CME - Vanguard
Alan Couto
Hello friends,
I am making tests between CME and Vanguard using the codec G723. When I make calls from Vanguard to CUCME works perfectly (see the attached show's). But when I try to make a call to an analog phone that is attached at Vanguard FXS the phone rings but when I try to answer to the call, the call drop and I receive a loud and fast busy tone.
It seems that CME does not activate the transcode for any reason that I don't know.
See the show run attached,  need help...
Many Thanks.
11 Accepted Solutions
Ayodeji Okanlawon
Hi Alan,
The problem is not with CME. When calls coming to CME, cme invokes a xcoder and the call succeeds. When call is going to Vanguard, vanguard needs to invoke the cme. I doubt if vanguard can do that so I suggest you configure calls going to Vanguard from cme to use the same codec. Either g711 or G723.
When a call comes in from Vanguard it comes in as G723 and the phone is on G711 so cme invookes a xcoder. The same should happen in reverse but its vanguard that need to invoke xcoder...
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts
Alan,
Is a little bit tricky. The only way this can work is to set the call up such that call going to vanguard will use g723. Since cisco IP phones cant use G723, then we have to find a way to xcode the call on CME to G723 before it goes to vanguard.
On CME you can try this...
dial-peer voice xxxx voip
incoming called number yyyyy
codec G723
Where xxxxx= any dial-peer number range eg 2000
and yyyy= the vanguard called number
So this way when ip phone originate call on g711, the outboung leg is set to G723, then cme should invove xcoder and when that is done then the call wil go to vanguard using g723...
Can you send a sh run of your gateway..or if you can try what I suggested..test and then send me a debug voip ccapi inout
No,
It is not similar. You are using voice-class codec, which means that call from IP Phones on CME will always use G711.
You need to change it like I suggested..
dial-peer voice 28 voip
destination-pattern 4027....
session target ipv4:192.168.0.2 ( if this is your Vanguard router)
codec G723
This way all calls going to vanguard will use G723 and cme will be forced to xcode before the call goes to vanguard.
Can you quickly send
Please leave the config as it is now with codec g723 on the dial-peer to vanguard
Alan,
I looked at the trace and yes g723 was sent to vanguard, vanguard also responded with g723. But the call disconnected with normal cause..
Can you send a
debug ephone state
Lets see whats happening on the ip phone side..
NB: i will be a way for a while so i will respond when im back
Alan,
So yes The debug confirms that the xcoding is not happening and the disconnect reason also confirms is a codc mismactch problem...We just need to figure out why..I will think about it..
011807: *Jun 12 17:13:47.746: dn_tone_control DN=2 chan 1 tonetype=0:DtSilence onoff=0 pid=263
011808: *Jun 12 17:13:47.746: ephone-2[4]:OpenReceive DN 2 chan 1 codec 4:G711Ulaw64k  duration 20 ms bytes 160
011809: *Jun 12 17:13:47.750: DN: 2, CHAN: 1, voice_hcmask: 0x890000F
011810: *Jun 12 17:13:47.754: dn_tone_control DN=2 chan 1 tonetype=37:DtReorderTone onoff=1 pid=263
011811: *Jun 12 17:13:47.754: ephone-2[1/4][AN43E1B195B0001]:DN 2 disc reason 65 bear cap not impl state ALERTING
+++We see the gateway sending OLC to the router.+++
011256: *Jun 12 16:50:39.582: H245 FS OLC OUTGOING PDU ::=
value OpenLogicalChannel ::=
      forwardLogicalChannelNumber 1
      forwardLogicalChannelParameters
        dataType audioData : g7231 :
The vanguard resposnd with OLC
H225.0 INCOMING PDU ::=
centralizedVideo FALSE
              distributedVideo FALSE
          capabilityTableEntryNumber 1
          capability receiveAndTransmitAudioCapability : g7231        capability receiveAudioCapability : g7231 :
Lets do this, send me the ff for the successful incoming call..
debug ephone state
sh voip rtp connection
Thanks..you removed
debug h225 asn1 and h245 asn1..
Can you please send those
I have looked at it and I see that on the call that worked. Call from Vanguard to CME, Vandguard sends its media IP in the h245 negotiation. But for the call that is failing Vanguard is not doing so.
++++++++Here...Succesful call++++++++
H245 FS OLC INCOMING PDU ::=
          maxAl-sduAudioFrames 2
          silenceSuppression FALSE
        multiplexParameters h2250LogicalChannelParameters :
          sessionID 1
          mediaControlChannel unicastAddress : iPAddress :
            network 'C0A80002'H  (192.168.0.2) Vanguard IP where RTP should be send and RTP port 16521
            tsapIdentifier 16521
++++++++On the failed call+++++
        mcCapability
          centralizedConferenceMC FALSE
          decentralizedConferenceMC FALSE
        rtcpVideoControlCapability FALSE
        mediaPacketizationCapability
          h261aVideoPacketization FALSE
      capabilityTable
            maxAl-sduAudioFrames 1
            silenceSuppression TRUE
          capabilityTableEntryNumber 16
          capability receiveAudioCapability : nonStandard :
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '47373233316172'H
Unless your trace was incomplete then something is not quite right with the way vanguard is sending its OLC for calls to it.
I like you to do this test..
Please do a test call again and send me only
debug h225 asn1
debug h245asn1
run them at the same time
2. Can you confugre vanguard to use g711u just for test? If so please do and change the codec on dial-peer to vanguard to use g711u. Then test and let me know
Ok. Let  me know when you change the codec. You can use G729 too. IP Phones support G729. If vanguard does not support G711u..
The log you sent me is for a succesful call from vanduard to cme. I want a failed call from cme to vanguard
Alan.
I am glad to have helped. But you have not rated any of my posts! Feel free to rate posts that helped
24 Replies 24
Ayodeji Okanlawon
Hi Alan,
aokanlawon
Many thanks for replaying. Actually I must use G723 at Vanguard side because of some particularities of the project. If Vanguard can not make xcode (I really think that does not) do you have any ideia for that case? May we can use a ISR as a cube/gatekeeper dedicated to make transcoding...
Thanks in advance!!
Alan.
Alan,
codec G723
It seems that my configuration is similar what you the one you are asking me to test.. See below:
dial-peer voice 10 voip
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
voice-class codec 1
My show run is already attached at the case (CME_11_06.txt.zip)
Also.. See the debug plus show commands too.. attached now (cme to vanguard and vanguard to cme)
Thanks again!!
No,
codec G723
CME_ISRG2(config)#do sh run | begin dial-peer
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 100 voip
destination-pattern 0T
session target sip-server
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
voice-class codec 1
dtmf-relay rtp-nte
codec g723r63
gateway
timer receive-rtp 1200
CME_ISRG2(config)#dial-peer
CME_ISRG2(config)#dial-peer voice 28
CME_ISRG2(config-dial-peer)#codec g723r53
The call continue to drop (with both codec r53 and r63) , no xcoding.
Thanks...
I've also tried on this way:
voice-class codec 2
voice class codec 2
codec preference 1 g723r63
codec preference 2 g723ar63
codec preference 3 g723r53
codec preference 4 g723ar53
aokanlawon
See attached... thanks...
Alan,
Can you send a
debug ephone state
aokanlawon
See attached  the debug ephone state,
many thanks,
Alan.
Alan,
aokanlawon,
thanks for the return.. If you need anything else tell me, I am really without idea :/
again many thanks for the help...
Alan.
debug ephone state
