cme upgrade
amralrazzaz
Level 5
Level 5
Dears
i need your support to know if i still can upgrade the ccme 10.5 to 12.5 for example ???
i have 2911 ISR router and i dont know if still i can upgrage the cme or not becuase the router i have is EOL and i dont have budget for this year to replacement
thanks
please confirm
also
whats the difference between
ProductCME-UL
Product DescriptionCisco Communication Manager Express (CME) - 1 User License
and
ProductCON-ECMU-CMEULCTG
Product DescriptionSWSS UPGRADES Cisco Communication Manager Express (CME
because i need to upgrade the ccme license and i dont know what difference ? and cme when i upgrade it i should pay for each ip cisco phone a cme 12.5 ? i already have the smartnet license for all phone or srst 25 seats so need to understand please
amr alrazzaz
Vaijanath Sonvane
CME 12.1 and later versions are not supported on Cisco 2900/3900 Series routers. So you can not upgrade from 10.5 to 12.5 on your Cisco 2911. Please check this compatibility guide for Unified CME 12.5:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme125spc.html
You can upgrade to 12.0 which is supported on Cisco 2900/3900 Series routers. Here is the compatibility guide for Unified CME 12.0:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme12spc.html
CME-UL is a CME endpoint license and CON-ECMU-CMEULCTG is a smartnet/maintenance contract for Cisco Support or CME Software upgrade.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
