CME to CME integration
cris_jimenez
Level 2
Level 2
hello folks
do you know or could you share a document that will explain cme to cme integration ?
thank you
Basically, you would just have dial-peers on each cme pointing to the remote site:
example:
California router
dial-peer voice 100 voip
description **Calls to Indianapolis**
destination-pattern ....(extensions in Indy)
session target ipv4:x.x.x.x (IP of Indy router)
dtmf-relay h245-alphanumeric
Indy router
description **Calls to California**
destination-pattern ....(extensions in Cali)
session target ipv4:x.x.x.x (IP of Cali router)
Hope that helped, if so please rate.
7 Replies 7
Can you be more specific? Are you just trying to network CME's at 2 different sites? Please explain further.
yes
I'd like to integrate 2 CME systems in 2 different locations
Indianapolis, California
there's going to be a VPN tunnel between the 2 sites and I'd like to have 4 digit dialing between the 2 sites
the site in indianapolis currently has cme version 4.2, the site in california has cme version 4.1
and i think i may need a GK for BW control, but i'm not sure i haven't found something that will explain how to integrate the 2 systems together
example:
California router
Indy router
hello,
I configured the dial-peers however i can only call the phones from california to indy. if i try to call from indy to california i get fast busy ... what am i doing wrong ?
problem resolved
thanks
how did you resolve it
I did a debug voice ccapi inout and realize that when i was placing the call it was actually getting to the remote ccme however the incoming dial-peer was wrong i reconfigure it and it fix my issue
