CME
Ahmad Kefaya
Hey All,
my problem:
i'm using CME , the phone is take call , but if is not answer the call will still ring until you pickup the phone and close.
how i can solved this problem..
Best Regards,
6 Replies 6
Tagir Temirgaliyev
fxo port?
Hey Tagir ,
Yes it's FXO port.
I make connection plar under the port.
and I don't need to transfer the call to another phone I want to disconnect the call if the agent not answer.
Best Regards,
Ahmad Kefaya.
you need to configure correct CPTONE under voice port
Hi Tagir ,
i make the correct CPTONE , but the problem is still..
Best Regards,
Ahmad Kefaya.
aateek singh
Hi ahmadmkefaya,
You need to configure call forwarding to another number when no answer is received from a Cisco Unified IP phone.You can set the maximum time out so that after a specific time (in secs) if call is not answered it will be transferred to another number
please refer to the following docs
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmetrans.html
Aateek Singh
Network Engineer
Spooster IT Services
Hey aateek ,
I don't want to use this option I want to send disconnect tone..
Best Regards,
Ahmad Kefaya.
