07-14-2018 04:24 AM - edited 03-17-2019 01:12 PM
Hi everyone,
Is it possible to use conditional dial-peer for SRST?
For example , I've a router via MGCP registered to CUCM. The router have 3 E1 cards and in normal circumstances they are used by 3 different device pools in CUCM. But what if all phones falls to SRST ,how can i use these 3 E1 cards in the same manner?
Ilyas
Solved! Go to Solution.
07-15-2018 04:22 PM
07-14-2018 11:40 AM
If you're using only MGCP in the GW, the call routing would only use the dial-peers when you go into SRST mode, then you need to configure the routing as you need with the inbound and outbound dial-peers.
07-14-2018 12:05 PM
Thank you for reply Jaime.
I am aware about it. I just want to know , how to force router to send calls lets say for x range numbers via first e1, for y range via second e1 and for z range via third e1
Ilyas
07-15-2018 04:22 PM
You can try COR with SRST
