12-18-2014 06:31 AM - edited 03-17-2019 01:22 AM
I am having issues with getting a Cisco 7821 phone to register.
Current deployment is with Cisco 6921 phones SCCP registration
SIP integration with CUE
SIP integration with Mitel system
c2951-universalk9-mz.SPA.154-3.M1.bin (CME 10.5)
In flash:
rootfs78xx.10-1-1SR1-4.sbn
kern78xx.10-1-1SR1-4.sbn
sboot78xx.10-1-1SR1-4.sbn
sip78xx.10-1-1SR1-4.loads
The 7821 phone gets IP address but fails to register. Please could somebody let me know why phone is not registering.
Configuration below (10.245.226.132 is CME address) .
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw redundancy maximum-sessions 5
h323
sip
registrar server expires max 600 min 60
options-ping 90
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice register global
mode cme
source-address 10.245.226.132 port 5060
max-dn 30
max-pool 10
load 7821 sip78xx.10-1-1SR1-4
authenticate register
authenticate realm all
timezone 22
date-format D/M/Y
voicemail 590
tftp-path flash:
create profile sync 0061443538560005
network-locale GB
voice register dn 1
number 1010
name user1
label user1
mwi
voice register pool 1
busy-trigger-per-button 2
id mac F09E.636E.63F2
type 7821
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username 1010 password 123
codec g711ulaw
no vad
dial-peer voice 391 voip
description *** Auto Attendant ***
destination-pattern 399
session protocol sipv2
session target ipv4:10.245.226.131
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 392 voip
description *** Administration Via Telephone ***
destination-pattern 392
codec g711ulaw
no vad
dial-peer voice 393 voip
description *** Extension Assigner ***
service ea out-bound
destination-pattern 393
session target ipv4:10.245.226.132
dial-peer voice 590 voip
description *** Voice Mail Pilot ***
destination-pattern 590
b2bua
codec g711ulaw
no vad
dial-peer voice 1 pots
description ** Match all incoming POTS calls **
translation-profile incoming IncomingPSTNcalls
incoming called-number .
direct-inward-dial
dial-peer voice 899 voip
description Call to Mitel
translation-profile incoming Prefix9
translation-profile outgoing rem44
destination-pattern [23]..
session target ipv4:192.168.114.2
voice-class codec 1
dtmf-relay rtp-nte
no vad
interface GigabitEthernet0/0
description *** Connection to Mitel Phone System ***
ip address 192.168.114.5 255.255.255.248
duplex auto
speed auto
interface ISM0/0
description *** Connection to Cisco Unity Express ***
ip unnumbered GigabitEthernet0/1
service-module ip address 10.245.226.131 255.255.255.128
!Application: CUE Running on ISM
service-module ip default-gateway 10.245.226.132
interface GigabitEthernet0/1
description *** Connection to IP Phone LAN ***
ip address 10.245.226.132 255.255.255.128
duplex auto
speed auto
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.245.226.129
ip route 10.245.226.131 255.255.2
tftp-server flash:apps37sccp.1-4-4-0.bin
tftp-server flash:sip78xx.10-1-1SR1-4.loads
tftp-server flash:rootfs78xx.10-1-1SR1-4.sbn
tftp-server flash:sboot78xx.10-1-1SR1-4.sbn
sip-ua
mwi-server ipv4:10.245.226.131 expires 3600 port 5060 transport udp
registrar ipv4:10.245.226.132 expires 600
gatekeeper
shutdown
telephony-service
authentication credential cmeadmin c4p1ta2012
xml user xmladmin password xmladmin 15
extension-assigner tag-type provision-tag
max-ephones 104
max-dn 299
ip source-address 10.245.226.132 port 2000
auto assign 101 to 105
no service directed-pickup
timeouts interdigit 5
system message CFGS
url services http://10.245.226.131/voiceview/common/login.do
url authentication http://10.245.226.132/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
load 7931 SCCP31.9-2-1S
load 6921 SCCP69xx.9-2-1-0
time-zone 22
date-format dd-mm-yy
voicemail 590
max-conferences 8 gain -6
call-forward pattern .T
moh enable-g711 "music-on-hold.au"
web admin system name cmeadmin secret 5 $1$QmIK$46fDKVSudMxzI2bRp/Ef7/
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 298
number 598...
mwi on
ephone-dn 299
number 599...
mwi off
Solved! Go to Solution.
11-04-2015 04:16 AM
Dear Rajan,
Sorry for late reply, now it's working perfectly...
Thank you!
Best Regards
Alcidio Tembe
02-25-2018 03:08 AM
am getting the following messages while the phone is registering
*Feb 25 06:30:58.504: TFTP: read request from host 192.168.20.2(50914) via Gigab
itEthernet0/1.20
*Feb 25 06:30:58.504: TFTP: Looking for CTLSEP0059DC5A65C2.tlv
*Feb 25 06:30:58.504: TFTP: Sending error 1 No such file
*Feb 25 06:30:59.296: TFTP: Server request for port 50062, socket_id 0x3DAFCF38
for process 431
*Feb 25 06:30:59.296: TFTP: read request from host 192.168.20.2(50062) via Gigab
itEthernet0/1.20
*Feb 25 06:30:59.296: TFTP: Looking for ITLSEP0059DC5A65C2.tlv
*Feb 25 06:30:59.296: TFTP: Sending error 1 No such file
*Feb 25 06:31:00.084: TFTP: Server request for port 49618, socket_id 0x3DA88584
for process 431
*Feb 25 06:31:00.084: TFTP: read request from host 192.168.20.2(49618) via Gigab
itEthernet0/1.20
*Feb 25 06:31:00.084: TFTP: Looking for ITLFile.tlv
*Feb 25 06:31:00.088: TFTP: Sending error 1 No such file
*Feb 25 06:31:00.920: TFTP: Server request for port 50041, socket_id 0x3DAFCF38
for process 431
*Feb 25 06:31:00.920: TFTP: read request from host 192.168.20.2(50041) via Gigab
itEthernet0/1.20
*Feb 25 06:31:00.920: TFTP: Looking for SEP0059DC5A65C2.cnf.xml
*Feb 25 06:31:00.920: TFTP: Sending error 1 No such file
*Feb 25 06:31:01.832: TFTP: Server request for port 52355, socket_id 0x3DA88584
for process 431
*Feb 25 06:31:01.832: TFTP: read request from host 192.168.20.2(52355) via Gigab
itEthernet0/1.20
*Feb 25 06:31:01.832: TFTP: Looking for XMLDefault.cnf.xml
*Feb 25 06:31:01.832: TFTP: Sending error 1 No such file
11-12-2015 05:06 AM
Dear Rajan
Once again I need your support, I would like to add the second number on the same pool, to do that I had to use 2 DNs for each Pool as you can see below:
voice register dn 1
number 10
pickup-call any-group
name John
label John
voice register dn 2
number 21456789
name John
label John
busy-trigger-per-button 1
id mac 584C.9EB2.5HE2
type 7821
number 1 dn 1
number 2 dn 2
dtmf-relay rtp-nte
username john password cisco
codec g711alaw
Do you have other way to do that, different of this using less dn's?
Best Regards
Alcidio Tembe
03-26-2017 02:32 AM
you have to supply codec command under voice register pool using
or apply a codec class
sample configs goes like
codec g711ulaw
dtmf-relay rtp-nte
12-19-2014 08:29 AM
Hi Michael
I added the load 7821 sip78xx.10-1-1SR1-4 under voice register global then added some new phones.
Each time I added a new phone the phone failed to register until I deleted and then re-created the profile:
no create profile
create profile
I had to do this each time I added phones and occasionally the router crashed
This seems to imply issue with the software.
First time I have deployed SIP phones to CCME. I noticed that the phones already had the active load sip78xx.10-1-1SR1-4.
12-19-2014 08:32 AM
There is still much development needed for SIP phones on CME. Every time you change any SIP feature it is a good idea to create profile. This is especially true for just adding phones as well. Glad you got it working!
11-20-2015 01:29 AM
Hi Michael
Could you please help me on this issue:
I want to
voice register dn 1
number 10
name John
shared-line
preference 9
label John
voice register dn 2
number 21456789
type 7821
number 1 dn 1
number 2 dn 2
dtmf-relay rtp-nte
codec g711alaw
Do you have other way to do that, different of this using only one dn?
Best Regards
Alcidio Tembe
09-07-2015 02:06 AM
Make sure to config accessible NTP server, that would solve it.
But it is not an issue to worry about.
Mzee
11-30-2015 07:21 AM
Please kindly Assist me I have the same problem.
see my Configuration below:
Current configuration : 30823 bytes
! Last configuration change at 17:26:00 Dar Thu Nov 26 2015 by erick.semiono
version 15.5
hostname TIB-SMR-CME-RTR
boot-start-marker
boot system flash c3900-universalk9-mz.SPA.155-3.M1.bin
boot-end-marker
card type e1 0 0
logging buffered 200000
no logging console
no logging monitor
enable secret 4 vMUOhXqqxEZPcSi3OKmL0dTLc6ZINB8baCz0/42zpzI
no aaa new-model
ethernet lmi ce
clock timezone Dar 3 0
network-clock-participate wic 0
ip dhcp excluded-address 172.16.16.1 172.16.16.20
ip dhcp excluded-address 172.16.30.1 172.16.30.20
ip dhcp excluded-address 172.16.30.129 172.16.30.149
ip dhcp excluded-address 172.16.31.1 172.16.31.20
ip dhcp excluded-address 172.16.31.129 172.16.31.149
ip dhcp excluded-address 172.16.32.1 172.16.32.20
ip dhcp pool BASEMENT_SERVER_FARM
network 172.16.16.0 255.255.255.192
default-router 172.16.16.1
dns-server 192.168.1.5 172.16.16.9
ip dhcp pool GROUND
network 172.16.30.0 255.255.255.128
default-router 172.16.30.1
ip dhcp pool GROUND
ip dhcp pool MEZZANINE
network 172.16.30.128 255.255.255.128
default-router 172.16.30.129
ip dhcp pool 7TH_FLOOR1
network 172.16.31.0 255.255.255.128
default-router 172.16.31.1
ip dhcp pool 7TH_FLOOR2
network 172.16.31.128 255.255.255.128
default-router 172.16.31.129
ip dhcp pool VOICE
network 172.16.100.0 255.255.255.0
default-router 172.16.100.1
option 150 ip 172.16.0.1
ip dhcp pool MEZZANINE_SAMORA
network 172.16.32.0 255.255.255.128
default-router 172.16.32.1
ip domain name tib.co.tz
ip name-server 192.168.1.5
ip name-server 172.16.16.9
ip name-server 41.204.128.15
ip name-server 41.204.129.15
ip cef
no ipv6 cef
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-2453821396
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2453821396
revocation-check none
rsakeypair TP-self-signed-2453821396
crypto pki certificate chain TP-self-signed-2453821396
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32343533 38323133 3936301E 170D3134 30333237 31303037
32355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 34353338
32313339 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
810094F5 C9B1D18D 28FBC935 ED6B0AAB E440D5F8 172C3345 CB5C8778 DEA2F9E2
1678206E 266E811C 354C7B2D 3820110E 9D28B7BB 500ADD31 A0B71294 B68D642A
233C5844 F7950426 B26A5D73 D4D99AC5 F9F0E408 4A5DB621 7737E43C 1012B75E
CEFD4350 71551A0E 7AB5F7D1 D1F095D4 1911ACE7 890C33FD CF85462B 4C1960D5
B2C70203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14AC49CF 9F078C0F 6E3F3B00 ADD0C47A D37F4039 34301D06
03551D0E 04160414 AC49CF9F 078C0F6E 3F3B00AD D0C47AD3 7F403934 300D0609
2A864886 F70D0101 05050003 8181004D EDCE808B 90CF612E ADCC92C9 AC0BAB3F
037C28A0 1EA4C836 C65230F8 72F5AD59 44F452E4 C7538FC9 BCD6473F E1FF8450
1FB81ABB CACC9953 B2E6FDF1 CDF77108 169B1F60 93F69FB9 B948C923 AF9A7EC1
B4622A92 3C35E245 051E5B1C 01B48199 090FA0EC 392590AA 89A8A1AF 313C2306
A8AC1D9F 08197B96 3B34A714 34FBF2
quit
voice-card 0
dsp services dspfarm
voice service voip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server
voice class custom-cptone leavetone
dualtone conference
frequency 400 800
cadence 400 50 200 50 200 50
voice class custom-cptone jointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
mode cme
source-address 172.16.0.1 port 5060
max-dn 600
max-pool 265
load 9971 sip9971.9-4-1-9
load 7821 sip78xx.10-3-1-12
timezone 24
time-format 24
date-format D/M/Y
tftp-path flash:
file text
conference hardware
voice register dn 1
number 420
after-hour exempt
name Arphaxad
shared-line max-calls 6
huntstop channel 2
mwi
voice register dn 2
number 443
after-hour exempt
name Kaanaeli Nnko
huntstop channel 2
label Kaanaeli Nnko
mwi
voice register dn 3
number 482
after-hour exempt
name Adolphina William
huntstop channel 2
label Adolphina William
mwi
voice register dn 4
number 441
after-hour exempt
name Joseph Kihulla
huntstop channel 2
label Joseph Kihulla
mwi
voice register dn 5
number 484
after-hour exempt
huntstop channel 2
mwi
voice register dn 6
number 442
after-hour exempt
name Mwallu Mwachang'a
huntstop channel 2
label Mwalu Mwachang'a
mwi
voice register dn 7
number 486
after-hour exempt
name Peragius Kavuyimbo
huntstop channel 2
label Peragius Kavuymbo
mwi
voice register dn 8
number 440
after-hour exempt
name RECEPTION
huntstop channel 2
label RECEPTION
mwi
voice register dn 9
number 444
after-hour exempt
name Frank Nyabundege
huntstop channel 2
label Frank Nyabundege
mwi
voice register dn 10
number 400
after-hour exempt
name Levina Mwang'ombe
huntstop channel 2
label Levina Mwang'ombe
mwi
voice register dn 11
number 490
after-hour exempt
name Edward Lyimo
huntstop channel 2
label Edward Lyimo
mwi
voice register dn 12
number 462
after-hour exempt
name Edwin Katanga
huntstop channel 2
label Edwin Katanga
mwi
voice register dn 13
number 492
after-hour exempt
name User1
huntstop channel 2
label User1
mwi
voice register dn 14
number 493
after-hour exempt
name User2
huntstop channel 2
label User2
voice register dn 15
number 494
after-hour exempt
name Swift Room
huntstop channel 2
label Swift Room
mwi
voice register dn 16
number 415
after-hour exempt
name User16
huntstop channel 2
label User16
mwi
voice register dn 17
number 410
after-hour exempt
name IT CORPORATE
huntstop channel 2
label IT CORPORATE
mwi
voice register dn 18
number 439
name Denice Rutechura
huntstop channel 2
label Denice Rutechura
mwi
voice register dn 19
number 438
name Amina Salum
huntstop channel 2
label Amina Salum
mwi
voice register dn 20
number 437
name Stanley Charles
huntstop channel 2
label Stanley Charles
mwi
voice register dn 21
number 436
name Pamela Lazaro
huntstop channel 2
label Pamela Lazaro
mwi
voice register dn 22
number 435
name Grace Wilbard
huntstop channel 2
label Grace Wilbard
mwi
voice register dn 23
number 428
name Zuhura Mfangavo
huntstop channel 2
label Zuhura Mfangavo
mwi
voice register dn 24
number 406
name Clemence Masogola
huntstop channel 2
label Clemence Masogola
mwi
voice register dn 25
number 439
after-hour exempt
name Test
huntstop channel 2
label Test
mwi
voice register template 1
session-transport tcp
softkeys hold Newcall Resume iDivert
softkeys idle Cfwdall DND Gpickup Mobility Newcall Pickup Redial
softkeys seized Cfwdall Endcall Gpickup Meetme Pickup Redial
softkeys connected ConfList Confrn Endcall Hold Mobility Park RmLstC Trnsfer iDivert
conference drop-mode creator
conference add-mode creator
conference admin
id mac 189C.5D21.6763
type 9971
dtmf-relay rtp-nte
username cisco password cisco
codec g711alaw
voice register pool 2
id mac 189C.5D21.697E
type 9971
number 1 dn 2
dtmf-relay rtp-nte
username admin password admin
codec g711alaw
voice register pool 3
id mac 189C.5D21.A4F4
type 9971
number 1 dn 3
dtmf-relay rtp-nte
username admin2 password admin2
codec g711alaw
voice register pool 4
id mac 189C.5D21.67B7
type 9971
number 1 dn 4
dtmf-relay rtp-nte
username admin3 password admin3
codec g711alaw
voice register pool 5
id mac 189C.5D20.7C18
type 9971
number 1 dn 5
dtmf-relay rtp-nte
username admin4 password admin4
codec g711alaw
voice register pool 6
id mac 189C.5D21.68E6
type 9971
number 1 dn 6
dtmf-relay rtp-nte
username admin5 password admin5
codec g711alaw
voice register pool 7
id mac 64E9.502F.4E42
type 9971
number 1 dn 7
dtmf-relay rtp-nte
username admin6 password admin6
codec g711alaw
voice register pool 8
id mac 189C.5D21.A618
type 9971
number 1 dn 8
dtmf-relay rtp-nte
username admin7 password admin7
codec g711alaw
voice register pool 9
id mac 189C.5D21.67B8
type 9971
number 1 dn 9
dtmf-relay rtp-nte
username admin8 password admin8
codec g711alaw
voice register pool 10
id mac 189C.5D21.6765
type 9971
number 1 dn 10
template 1
dtmf-relay rtp-nte
username admin9 password admin9
codec g711alaw
voice register pool 11
id mac B000.B4D8.8B2A
type 9971
number 1 dn 11
dtmf-relay rtp-nte
username admin11 password admin11
codec g711alaw
voice register pool 12
id mac B000.B4D8.8AAA
type 9971
number 1 dn 12
dtmf-relay rtp-nte
username admin12 password admin
codec g711alaw
voice register pool 13
id mac B000.B4D8.88EE
type 9971
number 1 dn 13
dtmf-relay rtp-nte
username admin13 password admin13
codec g711alaw
voice register pool 14
id mac 1CDE.A783.271F
type 9971
number 1 dn 14
dtmf-relay rtp-nte
username admin14 password admin14
codec g711alaw
voice register pool 15
id mac 1CDE.A783.21A5
type 9971
number 1 dn 15
dtmf-relay rtp-nte
username admin15 password admin15
codec g711alaw
voice register pool 16
id mac 38ED.1854.61E9
type 7821
number 1 dn 16
dtmf-relay rtp-nte
username admin16 password admin16
codec g711alaw
voice register pool 17
id mac 38ED.1854.629C
type 7821
number 1 dn 17
dtmf-relay rtp-nte
username admin17 password admin17
codec g711alaw
voice register pool 18
id mac 38ED.1854.62C1
voice register pool 19
id mac 38ED.1854.6258
type 7821
number 1 dn 19
dtmf-relay rtp-nte
username admin19 password admin19
codec g711alaw
voice register pool 20
id mac 38ED.1854.6235
type 7821
number 1 dn 20
dtmf-relay rtp-nte
username admin20 password admin20
codec g711alaw
voice register pool 21
id mac 38ED.1854.61E3
type 7821
number 1 dn 21
dtmf-relay rtp-nte
username admin21 password admin21
codec g711alaw
voice register pool 22
id mac 38ED.1854.6287
type 7821
number 1 dn 22
dtmf-relay rtp-nte
username admin22 password admin22
codec g711alaw
voice register pool 23
id mac 38ED.1854.6291
type 7821
number 1 dn 23
dtmf-relay rtp-nte
username admin23 password admin23
codec g711alaw
voice register pool 24
id mac 38ED.1854.61D5
type 7821
number 1 dn 24
dtmf-relay rtp-nte
username admin24 password admin24
codec g711alaw
voice register pool 25
id mac 38ED.1854.61ED
type 7821
dtmf-relay rtp-nte
username admin25 password admin25
codec g711alaw
voice translation-rule 1
rule 1 /^.*\(4..\)/ /\1/
voice translation-rule 2
rule 1 /^4/ /02221624/
voice translation-profile 1
translate called 1
voice translation-profile 2
translate calling 2
license udi pid C3900-SPE100/K9 sn FOC173466BF
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
username erick.semiono privilege 15 secret 4 SxlZFdkzsAdPTvQ.oX80TtUt8391I3sXhr1oR56KqQ2
username gano.mwinge privilege 15 secret 4 6WlPw5V1B2cl1DEkO1hj8TXPwpMRvxxlM93pE0dW10g
username admin privilege 15 secret 4 vMUOhXqqxEZPcSi3OKmL0dTLc6ZINB8baCz0/42zpzI
username admin21 password 0 admin21
username admin22 password 0 admin22
username admin23 password 0 admin23
username admin24 password 0 admin24
redundancy
controller E1 0/0/0
pri-group timeslots 1-16
interface Loopback1
description CUE INTERFACE
ip address 1.1.1.1 255.255.255.248
interface Embedded-Service-Engine0/0
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
interface ISM0/0
ip unnumbered Loopback1
service-module ip address 1.1.1.2 255.255.255.248
service-module ip default-gateway 1.1.1.1
description LINK TO CDSW1
ip address 172.16.0.1 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/2
description LINK TO CDSW2
ip address 172.16.0.6 255.255.255.252
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp tlv app
interface Vlan1
no ip address
router eigrp 1
network 1.1.1.0 0.0.0.7
network 172.16.0.0
redistribute connected
ip forward-protocol nd
ip http server
no ip http secure-server
ip http path flash:cme-gui
ip ftp username tib
ip ftp password tib
ip route 0.0.0.0 0.0.0.0 172.16.0.2
ip route 1.1.1.2 255.255.255.255 ISM0/0
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:dkern9971.100609R2-9-4-1-9.sebn
tftp-server flash:sip9971.9-4-1-9.loads
tftp-server flash:skern9971.022809R2-9-4-1-9.sebn
tftp-server flash:sboot9971.031610R1-9-4-1-9.sebn
tftp-server flash:rootfs9971.9-4-1-9.sebn
tftp-server flash:kern9971.9-4-1-9.sebn
tftp-server flash:CIPC_Locale.loads
tftp-server flash:/its
tftp-server flash:/its/CME-locale-en_US-English-8.6.2.4.tar.cfg
tftp-server flash:kern2.78xx.10-3-1-12.sbn
tftp-server flash:sip78xx.10-3-1-12.loads
tftp-server flash:kern78xx.10-3-1-12.sbn
tftp-server flash:rootfs2.78xx.10-3-1-12.sbn
tftp-server flash:rootfs78xx.10-3-1-12.sbn
tftp-server flash:sboot2.78xx.10-3-1-12.sbn
tftp-server flash:sboot78xx.10-3-1-12.sbn
control-plane
voice-port 0/0/0:15
translation-profile incoming 1
translation-profile outgoing 2
timeouts call-disconnect 2
timeouts wait-release 2
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 172.16.0.1 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate profile 1 register c067.afee.f681
dspfarm profile 1 conference
codec g729r8
codec g729ar8
codec g729abr8
codec g729br8
codec g711alaw
codec g711ulaw
maximum sessions 4
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
associate application SCCP
description TTCL E1 line
direct-inward-dial
dial-peer voice 7 pots
description CALL NATIONAL & INTERNATIONAL
destination-pattern 7T
port 0/0/0:15
dial-peer voice 9 pots
description CALL ALL MOBILEs
destination-pattern 90[6-7]T
port 0/0/0:15
forward-digits 10
dial-peer voice 2 pots
description CALL LANDLINE DSM
destination-pattern 2......
port 0/0/0:15
forward-digits all
dial-peer voice 3 pots
description CALL LANDLINE REGINALs
destination-pattern 02[3-9].......
port 0/0/0:15
forward-digits 10
dial-peer voice 33 voip
destination-pattern 3000
session target ipv4:1.1.1.2
codec g711alaw
no vad
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 3
sdspfarm tag 1 c067.afee.f681
conference hardware
authentication credential admin tibcop13
max-ephones 200
max-dn 400
ip source-address 172.16.0.1 port 2000
calling-number local
system message TIB SAMORA BRANCH
url services http://1.1.1.2/voiceview/common/login.do
url authentication http://1.1.1.1/CCMCIP/authenticate.asp
time-format 24
voicemail 3000
call-forward pattern T
moh enable-g711 "flash0:music-on-hold.au"
multicast moh 239.10.16.4 port 2000
web admin system name admin password tibcop13
dn-webedit
time-webedit
transfer-pattern T
transfer-pattern .T
after-hours block pattern 1 0 7-24
after-hours block pattern 2 2 7-24
after-hours block pattern 3 7 7-24
after-hours block pattern 4 9 7-24
create cnf-files version-stamp 7960 Nov 24 2015 15:21:02
ephone-template 1
conference admin
softkeys hold Newcall Resume Select Join
softkeys idle Cfwdall ConfList Dnd Gpickup HLog Join Login Newcall Pickup Redial RmLstC
softkeys seized Redial Pickup Gpickup HLog Meetme Endcall
softkeys connected Acct ConfList Confrn Endcall Flash HLog Hold Join Park RmLstC Select Trnsfer
ephone-template 2
ephone-dn 1 dual-line
number 489
ephone-dn 2 dual-line
number 401
label William Mosille
name William Mosille
ephone-dn 3 dual-line
number 402
label Amani Nkonya
name Amani Nkonya
ephone-dn 4 dual-line
number 403
label Nasobile Gallen
name Nasobile Gallen
ephone-dn 5 dual-line
number 404
label Susan Kusaga
name Susan Kusaga
ephone-dn 6 dual-line
number 405
label Customer-Service01
name Customer-Service01
ephone-dn 7 dual-line
number 406
ephone-dn 8 dual-line
number 407
name Samuel
ephone-dn 9 dual-line
number 408
label Karl Mmari
name Karl Mmari
ephone-dn 10 dual-line
number 409
label Julian Mwakitalima
name Julian Mwakitalima
ephone-dn 11 dual-line
number 423
name Mauna
ephone-dn 12 dual-line
number 411
ephone-dn 13 dual-line
number 412
label Eileen Mbunda
name Eileen Mbunda
ephone-dn 14 dual-line
number 413
label Lusajo Fubile
name Lusajo Fubile
ephone-dn 15 dual-line
number 414
ephone-dn 16 dual-line
number 415
ephone-dn 17 dual-line
number 416
label Isabela Mwidunda
name Isabela Mwidunda
ephone-dn 18 dual-line
number 417
ephone-dn 19 dual-line
number 418
label Lutundwa Kasese
name Lutundwa Kasese
ephone-dn 20 dual-line
number 419
label Albin Kimoso
name Albin Kimoso
ephone-dn 21 dual-line
number 480
ephone-dn 22 dual-line
number 495
label Kelvin Mboma
name Kelvin Mboma
ephone-dn 23 dual-line
number 424
label Loisiligaki Memirieki
name Loisiligaki Memirieki
ephone-dn 24 dual-line
number 410
ephone-dn 25 dual-line
number 424
ephone-dn 26 dual-line
number 425
ephone-dn 27 dual-line
number 426
ephone-dn 28 dual-line
number 427
ephone-dn 29 dual-line
ephone-dn 30 dual-line
number 429
label Irene Temu
name Irene Temu
ephone-dn 31 dual-line
number 430
label Robinson Mwakyomo
name Robinson Mwakyomo
ephone-dn 32 dual-line
number 431
label Emma Joseph
name Emma Joseph
ephone-dn 33 dual-line
number 432
ephone-dn 34 dual-line
number 433
label Yahya Hemmed
name Yahya Hemmed
ephone-dn 35 dual-line
number 434
label Lulutila Mwambipile
name Lulutila Mwambipile
ephone-dn 36 dual-line
number 435
ephone-dn 37 dual-line
number 436
ephone-dn 38 dual-line
number 437
ephone-dn 39 dual-line
number 438
ephone-dn 41 dual-line
number 440
ephone-dn 42 dual-line
number 441
ephone-dn 43 dual-line
number 442
ephone-dn 44 dual-line
number 443
ephone-dn 45 dual-line
number 445
label Anjela Kijo
name Anjela Kijo
ephone-dn 46 dual-line
number 446
label Rose Igogo
name Rose Igogo
ephone-dn 47 dual-line
number 447
label Matilda
name Matilda
ephone-dn 48 dual-line
number 448
label Novarty Tenga
name Novarty Tenga
ephone-dn 49 dual-line
number 449
label Benjamin Malekia
name Benjamin Malekia
ephone-dn 50 dual-line
number 455
label Wilfred Omary
name Wilfred Omary
ephone-dn 51 dual-line
number 450
label Alphoncina Moshi
name Alphoncina Moshi
ephone-dn 52 dual-line
number 451
label Zacharia Kapama
name Zacharia Kapama
ephone-dn 53 dual-line
number 452
label Magdalena Kajeri
name Magdalena Kajeri
ephone-dn 54 dual-line
number 453
ephone-dn 55 dual-line
number 454
label Tajiel John
name Tajiel John
ephone-dn 56 dual-line
number 426
label Nyaki
name Nyaki
ephone-dn 57 dual-line
number 456
label Theresia Soka
name Theresia Soka
ephone-dn 58 dual-line
number 427
label florah
name florah
ephone-dn 59 dual-line
number 425
label Doreen
name Doreen
ephone-dn 60 dual-line
number 459
label Ronald Fuya
name Ronald Fuya
ephone-dn 61 dual-line
number 421
name Jesca
ephone-dn 62 dual-line
number 463
label Frank Mpewa
name Frank Mpewa
ephone-dn 63 dual-line
number 422
name Barbara
ephone-dn 64 dual-line
number 463
ephone-dn 65 dual-line
number 428
label Amina
name Amina
ephone-dn 66 dual-line
number 465
ephone-dn 67 dual-line
number 466
ephone-dn 68 dual-line
number 467
ephone-dn 69 dual-line
number 468
ephone-dn 70 dual-line
number 469
ephone-dn 71 dual-line
number 470
label Masecha Fletcher
name Masecha Fletcher
ephone-dn 72 dual-line
number 471
label Berina Rugeiyamu
name Berina Rugeiyamu
ephone-dn 73 dual-line
number 472
label Samuel Malipula
name Samuel Malipula
ephone-dn 74 dual-line
number 473
ephone-dn 75 dual-line
number 474
label Bahati Minja
name Bahati Minja
ephone-dn 76 dual-line
number 496
ephone-dn 77 dual-line
number 476
ephone-dn 78 dual-line
number 477
ephone-dn 79 dual-line
number 478
ephone-dn 80 dual-line
number 479
ephone-dn 81
number 485
ephone-dn 91
number 4000...
mwi on
ephone-dn 92
number 4001...
mwi off
ephone-dn 100 dual-line
number 500
conference meetme
no huntstop
ephone-dn 101 dual-line
number 500
conference meetme
preference 1
no huntstop
ephone-dn 102 dual-line
number 500
conference meetme
preference 2
no huntstop
ephone-dn 103 dual-line
number 500
conference meetme
preference 3
no huntstop
ephone-dn 104 dual-line
number 500
conference meetme
preference 4
no huntstop
ephone-dn 105 dual-line
number 500
conference meetme
preference 5
no huntstop
ephone-dn 106 dual-line
number 500
conference meetme
preference 6
no huntstop
ephone-dn 107 dual-line
number 500
conference meetme
preference 7
ephone-dn 108 dual-line
number 600
name Conference
conference ad-hoc
no huntstop
ephone-dn 109 dual-line
number 600
name Conference
conference ad-hoc
preference 1
no huntstop
ephone-dn 110 dual-line
number 600
name Conference
conference ad-hoc
preference 2
no huntstop
ephone-dn 111 dual-line
number 600
name Conference
conference ad-hoc
preference 3
no huntstop
ephone-dn 112 dual-line
number 600
name Conference
conference ad-hoc
preference 4
no huntstop
ephone-dn 113 dual-line
number 600
name Conference
conference ad-hoc
preference 5
no huntstop
ephone-dn 114 dual-line
number 600
name Conference
conference ad-hoc
preference 6
no huntstop
ephone-dn 115 dual-line
number 600
name Conference
conference ad-hoc
preference 7
ephone 1
mac-address 0C27.24BB.C210
username "Receptionist"
type 6945
button 1:1
ephone 2
mac-address 0C27.24BB.9F8F
type 6945
button 1:2
ephone 3
mac-address 0C27.24BB.B438
type 6945
button 1:3
ephone 4
mac-address 0C27.24BB.B43D
type 6945
button 1:4
ephone 5
mac-address 0C27.24BB.BEFD
type 6945
button 1:5
ephone 6
mac-address 0C27.24BB.BC69
username "Customer-Service01"
type 6945
button 1:6
ephone 7
mac-address 0C27.24BB.B424
type 6945
button 1:7
ephone 8
mac-address 0C27.24BB.D5B0
type 6945
button 1:8
ephone 9
mac-address 0C27.24BB.D5B8
after-hours exempt
type 6945
button 1:9
ephone 10
mac-address 0C27.24BB.C663
type 6945
button 1:10
ephone 11
mac-address 0C27.24BB.C4DB
ephone-template 1
type 6945
button 1:11
ephone 12
mac-address D4BE.D947.20B5
after-hours exempt
type CIPC
button 1:12
ephone 13
mac-address 0C27.24BB.C040
type 6945
button 1:13
ephone 14
mac-address 0C27.24BB.BFE2
type 6945
button 1:14
ephone 15
ephone 16
mac-address 0C27.24BB.C2B6
type 6945
button 1:16
ephone 17
mac-address 0C27.24BB.BAAE
type 6945
button 1:17
ephone 18
mac-address 0C27.24BB.B67E
type 6945
button 1:18
ephone 19
mac-address 0C27.24BB.C1D0
type 6945
button 1:19
ephone 20
mac-address 0C27.24BB.C1B3
after-hours exempt
type 6945
button 1:20
ephone 21
mac-address 0C27.24BB.C1A0
after-hours exempt
type 6945
button 1:21
ephone 22
mac-address 0C27.24BB.B96A
after-hours exempt
type 6945
button 1:22
ephone 23
mac-address 0C27.24BB.C139
type 6945
button 1:23
ephone 24
mac-address 0C27.24BB.BB59
after-hours exempt
button 1:52
ephone 25
after-hours exempt
ephone 26
mac-address ECF4.BB2E.BAAD
after-hours exempt
type CIPC
button 1:26
ephone 27
mac-address ECF4.BB2E.BAF1
after-hours exempt
type CIPC
button 1:27
ephone 28
ephone 29
mac-address 0C27.24BB.C665
type 6945
button 1:29
ephone 30
mac-address 0C27.24BB.C65C
type 6945
button 1:30
ephone 31
mac-address 0C27.24BB.C376
type 6945
button 1:31
ephone 32
mac-address 0C27.24BB.C803
type 6945
button 1:32
ephone 33
mac-address 0C27.24BB.C1A9
username "Yahya"
type 6945
button 1:33
ephone 34
mac-address 0C27.24BB.C71B
ephone-template 1
username "Lulu"
type 6945
button 1:34
ephone 35
mac-address 0C27.24BB.B544
type 6945
button 1:35
ephone 36
mac-address 0C27.24BB.C96C
type 6945
button 1:36
ephone 37
mac-address 0C27.24BB.C91C
type 6945
button 1:37
ephone 38
mac-address 0C27.24BB.C7D0
type 6945
button 1:38
ephone 39
mac-address 0C27.24BB.C721
type 6945
button 1:39
ephone 40
mac-address 0C27.24BB.C660
type 6945
ephone 41
mac-address 0C27.24BB.9203
type 6945
button 1:41
ephone 42
mac-address 0C27.24BB.A0A9
type 6945
button 1:42
ephone 43
mac-address 0C27.24BB.B45A
type 6945
button 1:43
ephone 44
mac-address 0C27.24BB.B461
type 6945
button 1:44
ephone 45
mac-address 0C27.24BB.C6DF
after-hours exempt
type 6945
button 1:45
ephone 46
mac-address 0C27.24BB.BEB8
after-hours exempt
type 6945
button 1:46
ephone 47
mac-address 0C27.24BB.BF0C
after-hours exempt
type 6945
button 1:47
ephone 48
mac-address 0C27.24BB.BFE5
type 6945
button 1:48
ephone 49
mac-address 0C27.24BB.C00F
after-hours exempt
type 6945
button 1:49
ephone 50
mac-address 0C27.24BB.C60C
type 6945
button 1:50
ephone 51
mac-address 0C27.24BB.C1F5
after-hours exempt
type 6945
button 1:51
ephone 52
ephone 53
mac-address 0C27.24BB.C19C
type 6945
button 1:53
ephone 54
mac-address 0C27.24BB.C181
type 6945
button 1:54
ephone 55
mac-address 0C27.24BB.BF31
type 6945
button 1:55
ephone 56
mac-address 0C27.24BB.B539
type 6945
button 1:56
ephone 57
mac-address 0C27.24BB.C08F
type 6945
button 1:57
ephone 58
mac-address 0C27.24BB.C061
type 6945
button 1:58
ephone 59
mac-address 0C27.24BB.BF6F
type 6945
button 1:59
ephone 60
mac-address 0C27.24BB.BF19
type 6945
button 1:60
ephone 61
mac-address 0C27.24BB.BEE5
after-hours exempt
type 6945
button 1:61
ephone 62
mac-address 0C27.24BB.BEEC
type 6945
button 1:62
ephone 63
mac-address 0C27.24BB.BEC8
type 6945
button 1:63
ephone 64
mac-address 0C27.24BB.BE8D
type 6945
button 1:64
ephone 65
mac-address 0C27.24BB.BE24
type 6945
button 1:65
ephone 66
mac-address 0C27.24BB.BF2C
type 6945
button 1:66
ephone 67
mac-address 0C27.24BB.BEC3
type 6945
button 1:67
ephone 68
mac-address 0C27.24BB.C80C
after-hours exempt
type 6945
button 1:68
ephone 69
mac-address 0C27.24BB.C674
type 6945
button 1:69
ephone 70
mac-address 0C27.24BB.C3A0
type 6945
button 1:70
ephone 71
mac-address 0C27.24BB.B531
type 6945
button 1:71
ephone 72
mac-address 0C27.24BB.C1E5
type 6945
button 1:72
ephone 73
mac-address 0C27.24BB.C208
type 6945
button 1:73
ephone 74
mac-address 0C27.24BB.C138
type 6945
button 1:74
ephone 75
mac-address 0C27.24BB.BEF2
type 6945
button 1:75
ephone 81
ephone 100
mac-address 189C.5D21.A4F4
line con 0
password 7 1311464A0803147B786E69
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 195
no exec
transport input all
stopbits 1
line vty 0 4
privilege level 15
logging synchronous
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
ntp master
end
11-30-2015 10:49 PM
Dear splifs_84
I had the same problem, I used the solution below:
no load 7821 sip78xx.10-3-1-12
no create profile
create profile
and then power cycle all the IP phone
If it persists please do these debug below when the phone tries to register:
debug ccsip messages
debug tftp events
Best Regards
Alcidio Tembe
12-18-2014 07:51 AM
So this phone is indeed getting all IP parameters like option 66, GW, IP?
12-18-2014 08:53 AM
Hi Brandon
When I look at the IPV4 menu it confirms that the 7821 is getting IP address and default gateway
12-18-2014 08:56 AM
What about the option 66? It needs to be able to get it's configuration file from CME. Option 66 is the SIP variant of Option 150 which is what SCCP uses. You might need to do a pcap.
12-18-2014 12:19 PM
Page 7 of the following link recommends that you use option 150 with the Cisco 7800 series phones and use option 66 if you cannot use option 150
Dynamic Host Configuration Protocol (DHCP) | DHCP dynamically allocates and assigns an IP address to network devices. DHCP enables you to connect an IP phone into the network and have the phone become operational without your needing to manually assign an IP address or to configure additional network parameters. | DHCP is enabled by default. If disabled, you must manually configure the IP address, subnet mask, gateway, and a TFTP server on each phone locally. Cisco recommends that you use DHCP custom option 150. With this method, you configure the TFTP server IP address as the option value. For additional supported DHCP configurations, go to the "Dynamic Host Configuration Protocol" chapter and the "Cisco TFTP" chapter in the Cisco Unified Communications Manager System Guide.
10-31-2015 05:31 AM
I am facing 1 issue in my cme
My branch office cme license has been finished so i have to register my branch office ip phones to HQ CME...but my branch office phone only seeing branch office cme not HQ cme...
Plesae help
