CME translation rule by different caller
samhopealpha
Dear Everybody,
Is it possible to translate the "called number" according to different "Caller number" ?
For example,
PersonA (1000) calls to PersonZ (3105555), it will be translated to 2310555
PersonB (2000) calls to PersonZ (3105555), it will be translated to 5553105555
For the CUCM, I can translate it by using the CSS and route pattern combination
But for the CME, I have no idea on how to do it?
Any body can help?
Thanks in advance
Sam
Anas Abueideh
Level 9
Level 9
you will  solve your issue by using corlists, it is like the CSS in CUCM. the above post is helpful for inbound calls from pstn
kindly find the below config
voice translation-rule 1
  rule 1 /3105555/ /2310555/
voice translation-rule 2
  rule 1 /3105555/ /5553105555/
voice translation-profile phoneA
  translate called 1
voice translation-profile phoneB
  translate called 2
dial-peer cor custom
name phoneA
name phoneB
dial-peer cor list phoneA
member phoneA
dial-peer cor list phoneB
member phoneB
dial-peer cor list callingphoneA
member phoneA
dial-peer cor list callingphoneB
member phoneB
ephone-dn 1
number 1000
corlist incoming callingphoneA
ephone-dn 2
number 2000
corlist incoming callingphoneB
dial-peer voice 1 pots
  destination-pattern 3105555
  translation-profile outgoing phoneA
corlist outgoing phoneA
port 0/0/0
forward-digits all
dial-peer voice 2 pots
  translation-profile outgoing phoneB
corlist outgoing phoneB
port 0/0/0
forward-digits all
Anas
please don't forget to rate the helpful posts
7 Replies 7
Hi.
You can achieve this with a translation profile on a pots dialpeer.
Eg.
rule 1 /^1000/ /2310555/
rule 2 /^2000/ /5553105555/
voice tranlation-profile out
translate calling 1
dial-peer voice 10 pots
translation-profile outgoing out
Carlo
Please rate all helpful posts "The more you help the more you learn"
islam.kamal
Level 10
Level 10
1-
Voice translation-rule 1
voice translation-profile outgoing
translate calling 1
translation-profile outgoing outgoing
voice port  (based on your connection FXO or E1 &T1).
for test
router# test voice translation-rule 1 1000
thank you
please rate if this will help
Anas Abueideh
Level 9
Level 9
for this requirement you need to match based on the calling number not called-number. you need to use answer-address instead of incoming called-number. kindly find the below link for more info
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
you need to create two dial-peers with 2 answer-address, and then apply the appropriate translation
Anas
Anas Abueideh
Level 9
Level 9
  translate called 1
  translate called 2
name phoneA
name phoneB
member phoneA
member phoneB
member phoneA
member phoneB
ephone-dn 1
number 1000
ephone-dn 2
number 2000
port 0/0/0
forward-digits all
port 0/0/0
forward-digits all
Anas
Hi Anas.
Why complicate things where a translation-profile would match the calling on one or multiple dial-peer and would apply the translation for out calls.
Yes your soultion works (5P) , but for an easier deploy just a translation is enough.
For a more granualr calling match, answer-address woul be preferrable.
Carlo
Hi Carlo,
thanks for the rating.  the translation without corelist will not work, because phoneA and phoneB will dial the same destination number. he want to translate the called number not the calling number.
if you read the question carefully, you will figure out my understanding.
regards
Anas
Ops!! I totally confused called with calling
Sorry.
Here i can give my 5 cents now
A dial-peer with answer address  and tranlation profile also would work
voice translation-profile outPhoneA
translate called 1
voice translation-profile outPhoneB
translate called 2
dial-peer voice 10 voip
answer-address 1000
voice translation-profile out outPhoneA
dial-peer voice 20 voip
answer-address 2000
voice translation-profile out outPhoneB
HTH (hope )
Carlo
