CME Progress Bar hanging
We are attempting to set up CME on a device but it keeps getting stuck on the 'Progress' Bar. This means we cannot use the thing, and currently I am unable to raise a ticket for support directly, can anyone suggest a fix, or provide a contact details for some help?
Jon Marshall
CME = Communications Manager Express ?
If so suggest moving to one of the VoIP forums as you will be more likely to get help there.
Jon
