CME with SIP Trunk and T.38 Fax Server
d.haeni
Level 4
Level 4
I have an operational CME with a SIP Trunk to a SIP Provider. The SIP Provider uses T.38 for FoIP.
Now I would like to route one of the DDI numbers to a Fax Server that supports both H.323 and SIP with T.38.
1. Is this feasible at all?
2. Would you use H.323 or SIP with the Fax Server?
3. What is the necessary configuration on the CME?
Your help is greatly appreciated
/David
Vladimir Savostin
Hello David,
Yes
If FAX Server supports both H323 and SIP it does not matter which one to use.
There are some limitations for SIP-H323 and SIP-SIP calls though, you can check CUBE config guide for details:
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb_book/vb_book.html
First of all you will need IOS with -ivs prefix for CUBE(IPIPGW) fatures to work.
Then configure your GW to support IP-to-IP calls and T.38 FAX protocol:
voice service voip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38
Vladimir Savostin
Hello David,
Yes
voice service voip
fax protocol t38
Vladimir - exactly what I was after!
Thank you very much!
