02-03-2009 12:42 PM - edited 03-15-2019 03:58 PM
Dear All,
I am using CME router 3825. I have one FXO card (4 ports) and four PSTN lines are connected to my router. I have one 7921 wireless ip phone and three 7911 ip phones.
I want all the four users to use their own FXO port assigned to them.
I have attached the running configuration of my router.
I have configured my router in such a way that I want every user to use their own FXO port for making incoming and outgoing calls. But still the router is picking random FXO ports. How can I restrict user to user their own FXO port for making incoming and outgoing calls. Any other suggestion or tip will be very helpful to me.
Following are the four PSTN numbers which i have assigned to FXO ports:
voice-port 0/1/0 = 8579210
voice-port 0/1/1 = 8573083
voice-port 0/1/2 = 8572138
voice-port 0/1/3 = 8579206
Your consideration in this regard will highly be commendable.
Thanks & Regards,
Malik.
Solved! Go to Solution.
02-21-2009 04:44 AM
The gateway configuration and CUE configuration isn't very helpful because this is all MGCP controlled.
I would suggest opening a TAC case so you can pull traces and find out what's going on.
-nick
02-22-2009 10:24 PM
Dear Mr. Nick,
Thanks for your reply. Is there any other troubleshooting tips before i open a TAC case. I will be very thankful to you.
Awaiting for your reply.
Malik.
02-22-2009 11:40 PM
Hi Malik,
I would do some test calls and track them with 'show voice call summary' and look at exactly which port you're coming in. If you can figure out how to recreate the problem, it can be solved many times faster. Right now, the problem description isn't very clear and it's very muddy to troubleshoot.
-nick
02-23-2009 06:16 AM
do you need any kind of output of show commands from my side. i will be very greatful to u if u help me to sort out this issue.
02-23-2009 06:49 AM
Unfortunately the outputs are too large for something to look at on a web forum.
I would work on figuring out exactly what the problem is, and if you can create a more clear problem statement, we will be able to better help you.
-nick
02-23-2009 11:33 AM
A clear problem statement would be like this:
CUE - cue auto attendant script intermittently working.
Like for example when somebody dials the PSTN number the AA sometimes picks the call and sometimes it does not picks the call (its keeps ringing)
Second thing is that sometimes the if you call the PSTN number, the called is picked up but there is no response from the AA.
02-23-2009 12:21 PM
Unfortunately even for a problem such as that, you will need to run a lot of debugs for a large amount of time (since you can't easily reproduce the problem)
That would be best handled by TAC.
It should be noted that if you have a custom script on the AA, and it's CUE, then TAC will not help you support the script. They will make sure that the call is getting handed off correctly, and after that the burden is on the writer of the script.
-nick
02-23-2009 12:42 PM
On the 3845, try entering the following
config t
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
Hope that helped, if so please rate.
02-23-2009 09:36 PM
Dear Mr Kenneth,
thanks for the reply...i will add these commands and will let you know about the result..thanks for your suggestion.
regards,
Malik
02-23-2009 11:37 PM
Dear Mr Kenneth,
I added the above mentioned commands. But still no luck. Any other suggestion will highly be commendable.
Malik.
02-24-2009 12:19 AM
it sounds from ur AA secripts if you have aCRS try to debug it and see if it has problem with the answer step or what ever after it
thanks
06-20-2019 08:36 AM
Despite the fact that this post is very old, but I thought the creator didn't achieve what he wanted using the translation and ended up using corlists. Anyway here is how you can achieve it:
Assuming you are using 9 for outside dialing:
Voice translation-rule 1
Rule 1 /^9\(. *\)/ /19\1/
Voice translation-rule 2
Rule 1 /^9\(. *\)/ /29\1/
Voice translation-profile phone1
Translate called 1
Voice translation-profile phone2
Translate called 2
Ephone-dn 1
Number 555
Translation-profile incoming phone1
Ephone-dn 2
Number 666
Translation-profile incoming phone2
Dial-peer voice 1 pots
Destination-pattern 19.T
Port 0/1/0
Dial-peer voice 2 pots
Destination-pattern 29.T
Port 0/1/1
