12-18-2014 06:31 AM - edited 03-17-2019 01:22 AM
I am having issues with getting a Cisco 7821 phone to register.
Current deployment is with Cisco 6921 phones SCCP registration
SIP integration with CUE
SIP integration with Mitel system
c2951-universalk9-mz.SPA.154-3.M1.bin (CME 10.5)
In flash:
rootfs78xx.10-1-1SR1-4.sbn
kern78xx.10-1-1SR1-4.sbn
sboot78xx.10-1-1SR1-4.sbn
sip78xx.10-1-1SR1-4.loads
The 7821 phone gets IP address but fails to register. Please could somebody let me know why phone is not registering.
Configuration below (10.245.226.132 is CME address) .
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw redundancy maximum-sessions 5
h323
sip
registrar server expires max 600 min 60
options-ping 90
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice register global
mode cme
source-address 10.245.226.132 port 5060
max-dn 30
max-pool 10
load 7821 sip78xx.10-1-1SR1-4
authenticate register
authenticate realm all
timezone 22
date-format D/M/Y
voicemail 590
tftp-path flash:
create profile sync 0061443538560005
network-locale GB
voice register dn 1
number 1010
name user1
label user1
mwi
voice register pool 1
busy-trigger-per-button 2
id mac F09E.636E.63F2
type 7821
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username 1010 password 123
codec g711ulaw
no vad
dial-peer voice 391 voip
description *** Auto Attendant ***
destination-pattern 399
session protocol sipv2
session target ipv4:10.245.226.131
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 392 voip
description *** Administration Via Telephone ***
destination-pattern 392
codec g711ulaw
no vad
dial-peer voice 393 voip
description *** Extension Assigner ***
service ea out-bound
destination-pattern 393
session target ipv4:10.245.226.132
dial-peer voice 590 voip
description *** Voice Mail Pilot ***
destination-pattern 590
b2bua
codec g711ulaw
no vad
dial-peer voice 1 pots
description ** Match all incoming POTS calls **
translation-profile incoming IncomingPSTNcalls
incoming called-number .
direct-inward-dial
dial-peer voice 899 voip
description Call to Mitel
translation-profile incoming Prefix9
translation-profile outgoing rem44
destination-pattern [23]..
session target ipv4:192.168.114.2
voice-class codec 1
dtmf-relay rtp-nte
no vad
interface GigabitEthernet0/0
description *** Connection to Mitel Phone System ***
ip address 192.168.114.5 255.255.255.248
duplex auto
speed auto
interface ISM0/0
description *** Connection to Cisco Unity Express ***
ip unnumbered GigabitEthernet0/1
service-module ip address 10.245.226.131 255.255.255.128
!Application: CUE Running on ISM
service-module ip default-gateway 10.245.226.132
interface GigabitEthernet0/1
description *** Connection to IP Phone LAN ***
ip address 10.245.226.132 255.255.255.128
duplex auto
speed auto
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.245.226.129
ip route 10.245.226.131 255.255.2
tftp-server flash:apps37sccp.1-4-4-0.bin
tftp-server flash:sip78xx.10-1-1SR1-4.loads
tftp-server flash:rootfs78xx.10-1-1SR1-4.sbn
tftp-server flash:sboot78xx.10-1-1SR1-4.sbn
sip-ua
mwi-server ipv4:10.245.226.131 expires 3600 port 5060 transport udp
registrar ipv4:10.245.226.132 expires 600
gatekeeper
shutdown
telephony-service
authentication credential cmeadmin c4p1ta2012
xml user xmladmin password xmladmin 15
extension-assigner tag-type provision-tag
max-ephones 104
max-dn 299
ip source-address 10.245.226.132 port 2000
auto assign 101 to 105
no service directed-pickup
timeouts interdigit 5
system message CFGS
url services http://10.245.226.131/voiceview/common/login.do
url authentication http://10.245.226.132/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
load 7931 SCCP31.9-2-1S
load 6921 SCCP69xx.9-2-1-0
time-zone 22
date-format dd-mm-yy
voicemail 590
max-conferences 8 gain -6
call-forward pattern .T
moh enable-g711 "music-on-hold.au"
web admin system name cmeadmin secret 5 $1$QmIK$46fDKVSudMxzI2bRp/Ef7/
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 298
number 598...
mwi on
ephone-dn 299
number 599...
mwi off
Solved! Go to Solution.
12-02-2015 02:24 AM
i have already upload the file .........after that what can i do......
H-AlSAMAH-RTR01#show flash:
-#- --length-- -----date/time------ path
1 99077424 Oct 6 2014 22:09:10 +03:00 c2900-universalk9-mz.SPA.152-4.M4.bin
2 0 Dec 15 2010 21:24:04 +03:00 GUI
3 4118 Jul 19 2010 16:43:18 +03:00 GUI/admin_user.html
4 677820 Jul 19 2010 16:43:18 +03:00 GUI/admin_user.js
5 1029 Jul 19 2010 16:43:18 +03:00 GUI/CiscoLogo.gif
6 1019 Nov 29 2011 19:14:28 +03:00 GUI/CME_GUI_README.TXT
7 953 Jul 19 2010 16:43:18 +03:00 GUI/Delete.gif
8 16344 Jul 19 2010 16:43:18 +03:00 GUI/DOM.JS
9 864 Jul 19 2010 16:43:18 +03:00 GUI/downarrow.gif
10 6315 Jul 19 2010 16:43:18 +03:00 GUI/ephone_admin.html
11 4558 Jul 19 2010 16:43:18 +03:00 GUI/LOGOHOME.GIF
12 3978 Jul 19 2010 16:43:18 +03:00 GUI/normal_user.html
13 78428 Jul 19 2010 16:43:18 +03:00 GUI/normal_user.js
14 1347 Jul 19 2010 16:43:18 +03:00 GUI/Plus.gif
15 843 Jul 19 2010 16:43:18 +03:00 GUI/SXICONAD.GIF
16 174 Jul 19 2010 16:43:18 +03:00 GUI/Tab.gif
17 2496 Jul 19 2010 16:47:00 +03:00 GUI/telephony_service.html
18 870 Jul 19 2010 16:43:18 +03:00 GUI/UPARROW.GIF
19 10230 Jul 19 2010 16:43:18 +03:00 GUI/xml-test.html
20 3412 Jul 19 2010 16:43:18 +03:00 GUI/xml.template
21 8160 Aug 20 2004 10:58:00 +03:00 Analog1.raw
22 8160 Aug 20 2004 10:58:00 +03:00 Analog2.raw
23 4639974 May 13 2011 13:08:02 +03:00 apps45.9-2-1TH1-13.sbn
24 5280 Aug 20 2004 10:58:00 +03:00 AreYouThere.raw
25 5040 Aug 20 2004 10:58:00 +03:00 AreYouThereF.raw
26 8160 Aug 20 2004 10:58:00 +03:00 Bass.raw
27 12240 Aug 20 2004 10:58:00 +03:00 CallBack.raw
28 16040 Aug 20 2004 10:58:00 +03:00 Chime.raw
29 8160 Aug 20 2004 10:58:00 +03:00 Classic1.raw
30 16080 Aug 20 2004 10:58:00 +03:00 Classic2.raw
31 10800 Aug 20 2004 10:58:00 +03:00 ClockShop.raw
32 575590 May 13 2011 13:07:56 +03:00 cnu45.9-2-1TH1-13.sbn
33 2211969 May 13 2011 13:08:14 +03:00 cvm45sccp.9-2-1TH1-13.sbn
34 2823 Jul 3 2007 02:30:58 +03:00 DistinctiveRingList.xml
35 9600 Aug 20 2004 10:58:00 +03:00 Drums1.raw
36 13440 Aug 20 2004 10:58:00 +03:00 Drums2.raw
37 356907 May 13 2011 13:08:10 +03:00 dsp45.9-2-1TH1-13.sbn
38 15840 Aug 20 2004 10:58:00 +03:00 FilmScore.raw
39 16080 Aug 20 2004 10:58:00 +03:00 HarpSynth.raw
40 8160 Aug 20 2004 10:58:00 +03:00 Jamaica.raw
41 1886651 May 13 2011 13:08:12 +03:00 jar45sccp.9-2-1TH1-13.sbn
42 16080 Aug 20 2004 10:58:00 +03:00 KotoEffect.raw
43 12720 Aug 20 2004 10:58:00 +03:00 MusicBox.raw
44 496521 May 6 2015 17:34:56 +03:00 music-on-hold.au
45 8160 Aug 20 2004 10:58:00 +03:00 Piano1.raw
46 15360 Aug 20 2004 10:58:00 +03:00 Piano2.raw
47 9360 Aug 20 2004 10:58:00 +03:00 Pop.raw
48 7200 Aug 20 2004 10:58:00 +03:00 Pulse1.raw
49 4000 Aug 20 2004 10:58:00 +03:00 Ring1.raw
50 4000 Aug 20 2004 10:58:00 +03:00 Ring2.raw
51 4000 Aug 20 2004 10:58:00 +03:00 Ring3.raw
52 4000 Aug 20 2004 10:58:00 +03:00 Ring4.raw
53 4000 Aug 20 2004 10:58:00 +03:00 Ring5.raw
54 4000 Aug 20 2004 10:58:00 +03:00 Ring6.raw
55 4000 Aug 20 2004 10:58:00 +03:00 Ring7.raw
56 495 Mar 17 2006 04:27:34 +03:00 RingList.xml
57 10800 Aug 20 2004 10:58:00 +03:00 Sax1.raw
58 14160 Aug 20 2004 10:58:00 +03:00 Sax2.raw
59 656 May 13 2011 13:07:34 +03:00 SCCP45.9-2-1S.loads
60 660 May 13 2011 13:07:40 +03:00 term45.default.loads
61 660 May 13 2011 13:07:48 +03:00 term65.default.loads
62 16080 Aug 20 2004 10:58:00 +03:00 Vibe.raw
63 23123 Apr 12 2015 13:44:32 +03:00 startup-config
64 45308 May 6 2015 16:04:18 +03:00 BOOT69xx.0-0-0-14.zz.sgn
65 226112 May 6 2015 16:04:32 +03:00 DSP69xx.0-0-0-11-124120.zz.sgn
66 489 May 6 2015 16:04:42 +03:00 SCCP69xx.9-2-4-3.loads
67 2762328 May 6 2015 16:05:00 +03:00 SCCP69xx.9-2-4-3.zz.sgn
68 0 May 6 2015 16:42:08 +03:00 its
69 0 May 6 2015 16:42:08 +03:00 its/vrf1
70 3483 May 6 2015 16:42:12 +03:00 its/vrf1/XMLDefault.cnf.xml
71 1413 May 6 2015 16:42:12 +03:00 its/vrf1/XMLDefault6921.cnf.xml
72 107 May 6 2015 16:45:50 +03:00 its/SEPDEFAULT.cnf
73 518 May 6 2015 16:45:50 +03:00 its/vrf1/XMLDefault7902.cnf.xml
74 1017 May 6 2015 16:45:52 +03:00 its/vrf1/XMLDefault7905.cnf.xml
75 1304 May 6 2015 16:45:52 +03:00 its/vrf1/XMLDefault7906.cnf.xml
76 604 May 6 2015 16:45:52 +03:00 its/vrf1/XMLDefault7910.cnf.xml
77 1304 May 6 2015 16:45:52 +03:00 its/vrf1/XMLDefault7911.cnf.xml
78 1017 May 6 2015 16:45:54 +03:00 its/vrf1/XMLDefault7912.cnf.xml
79 1017 May 6 2015 16:45:54 +03:00 its/vrf1/XMLDefault7920.cnf.xml
80 1230 May 6 2015 16:45:54 +03:00 its/vrf1/XMLDefault7921.cnf.xml
81 1266 May 6 2015 16:45:54 +03:00 its/vrf1/XMLDefault7925.cnf.xml
82 1304 May 6 2015 16:45:54 +03:00 its/vrf1/XMLDefault7931.cnf.xml
83 553 May 6 2015 16:45:56 +03:00 its/vrf1/XMLDefault7935.cnf.xml
84 553 May 6 2015 16:45:56 +03:00 its/vrf1/XMLDefault7936.cnf.xml
85 1304 May 6 2015 16:45:56 +03:00 its/vrf1/XMLDefault7937.cnf.xml
86 1112 May 6 2015 16:45:56 +03:00 its/vrf1/XMLDefault7940.cnf.xml
87 1274 May 6 2015 16:45:58 +03:00 its/vrf1/XMLDefault7940-7914-1.cnf.xml
88 1274 May 6 2015 16:45:58 +03:00 its/vrf1/XMLDefault7940-7915-12-1.cnf. xml
89 1274 May 6 2015 16:45:58 +03:00 its/vrf1/XMLDefault7940-7915-24-1.cnf. xml
90 1274 May 6 2015 16:45:58 +03:00 its/vrf1/XMLDefault7940-7916-12-1.cnf. xml
91 1274 May 6 2015 16:45:58 +03:00 its/vrf1/XMLDefault7940-7916-24-1.cnf. xml
92 1405 May 6 2015 16:46:00 +03:00 its/vrf1/XMLDefault7940-7914-2.cnf.xml
93 1405 May 6 2015 16:46:00 +03:00 its/vrf1/XMLDefault7940-7915-12-2.cnf. xml
94 1405 May 6 2015 16:46:00 +03:00 its/vrf1/XMLDefault7940-7915-24-2.cnf. xml
95 1405 May 6 2015 16:46:00 +03:00 its/vrf1/XMLDefault7940-7916-12-2.cnf. xml
96 1405 May 6 2015 16:46:02 +03:00 its/vrf1/XMLDefault7940-7916-24-2.cnf. xml
97 1304 May 6 2015 16:46:02 +03:00 its/vrf1/XMLDefault7941.cnf.xml
98 1306 May 6 2015 16:46:02 +03:00 its/vrf1/XMLDefault7941GE.cnf.xml
99 1304 May 6 2015 16:46:02 +03:00 its/vrf1/XMLDefault7942.cnf.xml
100 1318 May 6 2015 16:46:02 +03:00 its/vrf1/XMLDefault7945.cnf.xml
101 1112 May 6 2015 16:46:04 +03:00 its/vrf1/XMLDefault7960.cnf.xml
102 1274 May 6 2015 16:46:04 +03:00 its/vrf1/XMLDefault7960-7914-1.cnf.xml
103 1274 May 6 2015 16:46:04 +03:00 its/vrf1/XMLDefault7960-7915-12-1.cnf.xml
104 1274 May 6 2015 16:46:04 +03:00 its/vrf1/XMLDefault7960-7915-24-1.cnf.xml
105 1274 May 6 2015 16:46:06 +03:00 its/vrf1/XMLDefault7960-7916-12-1.cnf.xml
106 1274 May 6 2015 16:46:06 +03:00 its/vrf1/XMLDefault7960-7916-24-1.cnf.xml
107 1405 May 6 2015 16:46:06 +03:00 its/vrf1/XMLDefault7960-7914-2.cnf.xml
108 1405 May 6 2015 16:46:06 +03:00 its/vrf1/XMLDefault7960-7915-12-2.cnf.xml
109 1405 May 6 2015 16:46:08 +03:00 its/vrf1/XMLDefault7960-7915-24-2.cnf.xml
110 1405 May 6 2015 16:46:08 +03:00 its/vrf1/XMLDefault7960-7916-12-2.cnf.xml
111 1405 May 6 2015 16:46:08 +03:00 its/vrf1/XMLDefault7960-7916-24-2.cnf.xml
112 1304 May 6 2015 16:46:08 +03:00 its/vrf1/XMLDefault7961.cnf.xml
113 1466 May 6 2015 16:46:10 +03:00 its/vrf1/XMLDefault7961-7914-1.cnf.xml
114 1466 May 6 2015 16:46:10 +03:00 its/vrf1/XMLDefault7961-7915-12-1.cnf.xml
115 1466 May 6 2015 16:46:10 +03:00 its/vrf1/XMLDefault7961-7915-24-1.cnf.xml
116 1466 May 6 2015 16:46:10 +03:00 its/vrf1/XMLDefault7961-7916-12-1.cnf.xml
117 1466 May 6 2015 16:46:10 +03:00 its/vrf1/XMLDefault7961-7916-24-1.cnf.xml
118 1597 May 6 2015 16:46:12 +03:00 its/vrf1/XMLDefault7961-7914-2.cnf.xml
119 1597 May 6 2015 16:46:12 +03:00 its/vrf1/XMLDefault7961-7915-12-2.cnf.xml
120 1597 May 6 2015 16:46:12 +03:00 its/vrf1/XMLDefault7961-7915-24-2.cnf.xml
121 1597 May 6 2015 16:46:12 +03:00 its/vrf1/XMLDefault7961-7916-12-2.cnf.xml
122 1597 May 6 2015 16:46:14 +03:00 its/vrf1/XMLDefault7961-7916-24-2.cnf.xml
123 1306 May 6 2015 16:46:14 +03:00 its/vrf1/XMLDefault7961GE.cnf.xml
124 1468 May 6 2015 16:46:14 +03:00 its/vrf1/XMLDefault7961GE-7914-1.cnf.xml
125 1468 May 6 2015 16:46:14 +03:00 its/vrf1/XMLDefault7961GE-7915-12-1.cnf.xml
126 1468 May 6 2015 16:46:16 +03:00 its/vrf1/XMLDefault7961GE-7915-24-1.cnf.xml
127 1468 May 6 2015 16:46:16 +03:00 its/vrf1/XMLDefault7961GE-7916-12-1.cnf.xml
128 1468 May 6 2015 16:46:16 +03:00 its/vrf1/XMLDefault7961GE-7916-24-1.cnf.xml
129 1599 May 6 2015 16:46:16 +03:00 its/vrf1/XMLDefault7961GE-7914-2.cnf.xml
130 1599 May 6 2015 16:46:16 +03:00 its/vrf1/XMLDefault7961GE-7915-12-2.cnf.xml
131 1599 May 6 2015 16:46:18 +03:00 its/vrf1/XMLDefault7961GE-7915-24-2.cnf.xml
132 1599 May 6 2015 16:46:18 +03:00 its/vrf1/XMLDefault7961GE-7916-12-2.cnf.xml
133 1599 May 6 2015 16:46:18 +03:00 its/vrf1/XMLDefault7961GE-7916-24-2.cnf.xml
134 1304 May 6 2015 16:46:18 +03:00 its/vrf1/XMLDefault7962.cnf.xml
135 1466 May 6 2015 16:46:20 +03:00 its/vrf1/XMLDefault7962-7914-1.cnf.xml
136 1466 May 6 2015 16:46:20 +03:00 its/vrf1/XMLDefault7962-7915-12-1.cnf.xml
137 1466 May 6 2015 16:46:20 +03:00 its/vrf1/XMLDefault7962-7915-24-1.cnf.xml
138 1466 May 6 2015 16:46:20 +03:00 its/vrf1/XMLDefault7962-7916-12-1.cnf.xml
139 1466 May 6 2015 16:46:22 +03:00 its/vrf1/XMLDefault7962-7916-24-1.cnf.xml
140 1597 May 6 2015 16:46:22 +03:00 its/vrf1/XMLDefault7962-7914-2.cnf.xml
141 1597 May 6 2015 16:46:22 +03:00 its/vrf1/XMLDefault7962-7915-12-2.cnf.xml
142 1597 May 6 2015 16:46:22 +03:00 its/vrf1/XMLDefault7962-7915-24-2.cnf.xml
143 1597 May 6 2015 16:46:24 +03:00 its/vrf1/XMLDefault7962-7916-12-2.cnf.xml
144 1597 May 6 2015 16:46:24 +03:00 its/vrf1/XMLDefault7962-7916-24-2.cnf.xml
145 1304 May 6 2015 16:46:24 +03:00 its/vrf1/XMLDefault7965.cnf.xml
146 1466 May 6 2015 16:46:24 +03:00 its/vrf1/XMLDefault7965-7914-1.cnf.xml
147 1466 May 6 2015 16:46:26 +03:00 its/vrf1/XMLDefault7965-7915-12-1.cnf.xml
148 1466 May 6 2015 16:46:26 +03:00 its/vrf1/XMLDefault7965-7915-24-1.cnf.xml
149 1466 May 6 2015 16:46:26 +03:00 its/vrf1/XMLDefault7965-7916-12-1.cnf.xml
150 1466 May 6 2015 16:46:26 +03:00 its/vrf1/XMLDefault7965-7916-24-1.cnf.xml
151 1597 May 6 2015 16:46:28 +03:00 its/vrf1/XMLDefault7965-7914-2.cnf.xml
152 1597 May 6 2015 16:46:28 +03:00 its/vrf1/XMLDefault7965-7915-12-2.cnf.xml
153 1597 May 6 2015 16:46:28 +03:00 its/vrf1/XMLDefault7965-7915-24-2.cnf.xml
154 1597 May 6 2015 16:46:28 +03:00 its/vrf1/XMLDefault7965-7916-12-2.cnf.xml
155 1597 May 6 2015 16:46:30 +03:00 its/vrf1/XMLDefault7965-7916-24-2.cnf.xml
156 1304 May 6 2015 16:46:30 +03:00 its/vrf1/XMLDefault7970.cnf.xml
157 1466 May 6 2015 16:46:30 +03:00 its/vrf1/XMLDefault7970-7914-1.cnf.xml
158 1466 May 6 2015 16:46:30 +03:00 its/vrf1/XMLDefault7970-7915-12-1.cnf.xml
159 1466 May 6 2015 16:46:32 +03:00 its/vrf1/XMLDefault7970-7915-24-1.cnf.xml
160 1466 May 6 2015 16:46:32 +03:00 its/vrf1/XMLDefault7970-7916-12-1.cnf.xml
161 1466 May 6 2015 16:46:32 +03:00 its/vrf1/XMLDefault7970-7916-24-1.cnf.xml
162 1597 May 6 2015 16:46:32 +03:00 its/vrf1/XMLDefault7970-7914-2.cnf.xml
163 1597 May 6 2015 16:46:34 +03:00 its/vrf1/XMLDefault7970-7915-12-2.cnf.xml
164 1597 May 6 2015 16:46:34 +03:00 its/vrf1/XMLDefault7970-7915-24-2.cnf.xml
165 1597 May 6 2015 16:46:34 +03:00 its/vrf1/XMLDefault7970-7916-12-2.cnf.xml
166 1597 May 6 2015 16:46:34 +03:00 its/vrf1/XMLDefault7970-7916-24-2.cnf.xml
167 1304 May 6 2015 16:46:36 +03:00 its/vrf1/XMLDefault7971.cnf.xml
168 1466 May 6 2015 16:46:36 +03:00 its/vrf1/XMLDefault7971-7914-1.cnf.xml
169 1466 May 6 2015 16:46:36 +03:00 its/vrf1/XMLDefault7971-7915-12-1.cnf.xml
170 1466 May 6 2015 16:46:36 +03:00 its/vrf1/XMLDefault7971-7915-24-1.cnf.xml
171 1466 May 6 2015 16:46:38 +03:00 its/vrf1/XMLDefault7971-7916-12-1.cnf.xml
172 1466 May 6 2015 16:46:38 +03:00 its/vrf1/XMLDefault7971-7916-24-1.cnf.xml
173 1597 May 6 2015 16:46:38 +03:00 its/vrf1/XMLDefault7971-7914-2.cnf.xml
174 1597 May 6 2015 16:46:40 +03:00 its/vrf1/XMLDefault7971-7915-12-2.cnf.xml
175 1597 May 6 2015 16:46:40 +03:00 its/vrf1/XMLDefault7971-7915-24-2.cnf.xml
176 1597 May 6 2015 16:46:40 +03:00 its/vrf1/XMLDefault7971-7916-12-2.cnf.xml
177 1597 May 6 2015 16:46:42 +03:00 its/vrf1/XMLDefault7971-7916-24-2.cnf.xml
178 1304 May 6 2015 16:46:42 +03:00 its/vrf1/XMLDefault7975.cnf.xml
179 1466 May 6 2015 16:46:42 +03:00 its/vrf1/XMLDefault7975-7914-1.cnf.xml
180 1466 May 6 2015 16:46:42 +03:00 its/vrf1/XMLDefault7975-7915-12-1.cnf.xml
181 1466 May 6 2015 16:46:44 +03:00 its/vrf1/XMLDefault7975-7915-24-1.cnf.xml
182 1466 May 6 2015 16:46:44 +03:00 its/vrf1/XMLDefault7975-7916-12-1.cnf.xml
183 1466 May 6 2015 16:46:44 +03:00 its/vrf1/XMLDefault7975-7916-24-1.cnf.xml
184 1597 May 6 2015 16:46:44 +03:00 its/vrf1/XMLDefault7975-7914-2.cnf.xml
185 1597 May 6 2015 16:46:46 +03:00 its/vrf1/XMLDefault7975-7915-12-2.cnf.xml
186 1597 May 6 2015 16:46:46 +03:00 its/vrf1/XMLDefault7975-7915-24-2.cnf.xml
187 1597 May 6 2015 16:46:46 +03:00 its/vrf1/XMLDefault7975-7916-12-2.cnf.xml
188 1597 May 6 2015 16:46:46 +03:00 its/vrf1/XMLDefault7975-7916-24-2.cnf.xml
189 1304 May 6 2015 16:46:48 +03:00 its/vrf1/XMLDefault7985.cnf.xml
190 405 May 6 2015 16:46:48 +03:00 its/vrf1/ATADefault.cnf.xml
191 1268 May 6 2015 16:46:48 +03:00 its/vrf1/XMLDefaultCIPC.cnf.xml
192 1397 May 6 2015 16:46:50 +03:00 its/vrf1/XMLDefault6941.cnf.xml
193 1397 May 6 2015 16:46:50 +03:00 its/vrf1/XMLDefault6961.cnf.xml
194 1397 May 6 2015 16:46:50 +03:00 its/vrf1/XMLDefault6901.cnf.xml
195 1397 May 6 2015 16:46:50 +03:00 its/vrf1/XMLDefault6911.cnf.xml
196 1266 May 6 2015 16:46:52 +03:00 its/vrf1/XMLDefault7926.cnf.xml
197 1397 May 6 2015 16:46:52 +03:00 its/vrf1/XMLDefault6945.cnf.xml
198 1397 May 6 2015 16:46:52 +03:00 its/vrf1/XMLDefault8941.cnf.xml
199 1397 May 6 2015 16:46:52 +03:00 its/vrf1/XMLDefault8945.cnf.xml
200 903 May 6 2015 16:46:54 +03:00 its/united_states_7960-tones.xml
201 8777 May 6 2015 16:46:54 +03:00 its/united_states_7960-font.xml
202 1313 May 6 2015 16:46:54 +03:00 its/united_states_7960-kate.xml
203 19750 May 6 2015 16:46:54 +03:00 its/united_states_7960-dictionary.xml
204 2740 May 6 2015 16:46:56 +03:00 its/united_states_SCCP-dictionary.xml
205 1479 May 6 2015 16:59:48 +03:00 its/vrf1/SEPC40ACBE01AC4.cnf.xml
206 593920 May 6 2015 17:34:38 +03:00 cucme-mlpp.tar
207 0 May 6 2015 17:35:44 +03:00 cucme-mlpp
208 1755 May 6 2015 17:35:44 +03:00 cucme-mlpp/cucme-mlpp-readme.txt
209 0 May 6 2015 17:35:44 +03:00 cucme-mlpp/G729
210 8532 May 6 2015 17:35:46 +03:00 cucme-mlpp/G729/ATQA.wav
211 9052 May 6 2015 17:35:46 +03:00 cucme-mlpp/G729/BNEA.wav
212 7612 May 6 2015 17:35:46 +03:00 cucme-mlpp/G729/BPA.wav
213 10872 May 6 2015 17:35:46 +03:00 cucme-mlpp/G729/ICA.wav
214 8062 May 6 2015 17:35:48 +03:00 cucme-mlpp/G729/PALA.wav
215 9312 May 6 2015 17:35:48 +03:00 cucme-mlpp/G729/UPA.wav
216 9282 May 6 2015 17:35:48 +03:00 cucme-mlpp/G729/VCA.wav
217 0 May 6 2015 17:35:48 +03:00 cucme-mlpp/G711AU
218 68980 May 6 2015 17:35:48 +03:00 cucme-mlpp/G711AU/ATQA.au
219 73090 May 6 2015 17:35:50 +03:00 cucme-mlpp/G711AU/BNEA.au
220 61550 May 6 2015 17:35:50 +03:00 cucme-mlpp/G711AU/BPA.au
221 87706 May 6 2015 17:35:50 +03:00 cucme-mlpp/G711AU/ICA.au
222 65165 May 6 2015 17:35:50 +03:00 cucme-mlpp/G711AU/PALA.au
223 75199 May 6 2015 17:35:52 +03:00 cucme-mlpp/G711AU/UPA.au
224 74976 May 6 2015 17:35:52 +03:00 cucme-mlpp/G711AU/VCA.au
225 1588 Aug 25 2015 18:58:18 +03:00 its/vrf1/SEP44ADD9BC0E5A.cnf.xml
226 1588 Aug 25 2015 19:00:06 +03:00 its/vrf1/SEP44ADD9BC0E8E.cnf.xml
227 1588 Aug 25 2015 19:00:22 +03:00 its/vrf1/SEP44ADD9BC0B71.cnf.xml
228 1588 Aug 25 2015 19:00:32 +03:00 its/vrf1/SEP44ADD9BC0AB7.cnf.xml
229 1588 Aug 25 2015 19:00:46 +03:00 its/vrf1/SEP44ADD9BC0DCE.cnf.xml
230 1588 Aug 25 2015 19:00:58 +03:00 its/vrf1/SEP44ADD9BC0AB8.cnf.xml
231 2511358 Nov 19 2015 15:44:10 +03:00 kern2.78xx.10-3-1-12.sbn
232 3092888 Nov 19 2015 15:44:48 +03:00 kern78xx.10-3-1-12.sbn
233 41419092 Nov 19 2015 15:46:54 +03:00 rootfs2.78xx.10-3-1-12.sbn
234 39321936 Nov 19 2015 15:49:02 +03:00 rootfs78xx.10-3-1-12.sbn
235 596536 Nov 19 2015 15:49:24 +03:00 sboot2.78xx.10-3-1-12.sbn
236 370348 Nov 19 2015 15:49:46 +03:00 sboot78xx.10-3-1-12.sbn
237 1206 Nov 19 2015 15:50:06 +03:00 sip78xx.10-3-1-12.loads
53772288 bytes available (202715136 bytes used)
12-02-2015 03:18 AM
Dear zaidysharib
Did you do the step above???
what is the result of the debugs bellow
debug ccsip messages
debug tftp events
Note that you mast do it when the phone tries to register
Best Regards
ART
12-02-2015 05:44 AM
but the problem of router ios 15.2 upgrade to 15.4
but still error (REGISTERING)
12-02-2015 05:50 AM
Hi zaidysharib
Did you had problems to issue the commands???
If not... try to debug to see the problem
debug tftp events
Best Regards
ART
12-02-2015 11:57 PM
if i will run this command any pronblem in exist phone because i am working in live senario and i have a little bit knwledege about voice
debug tftp events
12-03-2015 01:18 AM
Dear zaidysharib
For debug command you will not cause any problem, debug is for diagnostic propose.
feel free to debug, sure you will not have problem with this...
debug tftp events
After this
undebug all
Best Regards
ART
01-14-2016 03:58 AM
i am using 7821 cisco phones some of the phone is working well but
some are registered but not able to make any call it give busy tone if i am trying to call on any other extension or out side. forexample i am facing issue with pool 4 can you help in this regard
! Last configuration change at 15:35:39 gmt Wed Jan 13 2016 by admin
! NVRAM config last updated at 14:19:31 gmt Tue Jan 12 2016 by admin
version 15.4
service password-encryption
hostname APSG_CME
boot-start-marker
boot system flash:c2951-universalk9-mz.SPA.154-3.M1.bin
boot-end-marker
logging buffered 500000
no logging console
no logging monitor
enable secret 5 $1$MK0X$bCaR7Ro5BVqMDyIZv.GaN/
enable password 7 132407560C2C567A7A71
no aaa new-model
clock timezone gmt 3 0
ip dhcp excluded-address 192.168.10.1 192.168.10.50
ip dhcp excluded-address 192.168.20.1 192.168.20.50
ip dhcp excluded-address 192.168.50.0 192.168.50.254
ip dhcp pool DATA
network 192.168.10.0 255.255.255.0
default-router 192.168.10.5
dns-server 192.168.50.2 192.168.50.3
lease 2
ip dhcp pool VOICE
network 192.168.20.0 255.255.255.0
default-router 192.168.20.5
option 150 ip 192.168.20.5
ip dhcp pool SERVERS
network 192.168.50.0 255.255.255.0
default-router 192.168.50.1
ip cef
no ipv6 cef
trunk group STC
trunk group LOCAL
cts logging verbose
voice-card 0
voice service voip
dtmf-interworking rtp-nte
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
video screening
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class codec 222
codec preference 1 g729r8
voice class dualtone-detect-params 1
freq-min-power 35
freq-power-twist 15
cadence-variation 20
voice class dualtone-detect-params 60
freq-max-deviation 30
freq-max-power 15
freq-min-power 35
freq-power-twist 10
voice class custom-cptone cptone
dualtone disconnect
frequency 425
cadence 350 350
voice class custom-cptone STC
dualtone disconnect
frequency 420 435
cadence 255 245
voice class custom-cptone SA-CUSTOM
dualtone disconnect
frequency 425
cadence 250 250
voice class custom-cptone SA-TEST1
dualtone disconnect
frequency 406
cadence 500 500
voice class custom-cptone Disconnect
dualtone disconnect
frequency 420 420
cadence 251 255 245 250 249 250 250 250
voice register pool-type 8831
description Conference Phone 8831
mode cme
source-address 192.168.20.5 port 5060
max-dn 100
max-pool 100
load 7821 sip78xx.10-1-1SR1-4.loads
timezone 31
date-format D/M/Y
hold-alert
mwi stutter
mwi reg-e164
call-forward system redirecting-expanded
tftp-path flash:
create profile sync 2030695500558474
camera
video
voice register dn 1
number 1001
name Mahmoud Salama
voice register dn 2
number 1002
name Abdul Rauf
voice register dn 3
number 1003
name Saad
voice register dn 4
number 1004
name Syed Nehal Ahmed
voice register dn 5
number 1005
name Nasser Faramaway
voice register dn 6
number 1006
name Mohamed Kamran
voice register dn 7
number 1007
name Raheel Adeeb Bakhsh
voice register dn 8
number 1008
name Emad Mansour
voice register dn 9
number 1009
name Mohammad Nosser
voice register dn 10
number 1010
name Mohamed Gamal
voice register dn 11
number 1011
name Phone 11
voice register dn 12
number 1012
name Abdullah Khalifa
voice register dn 13
number 1013
name Ahmed Mohammad Sulaiman
voice register dn 14
number 1014
name Moataz Talaat
voice register dn 15
number 1015
name Salah Ghallab
voice register dn 16
number 1016
name Rayan AlOwedi
voice register dn 17
number 1017
name Sultan AL Jabri
voice register dn 18
number 1018
name Ahmed Abbas
voice register dn 19
number 1019
name Abbas Bawazeer
voice register dn 20
number 1020
name Adham AbuSarhad
voice register dn 21
number 1021
name Ahmed Al Sherbiny
voice register dn 22
number 1022
name Shafiq Ahmed
voice register dn 23
number 1023
name Abdul Moniem Mukhtar Ahmed
voice register dn 24
number 1024
name Phone24
voice register dn 25
number 1025
name Saif Ul Islam
voice register dn 26
number 1026
name Aboda AbdulAziz
voice register dn 27
number 1027
name Muhammad Shabana
voice register dn 28
number 1028
name Turki AbuRas
voice register dn 29
number 1029
call-forward b2bua all 1032
name CS-4
voice register dn 30
number 1030
name Musaab Abdu Saeed
voice register dn 31
number 1031
name Elham AbuSarhad
voice register dn 32
number 1032
name CS-1
voice register dn 33
number 1033
name Anas Yehya Omar Aldawelah
voice register dn 34
number 1034
name Sultan Khudari
voice register dn 35
number 1035
name Hani Bin Anas
voice register dn 50
number 1050
name Conference Phone
voice register dn 51
number 1051
name Israa Muhammad
voice register dn 52
number 1052
name Leila Alothman
voice register dn 53
number 1053
name Shaimaa Salim
voice register dn 54
number 1054
name Alaa Elden Waheeb
voice register dn 55
number 1055
name Ahmed Hamdi
voice register dn 56
number 1056
name Loay Labani
voice register dn 57
number 1057
name Mehreen Tanveer
voice register dn 58
number 1058
name Israa Fatta
voice register dn 59
number 1059
name Abdul Rehman AL-Khaldi
voice register dn 60
number 1060
name Ali AbuSarhad
voice register dn 61
number 1061
name Ahmed Alwi
voice register dn 62
number 1062
name Ahmed Rafaai
voice register dn 63
number 1063
name Khalid Alamer
voice register dn 64
number 1064
name Ziyad Muhammad
voice register dn 65
number 1065
name Mohammad Rashed
voice register dn 66
number 1066
name Nayef Al Thaghafi
voice register dn 67
number 1067
name Rabee Saleem
voice register template 1
pin 12345
busy-trigger-per-button 1
id mac 381C.1ABB.FFB6
type 9951
number 1 dn 1
dtmf-relay rtp-nte
username cisco1 password 1001
description M.Salama
codec g711ulaw
conference add-mode creator
voice register pool 2
id mac 381C.1ABB.FAE2
type 9951
number 1 dn 2
dtmf-relay rtp-nte
username cisco2 password 1002
description A Rauf
codec g711ulaw
voice register pool 3
id mac 381C.1ABB.FADE
type 9951
number 1 dn 3
dtmf-relay rtp-nte
username cisco3 password 1003
description Saad
codec g711ulaw
voice register pool 4
id mac 544A.0037.1350
type 7821
number 1 dn 4
dtmf-relay rtp-nte
username cisco4 password 1004
description Syed Nehal
codec g711ulaw
voice register pool 5
id mac 544A.0037.3085
type 7821
number 1 dn 5
dtmf-relay rtp-nte
username cisco5 password 1005
description N Faramaway
codec g711ulaw
voice register pool 6
id mac 544A.0037.1336
type 7821
number 1 dn 6
dtmf-relay rtp-nte
username cisco6 password 1006
description M.Kamran
codec g711ulaw
voice register pool 7
id mac 544A.0037.302A
type 7821
number 1 dn 7
dtmf-relay rtp-nte
username cisco7 password 1007
description Raheel
codec g711ulaw
voice register pool 8
id mac 544A.0037.13A8
type 7821
number 1 dn 8
dtmf-relay rtp-nte
username cisco8 password 1008
description Emad
codec g711ulaw
voice register pool 9
id mac 544A.0037.13BE
type 7821
number 1 dn 9
dtmf-relay rtp-nte
username cisco9 password 1009
description M Nosser
codec g711ulaw
voice register pool 10
pin 12345
id mac 544A.0037.1339
type 7821
number 1 dn 10
dtmf-relay rtp-nte
username cisco10 password 1010
description M-Gamal
codec g711ulaw
voice register pool 11
id mac 544A.0037.2FD8
type 7821
number 1 dn 11
dtmf-relay rtp-nte
username cisco11 password 1011
description Phone 11
codec g711ulaw
voice register pool 12
id mac 544A.0037.12FC
type 7821
number 1 dn 12
dtmf-relay rtp-nte
username cisco12 password 1012
description A Khalifa
codec g711ulaw
voice register pool 13
id mac 544A.0037.2FD9
type 7821
number 1 dn 13
dtmf-relay rtp-nte
username cisco13 password 1013
description Ahmed
codec g711ulaw
voice register pool 14
id mac 544A.0037.131B
type 7821
number 1 dn 14
dtmf-relay rtp-nte
username cisco14 password 1014
description Moataz
codec g711ulaw
voice register pool 15
id mac 544A.0037.133D
type 7821
number 1 dn 15
dtmf-relay rtp-nte
username cisco15 password 1015
description S Ghallab
codec g711ulaw
voice register pool 16
id mac 544A.0037.1314
type 7821
number 1 dn 16
dtmf-relay rtp-nte
username cisco16 password 1016
description Rayan
codec g711ulaw
voice register pool 17
id mac 544A.0037.3032
type 7821
number 1 dn 17
dtmf-relay rtp-nte
username cisco17 password 1017
description Sultan
codec g711ulaw
voice register pool 18
id mac 544A.0037.1340
type 7821
number 1 dn 18
dtmf-relay rtp-nte
username cisco18 password 1018
description Ahmed Abbas
codec g711ulaw
voice register pool 19
id mac 544A.0037.1560
type 7821
number 1 dn 19
dtmf-relay rtp-nte
username cisco19 password 1019
description A Bawazeer
codec g711ulaw
voice register pool 20
id mac 544A.0037.1301
type 7821
number 1 dn 20
dtmf-relay rtp-nte
username cisco20 password 1020
description Adham
codec g711ulaw
voice register pool 21
id mac 544A.0037.139B
type 7821
number 1 dn 21
dtmf-relay rtp-nte
username cisco21 password 1021
description A Sherbiny
codec g711ulaw
voice register pool 22
id mac 544A.0037.3038
type 7821
number 1 dn 22
dtmf-relay rtp-nte
username cisco22 password 1022
description Shafiq
codec g711ulaw
voice register pool 23
id mac 544A.0037.302E
type 7821
number 1 dn 23
dtmf-relay rtp-nte
username cisco23 password 1023
description Abdulmoniem
codec g711ulaw
voice register pool 24
pin 1024
id mac C472.95A8.A618
type 7821
number 1 dn 24
dtmf-relay rtp-nte
username cisco24 password 1024
description Phone24
codec g711ulaw
voice register pool 25
id mac C472.95A8.A315
type 7821
number 1 dn 25
dtmf-relay rtp-nte
username cisco25 password 1025
description Saif
codec g711ulaw
voice register pool 26
id mac C472.95A8.A5E0
type 7821
number 1 dn 26
dtmf-relay rtp-nte
username cisco26 password 1026
description Aboda
codec g711ulaw
voice register pool 27
id mac C472.95A8.A5C7
type 7821
number 1 dn 27
dtmf-relay rtp-nte
username cisco27 password 1027
description M Shabana
codec g711ulaw
voice register pool 28
id mac C472.95A8.A5E9
type 7821
number 1 dn 28
dtmf-relay rtp-nte
username cisco28 password 1028
description Turki
codec g711ulaw
voice register pool 29
id mac C472.95A8.A560
type 7821
number 1 dn 29
dtmf-relay rtp-nte
username cisco29 password 1029
description CS-4
codec g711ulaw
voice register pool 30
id mac C472.95A8.A2E6
type 7821
number 1 dn 30
dtmf-relay rtp-nte
username cisco30 password 1030
description Musab
codec g711ulaw
voice register pool 31
pin 12345
id mac C472.95A8.A57B
type 7821
number 1 dn 31
dtmf-relay rtp-nte
username cisco31 password 1031
description ELHAM
codec g711ulaw
voice register pool 32
pin 12345
id mac C472.95A8.A5AE
type 7821
number 1 dn 32
dtmf-relay rtp-nte
username cisco32 password 1032
description CS-1
codec g711ulaw
voice register pool 33
id mac B07D.47D1.E0BF
type 7821
number 1 dn 33
dtmf-relay rtp-nte
username cisco33 password 1033
description Anas Yehya
codec g711ulaw
voice register pool 34
id mac B07D.47D1.E35B
type 7821
number 1 dn 34
dtmf-relay rtp-nte
username cisco34 password 1034
description Sultan
codec g711ulaw
voice register pool 35
id mac B07D.47D1.E366
type 7821
number 1 dn 35
dtmf-relay rtp-nte
username cisco35 password 1035
description Hani
codec g711ulaw
voice register pool 50
busy-trigger-per-button 4
id mac AC44.F210.F2A0
type 8831
number 1 dn 50
dtmf-relay rtp-nte
username 1050 password 1050
codec g711ulaw
no vad
camera
video
voice register pool 51
id mac C472.95A8.A567
type 7821
number 1 dn 51
dtmf-relay rtp-nte
username cisco51 password 1051
description Israa
codec g711ulaw
voice register pool 52
pin 1052
id mac C472.95A8.A5DA
type 7821
number 1 dn 52
dtmf-relay rtp-nte
username cisco52 password 1052
description Leila
codec g711ulaw
voice register pool 53
pin 1053
id mac C472.95A8.A600
type 7821
number 1 dn 53
dtmf-relay rtp-nte
username cisco53 password 1053
description Shaimaa
codec g711ulaw
voice register pool 54
pin 1054
id mac C472.95A8.A5D5
type 7821
number 1 dn 54
dtmf-relay rtp-nte
username cisco54 password 1054
description Alaa Elden
codec g711ulaw
voice register pool 55
pin 1055
id mac C472.95A8.A5FB
type 7821
number 1 dn 55
dtmf-relay rtp-nte
username cisco55 password 1055
description Ahmed Hamdi
codec g711ulaw
voice register pool 56
pin 1056
id mac C472.95A8.A5F6
type 7821
number 1 dn 56
dtmf-relay rtp-nte
username cisco56 password 1056
description Loay Labani
codec g711ulaw
voice register pool 57
pin 1057
id mac C472.95A8.AEB7
type 7821
number 1 dn 57
dtmf-relay rtp-nte
username cisco57 password 1057
description Mehreen
codec g711ulaw
voice register pool 58
pin 1058
id mac C472.95A8.A2EA
type 7821
number 1 dn 58
dtmf-relay rtp-nte
username cisco58 password 1058
description Israa Fata
codec g711ulaw
voice register pool 59
pin 1059
id mac C472.95A8.A548
type 7821
number 1 dn 59
dtmf-relay rtp-nte
username cisco59 password 1059
description AL-Khaldi
codec g711ulaw
voice register pool 60
pin 1060
id mac C472.95A8.AC32
type 7821
number 1 dn 60
dtmf-relay rtp-nte
username cisco60 password 1060
description A.AbuSarhad
codec g711ulaw
voice register pool 61
pin 1061
id mac C472.95A8.A323
type 7821
number 1 dn 61
dtmf-relay rtp-nte
username cisco61 password 1061
description Ahmed Alwi
codec g711ulaw
voice register pool 62
pin 1062
id mac C472.95A8.A332
type 7821
number 1 dn 62
dtmf-relay rtp-nte
username cisco62 password 1062
description Ahmed
codec g711ulaw
voice register pool 63
pin 1063
id mac C472.95A8.A305
type 7821
number 1 dn 63
dtmf-relay rtp-nte
username cisco63 password 1063
description Khalid
codec g711ulaw
voice register pool 64
pin 1064
id mac C472.95A8.A599
type 7821
number 1 dn 64
dtmf-relay rtp-nte
username cisco64 password 1064
description Ziyad
codec g711ulaw
voice register pool 65
pin 1065
id mac C472.95A8.A8D0
type 7821
number 1 dn 65
dtmf-relay rtp-nte
username cisco65 password 1065
description Rashed
codec g711ulaw
voice register pool 66
pin 1066
id mac C472.95A8.AECB
type 7821
number 1 dn 66
dtmf-relay rtp-nte
username cisco66 password 1066
description Nayef
codec g711ulaw
voice register pool 67
pin 1067
id mac C472.95A8.A5E8
type 7821
number 1 dn 67
dtmf-relay rtp-nte
username cisco67 password 1067
description Rabee Saleem
codec g711ulaw
license udi pid CISCO2951/K9 sn FCZ1826605E
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
username admin privilege 15 secret 5 $1$ZN2o$WJ.I1vAu1ZMY2oIO68RCh0
username mgamal privilege 15 secret 5 $1$th3a$T2f54GXWqI3ZTDwsZar570
username cisco4
username cisco52 password 7 0257540E59
username cisco35 password 7 1158495642
redundancy
interface Loopback0
no ip address
interface Embedded-Service-Engine0/0
no ip address
description ****connected to LAN****
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description ***DATA SUBNET***
encapsulation dot1Q 10
ip address 192.168.10.5 255.255.255.0
interface GigabitEthernet0/0.20
description ***VOICE SUBNET***
encapsulation dot1Q 20
ip address 192.168.20.5 255.255.255.0
interface GigabitEthernet0/0.50
encapsulation dot1Q 50
ip address 192.168.50.1 255.255.255.0
interface ISM0/0
ip unnumbered GigabitEthernet0/0.20
service-module ip address 192.168.20.10 255.255.255.0
service-module ip default-gateway 192.168.20.5
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
no ip http secure-server
ip http path flash:
ip nat inside source list 107 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 192.168.10.1
ip route 10.208.9.69 255.255.255.255 10.68.35.209
ip route 192.168.20.10 255.255.255.255 ISM0/0
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:sip78xx.10-2-1-12SR1-4.loads
tftp-server flash:sboot78xx.10-2-1-12SR1-4.sbn
tftp-server flash:rootfs78xx.10-2-1-12SR1-4.sbn
tftp-server flash:kern78xx.10-2-1-12SR1-4.sbn
tftp-server flash:kern78xx.10-1-1SR1-4.sbn
access-list 107 permit ip 192.168.50.0 0.0.0.255 any
control-plane
voice-port 0/0/0
trunk-group LOCAL
cptone BR
connection plar opx 1995
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
voice-port 0/0/1
trunk-group LOCAL
supervisory disconnect dualtone mid-call
cptone SA
timeouts call-disconnect 1
timeouts ringing 20
timeouts wait-release 1
timing hookflash-out 500
caller-id enable
voice-port 0/0/2
cptone SA
timeouts ringing 20
caller-id enable
voice-port 0/0/3
cptone SA
timeouts ringing 20
caller-id enable
voice-port 0/1/0
cptone SA
timeouts ringing 20
caller-id enable
voice-port 0/1/1
cptone SA
timeouts ringing 20
caller-id enable
voice-port 0/1/2
trunk-group LOCAL
cptone SA
timeouts ringing 20
caller-id enable
voice-port 0/1/3
cptone SA
timeouts ringing 20
caller-id enable
voice-port 0/2/0
trunk-group LOCAL
cptone SA
timeouts ringing 20
caller-id enable
voice-port 0/2/1
cptone SA
timeouts ringing 20
caller-id enable
voice-port 0/2/2
cptone SA
timeouts ringing 20
connection plar opx 1031
caller-id enable
voice-port 0/2/3
trunk-group LOCAL
cptone SA
timeouts ringing 20
connection plar opx 1058
caller-id enable
voice-port 0/3/0
cptone SA
timeouts ringing 20
caller-id enable
voice-port 0/3/1
cptone SA
timeouts ringing 20
description ** Mobile Call **
caller-id enable
voice-port 0/3/2
cptone SA
timeouts ringing 20
caller-id enable
voice-port 0/3/3
cptone SA
timeouts ringing 20
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
paramspace callsetup after-hours-exempt FALSE
destination-pattern 9[2,6]......
fax rate disable
bandwidth maximum 0 minimum 0
no digit-strip
forward-digits 7
prefix 168.20.164:5060
no register e164
preemption level flash-override
dial-peer voice 2 pots
description ** International Call **
destination-pattern 900T
port 0/0/2
prefix 00
dial-peer voice 3 pots
trunkgroup STC
description ** national calls **
translation-profile outgoing to-old
preference 1
destination-pattern 901[123467].......
forward-digits 10
dial-peer voice 4 pots
trunkgroup STC
destination-pattern 905........
forward-digits 10
dial-peer voice 5 pots
trunkgroup STC
trunkgroup LOCAL
description STC Service Numbers
preference 10
destination-pattern 990.
forward-digits 3
dial-peer voice 6 pots
trunkgroup STC
trunkgroup LOCAL
preference 10
destination-pattern 9800.......
forward-digits 10
dial-peer voice 7 pots
trunkgroup LOCAL
description 9200 numbers
preference 10
destination-pattern 99200.....
forward-digits 9
dial-peer voice 1999 voip
destination-pattern 199.
session target ipv4:192.168.20.10
codec g711ulaw
no vad
dial-peer voice 10022 pots
port 0/0/2
prefix 00
dial-peer voice 10023 pots
preference 1
port 0/0/2
forward-digits 10
dial-peer voice 10024 pots
port 0/0/2
forward-digits 10
dial-peer voice 10032 pots
port 0/0/3
prefix 00
dial-peer voice 10033 pots
preference 1
port 0/0/3
forward-digits 10
dial-peer voice 10034 pots
port 0/0/3
forward-digits 10
dial-peer voice 10112 pots
port 0/1/1
prefix 00
dial-peer voice 10113 pots
preference 1
port 0/1/1
forward-digits 10
dial-peer voice 10114 pots
port 0/1/1
forward-digits 10
dial-peer voice 10132 pots
port 0/1/3
prefix 00
dial-peer voice 10133 pots
preference 1
port 0/1/3
forward-digits 10
dial-peer voice 10134 pots
port 0/1/1
forward-digits 10
dial-peer voice 10212 pots
port 0/0/2
prefix 00
dial-peer voice 10213 pots
preference 1
port 0/2/1
forward-digits 10
dial-peer voice 10214 pots
port 0/2/1
forward-digits 10
dial-peer voice 10222 pots
port 0/2/2
prefix 00
dial-peer voice 10223 pots
preference 1
port 0/2/2
forward-digits 10
dial-peer voice 10224 pots
port 0/2/2
forward-digits 10
dial-peer voice 10302 pots
port 0/3/0
prefix 00
dial-peer voice 10303 pots
preference 1
port 0/3/0
forward-digits 10
dial-peer voice 10304 pots
port 0/3/0
forward-digits 10
dial-peer voice 10312 pots
port 0/3/1
prefix 00
dial-peer voice 10313 pots
preference 1
port 0/3/1
forward-digits 10
dial-peer voice 10314 pots
port 0/3/1
forward-digits 10
dial-peer voice 10322 pots
port 0/3/2
prefix 00
dial-peer voice 10323 pots
preference 1
port 0/3/2
forward-digits 10
dial-peer voice 10324 pots
port 0/3/2
forward-digits 10
dial-peer voice 10332 pots
port 0/3/3
prefix 00
dial-peer voice 10333 pots
preference 1
port 0/3/3
forward-digits 10
dial-peer voice 10334 pots
port 0/3/3
forward-digits 10
dial-peer voice 1222551 voip
description ** STC to call Center **
destination-pattern 1222.....
session target ipv4:192.168.50.56
dial-peer voice 122251 voip
destination-pattern 01222.....
dial-peer voice 10335 pots
description ** Test **
preference 1
port 0/3/3
forward-digits 9
dial-peer voice 10336 pots
preference 1
port 0/0/0
forward-digits 9
dial-peer voice 10337 pots
preference 1
port 0/0/1
forward-digits 9
dial-peer voice 10338 pots
preference 1
port 0/0/2
forward-digits 9
dial-peer voice 11330 pots
preference 1
port 0/0/2
forward-digits 10
dial-peer voice 11331 pots
preference 1
port 0/0/0
forward-digits 10
dial-peer voice 11332 pots
preference 1
port 0/0/1
forward-digits 10
dial-peer voice 1129 pots
preference 1
port 0/1/3
forward-digits 10
dial-peer voice 1139 pots
preference 1
port 0/1/2
forward-digits 10
dial-peer voice 1140 pots
preference 1
port 0/1/2
forward-digits 3
dial-peer voice 1141 pots
preference 1
port 0/1/2
forward-digits 9
gatekeeper
shutdown
credentials
telephony-service
conference hardware
no auto-reg-ephone
max-ephones 51
max-dn 51
ip source-address 192.168.10.5 port 2000
auto assign 1 to 51
keepalive 40
max-conferences 10 gain -6
web admin system name alfuzail secret 5 $1$tmMP$OLz5DlOnShyddHE/ZLqA4/
dn-webedit
time-webedit
transfer-pattern 9.T
after-hours day Sun 00:01 23:59
after-hours day Mon 00:01 23:59
after-hours day Tue 00:01 23:59
after-hours day Wed 00:01 23:59
after-hours day Thu 00:01 23:59
after-hours day Fri 00:01 23:59
after-hours day Sat 00:01 23:59
create cnf-files version-stamp 7960 Dec 30 2015 13:06:21
ephone-dn-template 4
ephone-template 1
ephone-template 2
ephone-dn 4
ephone-dn 8
number 1008
name Yasir
ephone-dn 24
ephone-dn 51
number 1051
ephone 4
ephone 51
mac-address C472.95A8.A567
button 1:51
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 195
no exec
transport input all
stopbits 1
line vty 0
privilege level 15
password 7 070E315F49584B5643
login local
no domain-lookup
transport input all
line vty 1
login local
no domain-lookup
transport input all
line vty 2
login local
no domain-lookup
transport input all
line vty 3 4
login local
no domain-lookup
transport input all
line vty 5 15
login local
no domain-lookup
transport input all
scheduler allocate 20000 1000
ntp master 1
end
01-14-2016 05:46 AM
hey nehal,
plz go to config command and run this command insha allah fix the problem plz try it,,,,,,,,,,,,,
no create profile
create profile
Best Regards
01-14-2016 06:04 PM
hi zaidy
i already did the same,but still not working
my issue is phone got register but not making any calls after register
12-03-2015 12:02 AM
this is earlier command in show flash
and recenty showing this command in my router
233 104134844 Dec 2 2015 14:40:34 +03:00 c2900-universalk9-mz.SPA.154-3.M2.bin
234 596536 Nov 19 2015 15:49:24 +03:00 sboot2.78xx.10-3-1-12.sbn
235 370348 Nov 19 2015 15:49:46 +03:00 sboot78xx.10-3-1-12.sbn
236 1206 Nov 19 2015 15:50:06 +03:00 sip78xx.10-3-1-12.loads
237 41419092 Dec 2 2015 14:49:10 +03:00 rootfs2.78xx.10-3-1-12.sbn
238 824 Dec 3 2015 10:35:58 +03:00 its/featurePolicyDefault.xml
239 3855 Dec 3 2015 10:35:58 +03:00 its/SEP204C9EB32881.cnf.xml
240 4748 Dec 3 2015 10:35:58 +03:00 its/softkeyDefault_kpml.xml
241 4782 Dec 3 2015 10:35:58 +03:00 its/softkeyDefault.xml
242 1947 Dec 3 2015 10:35:56 +03:00 its/SIPDefault.cnf
243 69 Dec 3 2015 10:35:56 +03:00 its/syncinfo.xml
244 3861 Dec 3 2015 10:35:58 +03:00 its/SEP204C9EB3288C.cnf.xml
and 1 file is missing in recently command
(rootfs78xx.10-3-1-12.sbn)
if this is not exist then it would be any issue please assist me ...........
12-02-2015 05:54 AM
Note that every change you do must do this...
no create profile
create profile
Best Regards
ART
12-02-2015 11:53 PM
this command i used but same error in phone 7821 error (Registering)
no create profile
create profile
Best Regards
05-23-2017 01:54 AM
It's help me a lot: its solved the same issue I'd encounter.
Mine router version is:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1
and CME version:
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
The command about is working in my side and it's working: Except for this commands:
voice register pool-type 7821
xml-config maxNumCalls 6
xml-config busyTrigger 6
xml-config custom sshAccess 0
num-lines 2
description Cisco IP Phone 7821
reference-pooltype 6921
Weird but it fine with it.. I already registered my two (2) 7821 Phone and I can give call to each other.
03-26-2017 06:10 AM
sample configs to boot 7821 on C29xx Routers
mode cme
source-address x.x.x.x port 5060
max-dn 150
max-pool 10
load 7821 sip78xx.10-2-1-12SR1-4
timezone 31
time-format 24
hold-alert
voicemail xxxx
tftp-path flash:
file text
create profile sync 0609704072092917
network-locale GB
voice register dn 1
number 1001
name X
Label X
type 7821
number 1 dn 1
codec g711ulaw
dtmf-relay rtp-nte
username xxxx password xxxx
03-02-2018 11:26 AM
Dear,
I have CME has 7821 phones has been registered and working fine. I want to add new 7821 but I am not able. So After I add the new phone I should do
No create profile.
Create Profile
After I add the new 7821 I did the
Reset command and there was an error message
No contact info available for pool xx. What does this message mean ?
If did not use this command the phone will not register. What about factory reset Is it compensatory. I will try to do the commands above by next Sunday and I will update you I hope it will work.
Zadjali
