cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Compatible Headset Model for Cisco IP Phone 7945 G
networks PTC
HI Team,
We have recently purchased Cisco IP Phone 7945G & installed at one of our site. Now We need to procure the Headset for this 7945G IP phone Model.
Can you please share the Compatible Headset Model ( Both Wired & wireless ) for this 7945G IP phone.
OEM would be Jabra & Plantronics.
Appreciate your quick suppport
Thanks & regards,
Dayanand Waghmare
email: dwaghmare@ptc.com
Phone: +917875522110
3 RESPOSTAS 3
Rob Huffman
Hi Dayanand,
There are literally hundreds of supported models for the 7945 from both Plantronics and Jabra. You can use the compatibilty guides to narrow down your search;
For Plantronics;
http://www.plantronics.com/ca/compatibility-guide/#/search/
For Jabra;
http://www.jabra.ca/headsets-and-speakerphones/compatibilityguide#selectedProducts=%5B%7B%22EhsRccSupport%22%3A2%2C%22EhsSupport%22%3Afalse%2C%22ID%22%3A5637187909%2C%22Manufacturer%22%3A%7B%22ID%22%3A5637148436%2C%22Name%22%3A%22Cisco%22%7D%2C%22Nam...
Our users love the Plantronics CS540 with the APC-42 cord that enables calls to be answered via the headset when used with CUCM and Electronic Hookswitch Control enabled.
Cheers!
Rob
Hi Rob,
Can you suggest the specific Plantronic model of Headset ( Over a head & Over a hear ) which supports Cisco IP Phone 7945G perfectly.
One more thing how to enable Electronic Hook Switch Control with CUCM.
Thanks & regards,
Dayanand Waghmare
Hi Dayanand,
One of the many reasons that users love the CS540 is that it is convertible and can be worn "over the ear" or "over the head (mono and binaural)" and comes with all the required parts to wear either way. You can also order a "behind the head neckband" for people who don't want to muss up their fancy hairdo's :) SWEET!!
To enable EHS > from CUCM admin  Device>Phone (find the 7945) you set the Wireless Headset Hookswitch Control (under Product Specific Configuration)>Enabled>Save>Apply
Don't forget the cord I mentioned above (APC42 is required) for EHS
If you are looking for a "wired" equivalent I would recommend the DuoPro or the EncorePro 540  which come with all the parts to wear multiple ways as well. For any "wired" Plantronics model you order you'll also need this cord to work with Cisco phones;
http://www.plantronics.com/us/product/coil-cord-to-qd-modular-plug
Cheers!
Rob
