server flash:CP3905.9-4-1-0/CP3905.9-4-1-0.loads alias CP3905.9-4-1-0.loads
Warning: flash0:CP3905.9-4-1-0/CP3905.9-4-1-0.loads does not exist. Command retained.
tftp-server flash:CP3905.9-4-1-0/APP3905.9-4-1-0.zz alias APP3905.9-4-1-0.zz
Warning: flash0:CP3905.9-4-1-0/APP3905.9-4-1-0.zz does not exist. Command retained.
dir flash
#dir flash:
Directory of flash0:/
1 -rw- 99139212 Jun 25 2014 02:59:18 +04:00 c2900-universalk9-mz.SPA.152-4.M6.bin
2 -rw- 3064 Jun 25 2014 03:10:58 +04:00 cpconfig-29xx.cfg
3 drw- 0 Sep 9 2014 16:14:28 +04:00 its
25 drw- 0 Oct 6 2014 11:44:38 +04:00 CMEGUI
44 drw- 0 Jun 25 2014 03:11:24 +04:00 ccpexp
285 -rw- 2464 Jun 25 2014 03:13:08 +04:00 home.shtml
286 drw- 0 Oct 6 2014 00:36:16 +04:00 0121808001412541444
289 drw- 0 Oct 6 2014 11:04:44 +04:00 CME 9.1.0 GUI
308 -rw- 2495472 Oct 6 2014 01:05:28 +04:00 APP3905.9-2-1-0.zz
309 -rw- 19 Oct 6 2014 01:05:28 +04:00 CP3905.9-2-1-0.loads
310 -rw- 4639974 Oct 6 2014 01:09:04 +04:00 apps42.9-2-1TH1-13.sbn
311 -rw- 575495 Oct 6 2014 01:09:06 +04:00 cnu42.9-2-1TH1-13.sbn
312 -rw- 2208583 Oct 6 2014 01:09:12 +04:00 cvm42sccp.9-2-1TH1-13.sbn
313 -rw- 356907 Oct 6 2014 01:09:12 +04:00 dsp42.9-2-1TH1-13.sbn
314 -rw- 1759967 Oct 6 2014 01:09:16 +04:00 jar42sccp.9-2-1TH1-13.sbn
315 -rw- 676 Oct 6 2014 01:09:18 +04:00 SCCP42.9-2-1S.loads
316 -rw- 680 Oct 6 2014 01:09:18 +04:00 term42.default.loads
317 -rw- 680 Oct 6 2014 01:09:20 +04:00 term62.default.loads
318 drw- 0 Oct 6 2014 17:27:56 +04:00 3905.9-4-1-0
10-07-2014 02:44 AM
try moving those files to flash , instead of a folder and check changing the path
10-07-2014 02:55 AM
Dear
ok i will try that way give me 5 min
10-07-2014 03:37 AM
Dear ,
attached are the logs for the tftp events
tftp-server flash:CP3905.9-4-1-0.loads alias CP3905.9-4-1-0.loads
tftp-server flash:APP3905.9-4-1-0.zz alias APP3905.9-4-1-0.zz
dir flash
dir flash:
321 -rw- 19 Oct 7 2014 13:49:58 +04:00 CP3905.9-4-1-0.loads
322 -rw- 2820567 Oct 7 2014 13:51:16 +04:00 APP3905.9-4-1-0.zz
thanks
10-07-2014 03:55 AM
dont see any logs , pls re-attach
