CME PRI Line (outside calls not going)
alkabeer80
Hi, i am configuring CME (2811) with PRI line for first time, i can receive call from outside (to spefic extension) but when i dial outside number it shows (unknow number)
I did show isdn status : under L2 it shows "MULTIPLE_FRAME_ESTABLISHED"
This is my config.
ip dhcp pool Voice
network 192.168.1.0 255.255.255.0
option 150 ip 192.168.1.254
default-router 192.168.1.254
isdn switch-type primary-net5
voice service voip
allow-connections h323 to sip
no supplementary-service sip handle-replaces
voice-card 0
dspfarm
dsp services dspfarm
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-10,16
interface FastEthernet0/0
description Connected to LAN
ip address 192.168.1.254 255.255.255.0
duplex auto
speed auto
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
voice-port 0/1/0:15
timeouts call-disconnect 5
timeouts wait-release 5
connection plar 201
voice-port 0/1/1:15
dial-peer voice 201 pots
destination-pattern 9[3-7].......
direct-inward-dial
port 0/1/0:15
forward-digits 8
dial-peer voice 1 pots
description all-incoming-outgoing
incoming called-number .
direct-inward-dial
port 0/1/0:15
telephony-service
max-ephones 35
max-dn 48
ip source-address 192.168.1.254 port 2000
auto assign 1 to 40
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 9
ephone-dn  1  dual-line
number 201
ephone-dn  2  dual-line
number 202
ephone  1
device-security-mode none
mac-address
button  1:1
ephone  2
mac-address
button  1:2
9 Replies 9
Chris Deren
Please post "debug isdn q931" for the call, most likely you are sending the 3 digit internal number and telco is rejecting it.  You can build a translation rule to convert the 3 digit number to a DID of the user or main number. If you let us know the DID range we can help you with building it.
HTH,
Chris
Hi Chris,
How can i do translation rule, i beleive it is sending 3 digits as u mentioned, but  i dont have access to it currently to do debug. my local number is 8 digits. what is DID ?, is there any template config. for such config ?
plz help me in this
thankssss
also is my config correct ? do i need to add anything more ?
Here is good doc on translation rules:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
You did not post full config, so I will not comment on anything missing until you post full config.
HTH, please rate all useful posts!
Chris
Hi Chris, this is my config, i am also wonderinging why should i made the dialpeer number same as ephone number and do i need to make dialpeer for each ephone ?
CISCO2811#sh run
Building configuration...
Current configuration : 8429 bytes
version 15.1
hostname CISCO2811
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
no aaa new-model
network-clock-participate wic 1
dot11 syslog
ip source-route
ip cef
ip dhcp pool Voice
no ip domain lookup
no ipv6 cef
voice service voip
voice-card 0
dspfarm
crypto pki trustpoint TP-self-signed-2563656353
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2563656353
revocation-check none
rsakeypair TP-self-signed-2563656353
crypto pki certificate chain TP-self-signed-2563656353
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32353633 36353633 3533301E 170D3133 30333138 30343033
  34305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35363336
  35363335 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BB45 EA81E9BF 28CA2553 8278303F 6CFB65AA DB5B9157 942AE85F 229CA26C
  8F98550B 78247BC3 D0C71555 06486D01 A8F1CF14 59DDC789 B553E756 97F52E8A
  1C6F084B F169D182 C7BD722A 6E3D3D82 EA4F58CD 28C42522 2FDB8F90 F6A1A344
  CF556967 72F92172 C5A71EB4 27D50F70 5A54EA07 0980EECD D258C8B3 9B5385FA
  76650203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 142337F4 C1B84035 BF31EDD9 84ACBCC8 A849671A 51301D06
  03551D0E 04160414 2337F4C1 B84035BF 31EDD984 ACBCC8A8 49671A51 300D0609
  2A864886 F70D0101 05050003 81810086 43B1FDA9 3CBD3E3F 12F5D734 3BF3EDA2
  976124EF 19364047 F2A0D46C EF188CFB 93D38252 21C45345 358BF1DF AB27FFC2
  1325B012 F69A06B3 959AD987 11C056D1 1FE823C8 538781DC 27C63C1C 0495F9A9
  E2C3B5F2 261ED2BB 7E09865D 934C273A FCC272D7 A9A50BB9 C9D0C15B 6D9074A2
  DAC6E077 F2C978D7 6C80D79C 8B4024
        quit
username admin privilege 15 password 0 admin
redundancy
controller E1 0/1/0
framing NO-CRC4
controller E1 0/1/1
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
control-plane
voice-port 0/1/0:15
connection plar 207
voice-port 0/1/1:15
mgcp profile default
dial-peer voice 937 pots
direct-inward-dial
port 0/1/0:15
forward-digits 8
direct-inward-dial
port 0/1/0:15
port 0/1/0:15
forward-digits 8
dial-peer voice 204 pots
port 0/1/0:15
forward-digits 8
dial-peer voice 207 pots
translation-profile incoming XLATE_CALLED
translation-profile outgoing profile1
port 0/1/0:15
forward-digits 8
telephony-service
max-ephones 35
max-dn 48
auto assign 1 to 40
time-zone 31
time-format 24
create cnf-files version-stamp 7960 May 07 2013 05:07:40
number 201
number 202
ephone-dn  3  dual-line
number 203
ephone-dn  4
number 204
ephone-dn  5  dual-line
number 205
ephone-dn  6  dual-line
number 206
ephone-dn  7  dual-line
number 207
ephone-dn  8  dual-line
number 208
ephone-dn  9  dual-line
number 209
ephone-dn  10  dual-line
number 210
ephone-dn  11  dual-line
number 211
ephone-dn  12  dual-line
number 212
ephone-dn  13  dual-line
number 213
ephone-dn  14  dual-line
number 214
ephone-dn  15  dual-line
number 215
ephone-dn  16  dual-line
number 216
ephone-dn  17  dual-line
number 217
ephone-dn  18  dual-line
number 218
ephone-dn  19  dual-line
number 219
ephone-dn  20  dual-line
number 220
ephone-dn  21  dual-line
number 221
ephone-dn  22  dual-line
number 222
ephone-dn  23  dual-line
number 223
ephone-dn  24  dual-line
number 224
ephone-dn  25  dual-line
number 225
ephone-dn  26  dual-line
number 226
ephone-dn  27  dual-line
number 227
ephone-dn  28  dual-line
number 228
ephone-dn  29  dual-line
number 229
ephone-dn  30  dual-line
number 230
ephone  1
mac-address 8478.ACE7.C350
type 7945
button  1:1
ephone  2
mac-address 8478.ACE7.BF21
type 7945
button  1:2
ephone  3
mac-address 8478.ACE7.C2CA
type 7945
button  1:3
ephone  4
mac-address 8478.ACE7.C3BD
type 7945
button  1:7
ephone  5
mac-address 8478.ACC7.8ABB
max-calls-per-button 2
type 6921
button  1:5
ephone  6
mac-address 7010.5C5E.3C4A
type 7942
button  1:6
ephone  7
ephone  8
ephone  9
ephone  10
ephone  11
ephone  12
ephone  13
ephone  14
ephone  15
ephone  16
ephone  17
ephone  18
ephone  19
ephone  20
ephone  21
ephone  22
ephone  23
ephone  25
ephone  26
ephone  27
ephone  28
ephone  29
ephone  30
ephone  201
ephone  204
alias exec con conf t
alias exec sib show ip int brief
alias exec srb show run | b
alias exec sri show run int
line con 0
exec-timeout 0 0
logging synchronous
login
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
Dial-peer tags have nothing to do with ephones or ephone-dns, dialpeers are global and shared by all phones unless you dont want that in which case you need to build cor lists.  Please specify what your issue besides caller ID is and what can we help you with.
Chris
Hi Chris,
issue is i canot make calls to outside, when ever i press 9 to do calls (local, mobile, or international) directly it says unknow number, but i when i dial from outside ext 207 rings normally. only outside calls not working
What number are you dialing?
"debug isdn q931" would be very helpful here.
It looks like you have a partial PRI, are you sure all 10 channels are available to you?
Chris
hi Chris,
debug isdn q931 output
CISCO2811#
*May 11 09:11:05.982: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 207
*May 11 09:11:05.982: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x0088 callID = 0x8009 switch = primary-net5 interface = User
*May 11 09:11:05.986: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0088
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838A
                Exclusive, Channel 10
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0180, '207'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '55080967'
*May 11 09:11:06.094: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8088
        Cause i = 0x829C00000000 - Invalid number format (incomplete number)
*May 11 09:11:06.110: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 207
CISCO2811#May 11 09:11:06.114: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x0089 callID = 0x800A switch = primary-net5 interface = User
*May 11 09:11:06.114: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0089
                Standard = CCITT
*May 11 09:11:06.178: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8089
*May 11 09:11:06.190: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 207
*May 11 09:11:06.194: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x008A callID = 0x800B switch = primary-net5 interface = User
*May 11 09:11:06.194: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x008A
                Standard = CCITT
*May 11 09:11:06.266: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x808A
*May 11 09:11:06.282: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 207
*May 11 09:11:06.286: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x008B callID = 0x800C switch = primary-net5 interface = User
*May 11 09:11:06.286: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x008B
                Standard = CCITT
*May 11 09:11:06.378: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x808B
CISCO2811#
CISCO2811#
CISCO2811#
                Standard = CCITT
                Standard = CCITT
                Standard = CCITT
                Standard = CCITT
CISCO2811#
CISCO2811#
