04-29-2015 01:01 AM - edited 03-17-2019 02:50 AM
Hi Gents,
First of all, I have CUCM 10.5.
I followed all the steps necessary to configure the Trace , in the Cisco Unified Serviceability .
The final configuration is in the attachment.
My problem is, that whenever I go to RTMT - > Collect Files - > Cisco Call Manager Service(for the node I need) - > Date/Time and press the Finish button, I get just 2 folders : calllogs and SDL.
Checking the files with Notepad++ ,from both folders, they do not seem to be the usual CCM SDI traces .
Shouldn't be also another folder with SDI traces ?
Have I configured something wrong, so that I do not get these type of traces ?
Many thanks !
L.E.
Even on the CUCM CLi ,looks like there is not SDI data :
admin:file list activelog /cm/trace/ccm/sdi/
dir count = 0, file count = 0
Solved! Go to Solution.
04-29-2015 03:18 AM
Starting CUCM 9.X , traces are interleaved, which means SDI traces are now recorded along with SDL traces in the SDL files.
You can find more details below :
https://supportforums.cisco.com/document/135851/interleaved-traces-callmanager-9x
Aditya Gupta
04-29-2015 03:18 AM
Aditya Gupta
04-29-2015 05:00 AM
Thank you Aditya,
That's like to be good informed !
Could have searched long time for those traces...
Thanks again !
