Find Part Numbers
Bruno Rangel
Hi Guys
How I can get a Part Number of a Device ?
Do you know a tool for do it?
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
you need to look at data sheets for MCS servers
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/products_data_sheets_list.html
your server
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/data_sheet_c78-564637.html
You have
Hard disks
Four 146-GB SAS 2.5-in. hot-swap
Your part numbers
Spare Part Number
Description
Spare 146GB 10K SAS drive with 6Gbps controller
HDD-7835-I3-146=
Spare 300GB 10K SAS drive with 6Gbps controller
HDD-7835-I3-300=
And you can always get them newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16822135013
http://www.newegg.com/Product/Product.aspx?Item=N82E16822135015
Leo Laohoo
What device(s) are you talking about?  Phones?  Servers?
Hi thanks for reply ...
I want know in general devices ...
For example:
If I need replace a hard Driver on MCS7845I3. How find the Part number for that? There any command on CUCM to get it?
Cheers
Bruno Rangel
The serial number of MCS7845I3 will be used to get the hard-drive replacement.
You need to open a case with TAC and also should reach out to the IBM team to verify if the hard-drive is good or bad.
Mudit
PS .. Rate if useful..!!
your server
You have
Hard disks
Your part numbers
Spare Part Number
Description
HDD-7835-I3-146=
HDD-7835-I3-300=
