02-02-2018 02:01 PM - edited 03-17-2019 12:06 PM
Routing and switching guy with no insight into voice, need some assistance.
I need to have 8 polycom phones setup with PBX circuit on CME router which has CUE but does not have any configuration. All phones are setup with external carrier provided dedicated voicemail number. Unanswered calls are being forwarded to VM and I have no issues with VM, except one, which is if I leave a voicemail message the phone doesn't notify (SoundPoint IP 670 - red light for MWI) the user saying that there is vm message.
I have tried below XML config on phone but did not work
<msg msg.bypassInstantMessage="1">
<mwi msg.mwi.1.subscribe="" msg.mwi.1.callBackMode="contact" msg.mwi.1.callBack="91VM#"
My question is can we have MWI with external voicemail without CUE?
Thank you
02-02-2018 02:08 PM
02-02-2018 02:13 PM
Thank you Nipun for response. We moved from one architecture to other and CUE was inherited from previous architecture, it doesn't have any configuration.
I changed the MWI part on the cfg files on tftp server but no red light indicating message wait.
Any ideas?
Thank you
02-02-2018 02:41 PM
02-02-2018 02:43 PM
Oh ok, if this the case I will contact the carrier and see if they can enable this MWI feature on their side. Will let you know once I hear from carrier.
Thanks a lot once again Nipun.
