compatible cucm and unity connection version
shohamshalom
hello
i have unity connection ver 8.0.3  and cucm manager 8.0.3
i need to upgrade the cucm to ver 8.5
did it works?
i cant find some doc about it
tk
5 Replies 5
Rob Huffman
Hi there,
Supported Version Combinations for Cisco Unity Connection and Cisco Unified Communications Manager
Cisco Unity Connection 2.x and Later
Any version of Cisco Unity Connection 2.x or later is supported for use with any version of Cisco Unified CM 4.1(3) or later.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
Cheers!
Rob
thanks rob
but the pdf shows that there is not compatible  between unity connection 8.0.3 with cucm 8.5(express)
and also i have cucm manager and not the express
please have a look the attach
Rob Huffman
Hi there,
The first portion of the doc as well as the clip I linked, refers specifically
to CUCM not CME
Cheers!
Rob
thanks man
u the best!!!!!
Rob Huffman
Hi there,
Please disregard the info related to CME ...it just happens to be on the same
doc as the CUCM references and has no bearing on anything related to CUCM
and CUC compatibility
The **only** part that matters is this;
This means that CUC 8.0(3) would work with the following;
CCM 4.1(3),4.2(x) and 4.3(x)
CUCM 5.x,6.x and 7.x all versions
CUCM 8.0 and 8.5 all versions
Cheers!
Rob
