04-28-2015 02:34 AM 03-17-2019 02:49 AM 更新
Hi there - I'm very new to IP Telephony and was looking for some information on what the key components of an IP Phone system was. Here's what I have gathered
Is there anything else I need besides the above (I've been seeing a lot of Cisco Unified Communications Manager - what's this for?)
Finally, would appreciate it if anyone could give specific model numbers for the components for a basic setup of approximately 100 IP Phones (Cisco IP Phone 8800 Series)
Thank you.
解決済! 解決策の投稿を見る。
04-28-2015 03:09 AM
The best way to think of it is 'what do you have in a normal phone system' and what replaces each part in a VOIP one?
PBX - the brain of the phone system - this is basically Comunications Manager; it manages your dial plan, configuration etc.
Phones - easy, replace with IP Phones.
PSTN Connections - replaced with Voice Gateways; you need these to connect to anything non-IP, e.g. E1/T1 ISDNs, or FXO/FXS lines. A fancy voice gateway for IP-to-IP if you have a SIP service provider is CUBE (basically a voice gateway with more software licensing rather than physical interfaces)
Wires - instead of a room full of mind-boggling cables extending to every corner of your building, you have a nice easy network of routers/switches, WAN circuits and VPNs. Oh, and of course you do have a network of Cat5 cables extending to every corner of your building.
Aaron
04-28-2015 03:09 AM
Aaron
04-28-2015 03:22 AM
Hi Aaron,
Thank you very much for your fantastic reply which addresses all my queries. One final question, what device do I need to get to install the Communications Manager - can it be installed on any Windows machine or is there a specific device needed?
Many thanks!
04-28-2015 05:27 AM
You have two options:
Communications Manager Express - runs in IOS, on a router.
Communciations Manager - comes in lots of varieties, but is a Linux appliance that can be installed into VMware.
It would be best to speak to your Cisco partner about this, there are lots of options to consider.
Aaron
04-28-2015 06:44 AM
Thank you very much.
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
