CME7.1 and Pin Code (after-hours block) Problem
Salvo_Phl
Hi All,
I need to configure Pin Code dialing for a customer. I have followed the suggestions from other forum users with the After-Hours Blocking process.
Below is the configuration I have implemented to test with :
dial-peer voice 83 pots
corlist outgoing Call-Cellphones
description CellPhone Calls
destination-pattern 0[78][^5].......
port 0/2/0:15
forward-digits all
telephony-service
<ommited>
login timeout 2
after-hours block pattern 1 0831231234
after-hours day Sun 00:01 23:59
after-hours day Sat 00:01 23:59
after-hours day Mon 00:01 23:59
after-hours day Tue 00:01 23:59
after-hours day Wed 00:01 23:59
after-hours day Thu 00:01 23:59
after-hours day Fri 00:01 23:59
create cnf-files version-stamp 7960 Aug 19 2011 10:58:27
ephone-template  1
softkeys idle  Newcall Login Cfwdall Pickup
ephone  31
mac-address 0026.CB3C.0D3F
ephone-template 1
type 7911
button  1:31
pin 12345
Problem is: I press the Login softket and enter the pin number, then, after I dial the last digit of the blocked pattern number, I get a ringout tone with the following debug :
Aug 19 09:11:56.866: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 1D3D4CABC97A11E09165C0A27B310858, SetupTime 11:11:53.486 ZA Fri Aug 19 2011, PeerAddress 8031, PeerSubAddress , DisconnectCause 3F  , DisconnectText service or option not available unspecified (63), ConnectTime 11:11:56.866 ZA Fri Aug 19 2011, DisconnectTime 11:11:56.866 ZA Fri Aug 19 2011, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
If I remove the block pattern command, the call completes successfully.
Can anyone please assist.
Thanks in advance.
Phil
6 Replies 6
Prashanthi Velpula
Hi Phil,
I did the same config in my lab and it worked fine .
I only didnt have the corlist config under the dial-peer. Can you tell me what is that corlist you are trying to configure. if there isnt any list, please remove the config and test.
Also with the above config: in that specific time and date, you can only dial 0831231234 , unless and until you are logged in.
To verify if you are logged in. After you press Login soft-key and enter pin 12345:
Issue the command show ephone login to check if the phone is logged in. The output will be as below:
ephone x        Pin enabled:local       Logged-in:TRUE
Hope the above is informative and below is the resource link for configuring call blocking:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html#wp1014495
Thanks and Regards
Prashanthi Velpula
Thank you for the reply.
I upgraded the IOS to 15.1 so that I could use FAC on CME 8.5.
I used this guide to help me get it working :
https://supportforums.cisco.com/message/3425149
Thanks.
Phil
Hi Phil,
Thank you for giving the update with current status. Glad to hear that you were able to get resolution on this issue.
Thanks and Regards
Prashanthi Velpula
zeuscyril
Level 4
Level 4
hi guys,
is anybody succedeed with CME 8.6 with after hours block pattern with COR.
i configured COR and For long distance calls i need to use pin to call so i created
after-hours block pattern 1 900 7-24
then each user i created pin
when i login it is working and showing ephone staus also TRUE but no luck to make LD calls.
is this an issue on cme or anyother way to do it.
i seen some LPcor i didnt understand the concept.
can anybody brief me.
thanks
Hi Cyril,
Maybe you are seeing this Restriction;
Note  that logging in to a phone with a PIN only allows the user to override  call blocking that is associated with particular time periods.  ***Blocking patterns that are created with the 7-24 keyword in the  after-hours block pattern command are in effect 7 days a week, 24 hours a  day, and they cannot be overridden by using a PIN.
So you would need to configure something like Philip did in the original post
From this good CME doc;
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
hi rob,
i am attached my COR config and block pattern
i am going to config this lines only . is this config will work for international call with pin?
trunk group ALL_FXO
trunk group NIDCO
dial-peer cor custom
name PT-EMERGENCY
name PT-CUSTOMER-CARE
name PT-LOCAL
name PT-NATIONAL
name PT-INTERNATIONAL
name NIDCO-Local
name NIDCO-National
name NIDCO-Intl
dial-peer cor list CSS-EMERGENCY
member PT-EMERGENCY
dial-peer cor list CSS-CUSTOMER-CARE
member PT-CUSTOMER-CARE
dial-peer cor list CSS-INTERNATIONAL
member PT-INTERNATIONAL
dial-peer cor list CSS-LOCAL
member PT-LOCAL
dial-peer cor list CSS-NATIONAL
member PT-NATIONAL
dial-peer cor list CSS-USER
member PT-EMERGENCY
member PT-LOCAL
dial-peer cor list CSS-EMPLOYEE
member PT-EMERGENCY
member PT-LOCAL
member PT-NATIONAL
dial-peer cor list CSS-EXECUTIVE
member PT-EMERGENCY
member PT-LOCAL
member PT-NATIONAL
dial-peer cor list NIDCO-INTERNATIONAL
member NIDCO-Intl
dial-peer cor list NIDCO-LOCAL
member NIDCO-Local
dial-peer cor list NIDCO-NATIONAL
member NIDCO-National
dial-peer cor list NIDCO-USER
member NIDCO-Local
dial-peer cor list NIDCO-EMPLOYEE
member NIDCO-Local
dial-peer cor list NIDCO-EXECUTIVE
member NIDCO-Local
member NIDCO-Intl
dial-peer voice 60 pots
trunkgroup ALL_FXO
corlist outgoing CSS-LOCAL
description LOCAL CALLS
destination-pattern 9[^0678]......
dial-peer voice 61 pots
trunkgroup ALL_FXO
corlist outgoing CSS-NATIONAL
description NATIONAL CALLS
destination-pattern 90[2-4].......
prefix 0
dial-peer voice 62 pots
trunkgroup ALL_FXO
destination-pattern 90[6-9].......
prefix 0
dial-peer voice 63 pots
trunkgroup ALL_FXO
destination-pattern 905[056].......
prefix 05
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing CSS-CUSTOMER-CARE
description EMERGENCY CALL
destination-pattern 91[0-9].
prefix 1
dial-peer voice 65 pots
trunkgroup ALL_FXO
destination-pattern 99[9].
prefix 9
dial-peer voice 66 pots
trunkgroup ALL_FXO
description CUSTOMER CARE
destination-pattern 96[0-9]T
prefix 6
dial-peer voice 67 pots
trunkgroup ALL_FXO
destination-pattern 98[0-9]T
prefix 8
dial-peer voice 68 pots
trunkgroup ALL_FXO
destination-pattern 97[0-9]T
prefix 7
dial-peer voice 150 pots
trunkgroup ALL_FXO
description ** E1 Incoming Dial Peer **
incoming called-number .
direct-inward-dial
dial-peer voice 69 pots
trunkgroup ALL_FXO
corlist outgoing CSS-INTERNATIONAL
description INTERNATIONAL CALL
destination-pattern 900[1-9]T
prefix 00
dial-peer voice 2000 voip
description ***Incoming Call from LYNC***
b2bua
session protocol sipv2
session target ipv4:192.168.20.7:5068
session transport tcp
incoming called-number .%
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2001 voip
tone ringback alert-no-PI
description ***Call to LYNC***
translation-profile outgoing LYNC_ADD_PLUS
destination-pattern 1..
rtp payload-type comfort-noise 13
dtmf-relay rtp-nte
codec g711ulaw
fax protocol none
dial-peer voice 70 pots
trunkgroup NIDCO
corlist outgoing NIDCO-LOCAL
dial-peer voice 71 pots
trunkgroup NIDCO
corlist outgoing NIDCO-NATIONAL
prefix 0
dial-peer voice 72 pots
trunkgroup NIDCO
prefix 0
dial-peer voice 73 pots
trunkgroup NIDCO
prefix 05
dial-peer voice 74 pots
trunkgroup NIDCO
prefix 1
dial-peer voice 75 pots
trunkgroup NIDCO
prefix 9
dial-peer voice 76 pots
trunkgroup NIDCO
prefix 6
dial-peer voice 77 pots
trunkgroup NIDCO
prefix 8
dial-peer voice 78 pots
trunkgroup NIDCO
prefix 7
dial-peer voice 79 pots
trunkgroup NIDCO
corlist outgoing NIDCO-INTERNATIONAL
prefix 00
telephony-service
max-ephones 42
max-dn 100
ip source-address 10.1.1.1 port 2000
ephone-dn  11  dual-line
number 201 no-reg primary
pickup-group 1
label 201
description 201
name 201
corlist incoming CSS-EMPLOYEE
hold-alert 15
ephone  1
mac-address 2C36.F859.497E
type 7911
button  1:11
pin 2580
