CME SIP trunks failing to come up...
yamikani2g2
Good day expert.
I have an issue
1. My service provider says my CME is not registering issue is the have give me 2 IP addresses one they say is for signalling the other is for media? now which one do i put under here
dial-peer voice 4000 voip
session target ipv4:10.X.X.X
2. How do i also check exactly what is happening when i call the phones are quite when i call out
Debug ccsip bring a lot of stuff
Any pointers to this will be appreciated
George Sotiropoulos
1. Session Target (session target ipv4:10.X.X.X)  is the IP address of the Provider SIP Server Side.
2. The commands that you may use are the following:
Show call active voice compact
show sip-ua register status
Would you like to post part of your running configuration to help you accordingly?
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
OUTPUT BELOW
VOIP-RTR#show sip-ua register status
Registrar is not configured
But also i get this ..
%SEC-6-IPACCESSLOGP: list 101 permitted udp 192.168.10.1(0) -> 10.9.6.18(0), 1 packet
Please note 10.9.6.18 is the said signalling IP address that i configured as my SIP server
what i configured and please find attached my running config
session target ipv4:10.9.6.18
In my running config i will erase what is not necessary for VoIP
thanks
It looks like you use the same IP address on your sub-interface Gi0/0.10  and on the sip server IP address
sip-server 192.168.10.1
Please note that the sip-server IP address is the IP address on the "other-side" ie the IP address of your Telephony Provider. So you may replace/correct this IP address and replace the IP address on the dial-peers with the command "session target sip-server"
Also, have you cross-checked with the provider that there is no authenication on your SIP connectivity with the provider, as an example
"credentials number +44XXXXXXX username +44XXXXXXX@provider.com password 7 00000000fff realm provider.com"
G
