CME Phones not upgrading
adamgibs7
Level 6
Level 6
Dears,
I am trying to upload a firmware for 3905 phones in CME 9.1 but i couldn't, also GUI is not working for me I don't know where things are going wrong with me.
Attached are the configs
27 Replies 27
here are the attached
are you using any locale package?
Oct  7 14:24:31: TFTP: Looking for SIP_English_United_States/cin-sip.jar
Oct  7 14:24:31: TFTP: Sending error 1 No such file
Oct  7 14:24:31: TFTP: Server request for port 3072, socket_id 0x3C372FCC for process 181
Oct  7 14:24:31: TFTP: read request from host 192.168.4.35(3072) via GigabitEthernet0/0
Oct  7 14:24:31: TFTP: Looking for United_States/g3-tones.xml
Dear
No i  have not uploaded any locale or ring tones file in tftp.
thanks
Can you just try to giving below command only ..
tftp-server flash:CP3905.9-4-1-0.loads
tftp-server flash:APP3905.9-4-1-0.zz
Suresh
Dear Suresh,
I tried the commands but it didn't worked,
Dear Javelkur,
If it is searching  for the locale and ringtones files , i saw the package of CME 9.1 i didnt see these files.
thanks
try copying the english us locale files to flash and test
download the latest
http://software.cisco.com/download/release.html?mdfid=277641082&softwareid=282897001&release=10.5&relind=AVAILABLE&rellifecycle=&reltype=latest
make sure to copy cin-sip and g3-tones and config the tftp path as well
if that still fails, collect the same debugs and post
Dear
Attached are the logs for the TFTP without errors,
Still if i do show voice register pool 9 the current load on the phones is load 9.2.1
looks like it did upgrade in the logs
 check in , sh voice register pool phone-load or in the phone manually
Dear Javelkur,
this is the phone i am playing with, i dont have pysical access but remotely i can access the router.
#sh voice register pool 9
 Pool Tag 9
Config:
  Mac address is BC67.1CDC.D91A
   Type is 3905
  Number list 1 : DN 9
  Proxy Ip address is 0.0.0.0
  Current Phone load version is Cisco-CP3905/9.2.1
  Class of Restriction List Tag: default
    Incoming corlist name is user-national
  DTMF Relay is enabled, rtp-nte
  Call Waiting is enabled
  DnD is disabled
  Video is disabled
  Camera is disabled
  Busy trigger per button value is 0
  keep-conference is enabled
  registration expires timer max is 3600 and min is 60
  kpml signal is enabled
  Lpcor Type is none
  Transport type is udp
  service-control mechanism is supported
  registration Call ID is moCIRLFM0tCLxFbfel949AlVM607C9kB
  Registration method: per line
  Privacy feature is not configured.
  Privacy button is disabled
  active primary line is: 120
  contact IP address: 192.168.4.35 port 5060
  Phone SIS Version:  5.0.0
  GW SIS Version:  1.0.0
  conference admin: no
  conference add mode: all
  conference drop mode: never
  paging-dn: config 0 [multicast]  effective 0 [multicast]
Dialpeers created:
Dial-peers for Pool 9:
dial-peer voice 40008 voip
 corlist incoming user-national
 destination-pattern 120$
 session target ipv4:192.168.4.35:5060
 session protocol sipv2
 dtmf-relay rtp-nte
 digit collect kpml
 codec  g711ulaw bytes 160
 no vad
  after-hours-exempt   FALSE
Statistics:
  Active registrations  : 1
  Total SIP phones registered: 8
  Total Registration Statistics
    Registration requests  : 12
    Registration success   : 12
    Registration failed    : 0
    unRegister requests    : 11
    unRegister success     : 11
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   : 00:53:48.320 GMT Wed Oct 8 2014
    Last unregister request time : 01:44:23.052 GMT Wed Oct 8 2014
    Register success time        : 00:53:48.320 GMT Wed Oct 8 2014
    Unregister success time      : 01:44:23.052 GMT Wed Oct 8 2014
Dear Javelkur,
thanks +5 for you
the voice register pool 9 command show the phone is not upgraded but when i asked somebody to check manually the phone information, it was upgraded to 9.4
thanks for all your replies
good to know , but odd why it wont show in the cme
Jayanth Velkuri
Please send  the complete running config for gui issue , what browser are you trying , do you see any error on the browser
Please enable , deb tftp event , and send the logs for the firmware upgrade issue
