CME- Translation Profile Help
fathar
Hi Every one,
I am new bee in voice and need urgent help to solve one issue for my company..
I am running CME 8.5 and two 100 number ranges are terminating for inbound/outbound calls.
Incoming calls are appearing with right number to the users but outgoing calls to every where
including mobile and local are not showing individual extensions(Full numbers), instead they going with
general main line number..I have tried couple of settings in outgoing profile and not using any dial-pattern or
num-exp commands in the configs. Also profile is applied to POTS peers in a correct way.
The two number ranges are  03888668XX  and 03888669xx  - could some one please suggest what shoud
be the configurations for outbound translation-profile ?
cheers,
Athar
sumimanc
From What I understand is you want expand 800 and 900 number so that when the calls go out it should display full did.
router#conf t
router-config)#
voice translation-rule 10
rule 1 /^8\(..\)$/ /03888668\1/
rule 2 /^9\(..\)$/ /03888669\1/
voice translation-profile expandcalling
translate calling 10
and apply that in the outgoing dial-peer
dial-peer voice 10 pots
translation-profile outgoing expandcalling
destination-patter
port
Here are the results of this rule
BR2-RTR#test voice translation-rule 10 899
Matched with rule 1
Original number: 899    Translated number: 0388866899
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
BR2-RTR#test voice translation-rule 10 999
Matched with rule 2
Original number: 999    Translated number: 0388866999
Please Rate if you find this info useful.
sumit
5 Replies 5
gsidhu
Level 3
Level 3
I suggest that you first run 'debug isdn q931' (and 'term mon' if you are telneted to the gateway) and see what calling number CME is sending the Telco
Also check with the Telco if outbound caller id has been set - you should'nt need to configure outbound profiles.
Please rate helpful posts
sumimanc
router#conf t
router-config)#
destination-patter
port
Matched with rule 1
Matched with rule 2
sumit
Hi Guys,
Thanks for the prompt response.
I am checking with our Telco if write configurations are in place before trying the tranlsation
rule.
Would get back with updates and rating.
cheers,
Athar
Hey Sumit,
Your reply worked perfectly fine.... Test command was especially helpful
cheers,
Athar
Hi Athar,
Glad to help
Cheers,
sumit
