Showing results forĀ
Search instead forĀ
Did you mean:Ā
CME Sip Trunk to Service Provider not sending or receiving calls
I have configured a cme router with local calls on the 10xx range working properly. However, there was a request to connect to the service provider via Sip Trunking. The sip server  is 10.20.39.254 (service provider). I have been assigned a DID (dn 70) that I have associated with voice register pool 41. However, calls are neither going out nor coming into the local 'PBX'.
Attached is the configuration and some debugs.
Kindly advise on what could be amiss.
Thank you.
11 Replies 11
Ayodeji Okanlawon
Can you send us a debug ccsip message. include calling and called number.
Please rate all useful posts
Thank you for your response. In the attached text file, there is an output for debug ccsip message! The calling number is 377420, while the called number is 0979517265.
You need to contact your ITSP..They are saying the dialled number cant be found,.
*Oct 12 14:02:40.570: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 10.20.39.13:5060;branch=z9hG4bK61EA54F
To: <sip:0979517265@10.20.39.254>;tag=a142104-19046
From: "+260211377420"<sip:377420@10.20.39.13>;tag=342A6BC-1DA5
Call-ID: BA3FA61B-702011E5-92DB98ED-681E8A68@10.20.39.13
CSeq: 101 INVITE
User-Agent: ZTE Softswitch/1.0.0
Content-Length: 0
Let me check with my ITSP. Will revert. Do the configs look ok?
Hi Ayodeji,
I cleared the issue with my ITSP. It had to do with the way the provider expected the called number to be sent to them. Had to add some digits to my number.
However, I am now unable to receive incoming calls!
Kindly review the debug ccsip messages below:
What do you advise should be the session target? 10.20.33.4 or 10.20.39.254?
Also advise on any reasons why it is failing?
ZPPA_CME#
*Oct 14 08:13:42.675: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.20.39.13 SIP/2.0
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK099473fa.0
To: <sip:10.20.39.13>
Call-ID: 2e954192-0009-0167@10.20.33.4
CSeq: 1069466 OPTIONS
Accept: application/sdp
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:13:52.671: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK4d2166af.0
CSeq: 1069467 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:13:52.675: //240630/572A6FD29EE3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK4d2166af.0;received=10.20.39.254
To: <sip:10.20.39.13>;tag=C501A30-1A53
Date: Wed, 14 Oct 2015 08:13:52 GMT
Server: Cisco-SIPGateway/IOS-15.5.1.T
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 367
v=0
o=CiscoSystemsSIP-GW-UserAgent 1263 7926 IN IP4 10.20.39.13
s=SIP Call
c=IN IP4 10.20.39.13
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
*Oct 14 08:13:57.987: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:1042@172.17.1.1:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.0.18:5060;branch=z9hG4bK3e5503d8
From: "Principal Officer DA" <sip:1034@172.17.1.1>;tag=b838612fcc1f0b0410e34622-4c9b57bf
To: <sip:1@172.17.1.1>;tag=C4C41C4-DEB
Call-ID: b838612f-cc1f008c-5a930076-41cafb47@172.17.0.18
Max-Forwards: 70
Date: Wed, 14 Oct 2015 08:13:58 GMT
CSeq: 102 BYE
User-Agent: Cisco-CP7821/10.2.1
Content-Length: 0
Sent:
SIP/2.0 200 OK
Date: Wed, 14 Oct 2015 08:13:57 GMT
CSeq: 102 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=9246,OS=1308276,PR=9221,OR=1354997,PL=0,JI=0,LA=0,DU=238
Content-Length: 0
*Oct 14 08:13:57.991: //240490/BFBA58D89EC0/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:8690-3CE@172.17.0.13:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.17.1.1:5060;branch=z9hG4bK2866D120
From: "Principal Officer DA" <sip:1034@172.17.1.1>;tag=C4C4190-1D9B
To: <sip:1042@172.17.0.13>;tag=b838612fc6cd080a00709f2a-3ececc70
Date: Wed, 14 Oct 2015 08:09:40 GMT
Call-ID: C0ECBD90-718111E5-9EC798ED-681E8A68@172.17.1.1
User-Agent: Cisco-SIPGateway/IOS-15.5.1.T
Max-Forwards: 70
P-Asserted-Identity: "Principal Officer DA" <sip:1034@172.17.1.1>
Timestamp: 1444810437
CSeq: 102 BYE
P-RTP-Stat: PS=9221,OS=1354997,PR=9246,OR=1308276,PL=0,JI=0,LA=0,DU=238
Content-Length: 0
*Oct 14 08:13:58.119: //240490/BFBA58D89EC0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Server: Cisco-CP7821/10.2.1
Content-Length: 0
*Oct 14 08:14:02.671: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK331205dc.0
CSeq: 1069468 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:14:12.671: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK4b6a2276.0
CSeq: 1069469 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:14:22.671: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK164e0270.0
CSeq: 1069470 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:14:32.671: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK6fd60969.0
CSeq: 1069471 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:14:32.675: //240634/6F014EBA9EE7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK6fd60969.0;received=10.20.39.254
To: <sip:10.20.39.13>;tag=C50B66C-478
Date: Wed, 14 Oct 2015 08:14:32 GMT
Content-Length: 367
v=0
o=CiscoSystemsSIP-GW-UserAgent 8005 7598 IN IP4 10.20.39.13
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
*Oct 14 08:14:38.343: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1@172.17.1.1;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.17.0.55:5060;branch=z9hG4bK06077ab7
From: "Officer Compliance Monitoring" <sip:1041@172.17.1.1>;tag=b8386156de0900c462da26a2-373f5a99
Call-ID: b8386156-de090009-792ff31a-58e4405c@172.17.0.55
Max-Forwards: 70
Date: Wed, 14 Oct 2015 08:14:41 GMT
CSeq: 101 INVITE
Contact: <sip:868C-10D2@172.17.0.55:5060;transport=udp>
Expires: 180
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Officer Compliance Monitoring" <sip:1041@172.17.1.1>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Content-Length: 349
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 4995 0 IN IP4 172.17.0.55
s=SIP Call
t=0 0
m=audio 25106 RTP/AVP 8 0 18 102 116 101
c=IN IP4 172.17.0.55
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:102 L16/16000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
*Oct 14 08:14:38.351: //240635/7262C8959EE8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 14 Oct 2015 08:14:38 GMT
CSeq: 101 INVITE
Content-Length: 0
*Oct 14 08:14:38.367: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:1@172.17.1.1:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.0.55:5060;branch=z9hG4bK41099380
To: <sip:1@172.17.1.1>;tag=C50CC98-A39
From: <sip:1041@172.17.0.55>;tag=b8386156de0900c509e80fbf-640450e5
Call-ID: 726364BD-718211E5-9EED98ED-681E8A68@172.17.1.1
CSeq: 1000 NOTIFY
Event: kpml
Subscription-State: active; expires=7200
Max-Forwards: 70
Content-Length: 0
*Oct 14 08:14:38.547: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.0.55:5060;branch=z9hG4bK20b6c565
CSeq: 1001 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Content-Type: application/kpml-response+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="0" tag="Backspace OK"/>
*Oct 14 08:14:38.679: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.0.55:5060;branch=z9hG4bK49bdfeba
CSeq: 1002 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="3" tag="Backspace OK"/>
*Oct 14 08:14:38.815: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.0.55:5060;branch=z9hG4bK4c43f13e
Date: Wed, 14 Oct 2015 08:14:42 GMT
CSeq: 1003 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
*Oct 14 08:14:38.819: //240636/7262C8959EE8/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1033@172.17.0.6:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.1.1:5060;branch=z9hG4bK286701B69
From: "Officer Compliance Monitoring" <sip:1041@172.17.1.1>;tag=C50CE70-20C6
To: <sip:1033@172.17.0.6>
Call-ID: 72AB694A-718211E5-9EEF98ED-681E8A68@172.17.1.1
Min-SE:  2000
Cisco-Guid: 1919076501-1904349669-2666043629-1746831976
CSeq: 101 INVITE
Timestamp: 1444810478
Contact: <sip:1041@172.17.1.1:5060>
Expires: 180
Max-Forwards: 69
P-Asserted-Identity: "Officer Compliance Monitoring" <sip:1041@172.17.1.1>
Content-Length: 209
v=0
o=CiscoSystemsSIP-GW-UserAgent 6048 8972 IN IP4 172.17.1.1
s=SIP Call
c=IN IP4 172.17.1.1
t=0 0
m=audio 19226 RTP/AVP 0 19
c=IN IP4 172.17.1.1
a=rtpmap:19 CN/8000
a=ptime:20
*Oct 14 08:14:38.827: //240636/7262C8959EE8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Wed, 14 Oct 2015 08:14:43 GMT
CSeq: 101 INVITE
Contact: <sip:8678-FFB@172.17.0.6:5060;transport=udp>
Content-Length: 0
*Oct 14 08:14:38.839: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.0.55:5060;branch=z9hG4bK753e3038
CSeq: 1004 NOTIFY
Event: kpml
Subscription-State: terminated; reason=timeout
Max-Forwards: 70
Content-Length: 218
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="487" text="Subscription Exp" suppressed="false" forced_flush="false" digits="" tag="Backspace OK"/>
*Oct 14 08:14:38.891: //240636/7262C8959EE8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:1033@172.17.0.6>;tag=b838612fea7701706b6a1028-109b06e8
CSeq: 101 INVITE
Remote-Party-ID: "Stenographer" <sip:1033@172.17.1.1>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
*Oct 14 08:14:38.891: //240635/7262C8959EE8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:1@172.17.1.1>;tag=C50CEB8-112B
CSeq: 101 INVITE
Remote-Party-ID: "Stenographer" <sip:1033@172.17.1.1>;party=called;screen=yes;privacy=off
Contact: <sip:8678-FFB@172.17.1.1:5060>
Content-Length: 0
*Oct 14 08:14:41.371: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:1@172.17.1.1;user=phone SIP/2.0
Max-Forwards: 70
Date: Wed, 14 Oct 2015 08:14:44 GMT
CSeq: 101 CANCEL
Content-Length: 0
*Oct 14 08:14:41.371: //240635/7262C8959EE8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
*Oct 14 08:14:41.371: //240636/7262C8959EE8/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:1033@172.17.0.6:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1444810481
Content-Length: 0
Sent:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Content-Length: 0
*Oct 14 08:14:41.375: //240636/7262C8959EE8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Wed, 14 Oct 2015 08:14:45 GMT
CSeq: 101 CANCEL
Content-Length: 0
*Oct 14 08:14:41.379: //240636/7262C8959EE8/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
*Oct 14 08:14:41.379: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1033@172.17.0.6:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Received:
ACK sip:1@172.17.1.1;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Oct 14 08:14:42.671: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK61a233ee.0
CSeq: 1069472 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:14:52.671: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK341465c0.0
CSeq: 1069473 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:15:02.611: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:172.17.1.1 SIP/2.0
Via: SIP/2.0/UDP 172.17.0.55:5060;branch=z9hG4bK23c95ba3
From: <sip:1041@172.17.1.1>;tag=b8386156de0900c630b7ffc6-2079124a
To: <sip:1041@172.17.1.1>
Call-ID: b8386156-de090002-377c9c5e-5c768ca2@172.17.0.55
Max-Forwards: 70
Date: Wed, 14 Oct 2015 08:15:05 GMT
CSeq: 193 REGISTER
Contact: <sip:868C-10D2@172.17.0.55:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-b8386156de09>";+u.sip!devicename.ccm.cisco.com="SEPB8386156DE09";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
*Oct 14 08:15:02.611: //240639/80D9C3A39EF2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:1041@172.17.1.1>;tag=C512B60-1C4B
Date: Wed, 14 Oct 2015 08:15:02 GMT
CSeq: 193 REGISTER
Supported: X-cisco-cme-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:1041@172.17.0.55:5060>;expires=600
Expires:  600
Content-Length: 0
*Oct 14 08:15:02.671: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK2c993f12.0
CSeq: 1069474 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:15:02.783: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.0.55:5060;branch=z9hG4bK24cf1c85
From: <sip:377420@172.17.1.1>;tag=b8386156de0900c7079fb381-5dfe56b9
To: <sip:377420@172.17.1.1>
Call-ID: b8386156-de090003-5397c307-56e77ec9@172.17.0.55
Max-Forwards: 70
CSeq: 193 REGISTER
Contact: <sip:868C-350@172.17.0.55:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-b8386156de09>";+u.sip!devicename.ccm.cisco.com="SEPB8386156DE09";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
*Oct 14 08:15:02.783: //240641/80F401ED9EF4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:377420@172.17.1.1>;tag=C512C0C-63A
CSeq: 193 REGISTER
Contact: <sip:377420@172.17.0.55:5060>;expires=600
Expires:  600
Content-Length: 0
*Oct 14 08:15:12.667: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK160b2fc2.0
CSeq: 1069475 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:15:12.671: //240642/86D82DA19EF5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK160b2fc2.0;received=10.20.39.254
To: <sip:10.20.39.13>;tag=C5152A8-170E
Date: Wed, 14 Oct 2015 08:15:12 GMT
Content-Length: 367
v=0
o=CiscoSystemsSIP-GW-UserAgent 5911 8031 IN IP4 10.20.39.13
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
*Oct 14 08:15:22.670: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK123c0c8d.0
CSeq: 1069476 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:15:32.666: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK332d5bc4.0
CSeq: 1069477 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:15:42.666: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK4c54485f.0
CSeq: 1069478 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:15:52.670: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK58831c3a.0
CSeq: 1069479 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:15:52.674: //240646/9EB0E1999EF9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK58831c3a.0;received=10.20.39.254
To: <sip:10.20.39.13>;tag=C51EEF0-196A
Date: Wed, 14 Oct 2015 08:15:52 GMT
Content-Length: 367
v=0
o=CiscoSystemsSIP-GW-UserAgent 5534 7205 IN IP4 10.20.39.13
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
*Oct 14 08:16:02.662: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK305b3151.0
CSeq: 1069480 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:16:12.662: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK5877224f.0
CSeq: 1069481 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:16:22.666: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK751c1861.0
CSeq: 1069482 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:16:30.178: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.0.7:5060;branch=z9hG4bK653f4e74
From: <sip:1047@172.17.1.1>;tag=b838612fc8f106ec08bbe5dc-1ce9c8eb
To: <sip:1047@172.17.1.1>
Call-ID: b838612f-c8f10047-58cadf20-4a3b66ea@172.17.0.7
Max-Forwards: 70
Date: Wed, 14 Oct 2015 08:16:38 GMT
CSeq: 2965 REGISTER
Contact: <sip:869C-12DF@172.17.0.7:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-b838612fc8f1>";+u.sip!devicename.ccm.cisco.com="SEPB838612FC8F1";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
*Oct 14 08:16:30.178: //240706/B50B822B9EFD/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:1047@172.17.1.1>;tag=C528170-441
Date: Wed, 14 Oct 2015 08:16:30 GMT
CSeq: 2965 REGISTER
Contact: <sip:1047@172.17.0.7:5060>;expires=600
Expires:  600
Content-Length: 0
*Oct 14 08:16:32.662: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK240a34f8.0
CSeq: 1069483 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:16:32.662: //240707/B68687989EFE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK240a34f8.0;received=10.20.39.254
To: <sip:10.20.39.13>;tag=C528B24-1A88
Date: Wed, 14 Oct 2015 08:16:32 GMT
Content-Length: 367
v=0
o=CiscoSystemsSIP-GW-UserAgent 6638 8476 IN IP4 10.20.39.13
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
*Oct 14 08:16:42.662: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK61a9182b.0
CSeq: 1069484 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:16:52.662: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK4c63786b.0
CSeq: 1069485 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:17:02.658: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK7fb613bc.0
CSeq: 1069486 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:17:12.658: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK277b74b7.0
CSeq: 1069487 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:17:12.662: //240711/CE5D667F9F02/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK277b74b7.0;received=10.20.39.254
To: <sip:10.20.39.13>;tag=C532760-19FE
Date: Wed, 14 Oct 2015 08:17:12 GMT
Content-Length: 367
v=0
o=CiscoSystemsSIP-GW-UserAgent 8927 2169 IN IP4 10.20.39.13
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
*Oct 14 08:17:22.658: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK75e47bd9.0
CSeq: 1069488 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:17:24.070: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.0.51:5060;branch=z9hG4bK5de32e93
From: <sip:1026@172.17.1.1>;tag=b838612fb468162d066ac87b-4584231e
To: <sip:1026@172.17.1.1>
Call-ID: b838612f-b46801c9-1dd70e12-0ba5de15@172.17.0.51
Max-Forwards: 70
Date: Wed, 14 Oct 2015 08:17:24 GMT
CSeq: 9077 REGISTER
Contact: <sip:8668-152D@172.17.0.51:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-b838612fb468>";+u.sip!devicename.ccm.cisco.com="SEPB838612FB468";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
*Oct 14 08:17:24.074: //240713/D52ABAA69F04/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:1026@172.17.1.1>;tag=C5353F4-1021
CSeq: 9077 REGISTER
Contact: <sip:1026@172.17.0.51:5060>;expires=600
Expires:  600
Content-Length: 0
*Oct 14 08:17:32.686: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK01c26cb0.0
CSeq: 1069489 OPTIONS
Max-Forwards: 10
Content-Length: 0
*Oct 14 08:17:34.142: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.0.40:5060;branch=z9hG4bK2d983236
From: <sip:377408@172.17.1.1>;tag=b838612fc55d01f554b2f157-165e6a08
To: <sip:377408@172.17.1.1>
Call-ID: b838612f-c55d0011-0d0160c3-537a9f42@172.17.0.40
Max-Forwards: 70
Date: Wed, 14 Oct 2015 08:17:41 GMT
CSeq: 234 REGISTER
Contact: <sip:794C73C-F80@172.17.0.40:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-b838612fc55d>";+u.sip!devicename.ccm.cisco.com="SEPB838612FC55D";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
*Oct 14 08:17:34.142: //240715/DB2B95DD9F06/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:377408@172.17.1.1>;tag=C537B4C-AEA
Date: Wed, 14 Oct 2015 08:17:34 GMT
CSeq: 234 REGISTER
Contact: <sip:377408@172.17.0.40:5060>;expires=600
Expires:  600
Content-Length: 0
*Oct 14 08:17:34.306: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.0.40:5060;branch=z9hG4bK4f5615aa
From: <sip:1015@172.17.1.1>;tag=b838612fc55d01f61420d3cb-09c4d010
To: <sip:1015@172.17.1.1>
Call-ID: b838612f-c55d0010-5817ae0c-733ea553@172.17.0.40
Max-Forwards: 70
CSeq: 437 REGISTER
Contact: <sip:864C-2098@172.17.0.40:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-b838612fc55d>";+u.sip!devicename.ccm.cisco.com="SEPB838612FC55D";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
*Oct 14 08:17:34.306: //240716/DB449BD79F07/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:1015@172.17.1.1>;tag=C537BF0-250C
CSeq: 437 REGISTER
Contact: <sip:1015@172.17.0.40:5060>;expires=600
Expires:  600
Content-Length: 0
*Oct 14 08:17:35.238: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.0.41:5060;branch=z9hG4bK494a6ece
From: <sip:377409@172.17.1.1>;tag=b838612fd016022440425238-75a20bae
To: <sip:377409@172.17.1.1>
Call-ID: b838612f-d016002c-5a9988f6-43f11c5c@172.17.0.41
Max-Forwards: 70
Date: Wed, 14 Oct 2015 08:17:42 GMT
CSeq: 234 REGISTER
Contact: <sip:794C748-1E7B@172.17.0.41:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-b838612fd016>";+u.sip!devicename.ccm.cisco.com="SEPB838612FD016";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
*Oct 14 08:17:35.242: //240717/DBD2D1E69F08/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:377409@172.17.1.1>;tag=C537F94-C73
Date: Wed, 14 Oct 2015 08:17:35 GMT
CSeq: 234 REGISTER
Contact: <sip:377409@172.17.0.41:5060>;expires=600
Expires:  600
Content-Length: 0
*Oct 14 08:17:35.482: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.0.25:5060;branch=z9hG4bK5956bc15
From: <sip:377407@172.17.1.1>;tag=b838612fef4c022308bbb286-2a11f7b3
To: <sip:377407@172.17.1.1>
Call-ID: b838612f-ef4c000f-63077f86-5f029c8b@172.17.0.25
Max-Forwards: 70
Date: Wed, 14 Oct 2015 08:17:43 GMT
CSeq: 234 REGISTER
Contact: <sip:794C730-1A3C@172.17.0.25:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-b838612fef4c>";+u.sip!devicename.ccm.cisco.com="SEPB838612FEF4C";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
There is no inbound PSTN call in this trace. The only call here is from 1041 to 1033.
It is possible the call is not making it to you at all. In which case you still need to contact your provider
Doesn't this exchange imply there is an inbound conversation?!
Received:
Via: SIP/2.0/UDP online-test:5060;maddr=10.20.39.254;branch=z9hG4bK72ea3ebd.0
CSeq: 1069351 OPTIONS
Max-Forwards: 10
Content-Length: 0
This is an OPTIONS ping. Its not used for routing calls. Its used to check the status of a sip trunk..
You need a RURI (request URI) to make requests for a call..E.g
Received:
Please refer to this document to understand more on how SIP dialog works..
https://supportforums.cisco.com/document/113271/understanding-sip-traces
The issue has been closed. Actually, had to do some clean up on my CME router for calls to start coming in. There was duplicity of subinterfaces that had identical vlans!
Thanks for your support.
Well glad to help. But you didn't rate any post. We say thanks by rating posts here..
jsulliva
Here's a link to a video with config's on setting up a basic SIP trunk.
https://www.youtube.com/watch?v=-meBR1Ag1YY
My pointers for you are:
  • Double NAT...ughhhh not good.  My issues stemmed directly from that. If possible remove double NAT.
  • Statically define a NAT Port to SIP port in case of dynamic allocation over port range.
  • SIP-UA needs to associate user credentials with profile.
Good luck!!!
