IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6166 Views
  • 14 replies
Resolved! CME - Vanguard
Hello friends,I am making tests between CME and Vanguard using the codec G723. When I make calls from Vanguard to CUCME works perfectly (see the attached show's). But when I try to make a call to an analog phone that is attached at Vanguard FXS the p...
Alan Couto by Level 1
  • 2420 Views
  • 24 replies
Good morning people,I'm having a problem in the FXS ports on my router.The problem is the following ....The FXS extensions on the card connected the router can not make connection .... when they dial, since the busy direct. Also, they are not ringing...
     I have a UC540 which at first was functioning well and super. Afterwaards it stop giving ip address to cisci ip phones.     Even after reseting and using the default config it does give or see any phones, but when you statical ip address are put...
divine007 by Level 1
  • 441 Views
  • 2 replies
Hello Everyone,I have installed a cluster of CUCM 8.6 and registered 10 Cisco IP Phones. All the CUCM's configurations are default, no specific parameter has been alterned.I have a situation:One IP Phone 7965 has enable Call Forward All to a Cisco IP...
adidibra1 by Level 1
  • 2249 Views
  • 3 replies
